电子发烧友App
硬声App
电子发烧友网>通信网络>通信设计应用>QuickChip Design Example 2 Low
收藏
查看更多
4.5V 5.5A汽车类SEPIC转换器启停应用
A (TLV62065)3.3V output at 1A (TLV62065)This example design is supported with design and test files
2018-12-21 14:25:41
Design Note for DN06018/D
Design Note for DN06018/D12V or 24Vin DC, Constant Current LED Driver Key
2009-11-19 17:23:03
Design Note for DN06009/D
Design Note for DN06009/D5W,CCCV Cell Phone Battery ChargerThis circuit presents a very simple, low
2009-11-20 09:04:04
Design of low-voltage low-power CMOS operational amplifier cells
分享一本书:Design of low-voltage low-power CMOS operational amplifier cells
2021-06-22 07:01:47
Design of Combinational Circuit
Design of Combinational CircuitWhat is Combinational CircuitCombinational Circuit if–Outputs at a
2008-09-11 09:33:56
Low_Power_Design
Low_Power_Design分享给大家
2013-05-13 06:48:53
A Low-Noise-Amplifier at 1.9 GHz using BFP405
The design emphasis has been on achieving a low noisefigure. A circuit description, schematic, pcb
2009-05-12 14:10:12
A Low-Noise-Amplifier at 900 MHz using SIEGET BFP420
This application note describes a low noise amplifier at 900MHz usingSIEMENS SIEGET?25 BFP420.
2009-05-12 13:43:24
A Low-Noise-Amplifier shows good Noise Figure performance at 1.9 GHz using BF
2009-05-12 13:36:57
A Low-Noise-Amplifier with good IP3outperformance at 1.9 GHz using BFP420
This application note describes a low noise amplifier at 1.9GHz using SIEMENSSIEGETa25 BFP420.
2009-05-12 13:33:19
A Model Checking Example--Solving Sudoku Using Simulink Design Verifier
Formal verification methods prove mathematically that a design does not contain unwanted behavior.
2011-07-18 09:39:54
AN644
AN644 - QuickChip Design Example 2 Low Power Silicon BJT LNA for 1.9GHz - Maxim Integrated Products
2022-11-04 17:22:44
Advanced Design System(ADS)使用指南教程
of the stepped-impedance low pass filer obtained in Example 8.6 inMicrowave Engineering, 3rd, Pozar. This filer
2008-07-21 11:48:17
Altium Design:Getting Started with PCB Design
and the target output, for example the FPGA, embedded (VHDL), library package, or in this case the PCB design
2015-01-27 10:24:11
DDR2设计原理 DDR2 design
Analysis Needs– PRBS Support (Custom Stimulus)– Eye diagram AC, DC and Vref Support[hide]DDR2-design.pdf[/hide]
2009-11-19 09:59:04
ESP32-S2运行example\ ulp\uulp-fsm,运行不了是为什么?
目前用的ESP32-S2运行example ulpuulp-fsm。但是运行不了,
2023-02-14 08:44:37
High and low temperature test chamber
low-temperature loop system design.Standards Applied GB/T2423.1-2001 and GB/T2423.2-2001Specs
2011-06-15 15:13:17
Modelsim是如何运行example_design的?
)。我只想用Modelsim运行example_design,看看它是如何工作的。我正在关注UG586.pdf手册和一些readme.txt文件,了解“如何实现模拟”。但我不这么认为我走上正轨。我追踪
2020-05-11 09:11:44
NXP PCF8562TT/2 2k Universal LCD driver for low multiplex rates
LCDs Low power consumption 400 kHz I2C-bus interface No external components required Manufactured in silicon gate CMOS process
2021-08-04 11:04:21
Nvidia Shanghai Hiring---ASIC Design Engineer
multi-disciplinarygroup environment -Knowledge on video, or network, or layout, or low-power design
2012-07-06 14:30:34
SIEGET45 - Low Noise Amplifier with BFP520 Transistor at 1.9 GHz
This application note describes an example of a Low Noise Amplifier with theBFP520 (5th Generation
2009-05-12 14:00:34
SMBus Design Using Low Power Microcontroller
`描述This design utilizes existing Launchpad evaluation kits and BoosterPack plug-in modules
2015-03-23 10:02:29
Speed Example
Design Requirement??The design need to run at 78Mhz or above??All the pin has been locked down, you
2008-09-11 09:30:36
TPS40200通用非同步最低成本降压转换器
built and tested and the design files and test report are included. This is a good low cost design
2018-12-24 16:03:02
Vivado无法创建IBUF_LOW_PWR的原因?
。 Vivado忽略'IBUF_LOW_PWR',但保留了实现工具。 [C:/ac701_mig/mig_7series_0_example/mig_7series_0_example.runs/impl_1
2020-05-06 10:32:02
[UPF]低功耗(Low Power Design)and UPF介紹 精选资料分享
低功耗(Low Power Design)and UPF介紹一、低功耗設計策略(Lower-power design strategies)1.1、動態和靜態功耗(Dynamic
2021-07-27 07:26:56
[社招-成都] VeriSilicon(成都)招聘ASIC Design/DV/Video IP Design/算法等职位
computer graphics and low-power design techniques a plus7. Experienceof ISP or GPU design
2016-12-02 13:17:00
altium designer10中没有reference design and example么?
altium designer10中没有reference design and example么?怎么添加啊
2012-07-20 19:59:03
springer 2011 classic book]Operational Amplifiers: Theory and Design, 2nd
`Operational Amplifiers: Theory and Design, 2nd Edition[/td][td]by:[size=90%]Johan
2012-01-04 15:21:48
vivado tri mode ethernet mac 不产生example design的解决办法
2020-12-24 07:55:33
xilinxGTH的example design问题
[tr=transparent]gth_sim_common.v中例化了GTHE2_COMMON,为什么树形结构中不显示GTHE2_COMMON.v,工程是xilinxGTH的example design[/tr]
2018-06-30 22:21:56
Low Voltage Power MOSFETs Design, Performance and Applications》
`求书《Low Voltage Power MOSFETs Design, Performance and Applications》,这本书里主要讲了什么内容?`
2021-06-22 08:07:36
【下载】《Analysis and Design of Analog Integrated Circuits》
are fabricated, including recent issues like heterojunction bipolar transistors, copper interconnect and low
2018-04-13 17:45:08
使用user design文件夹下的.v文件,如果编写顶层读写控制程序对mig-39-2.v进行例化,如何操作才能使用sim_tb_top.v仿真文件?
本帖最后由 一只耳朵怪 于 2018-6-22 17:45 编辑 最近在学习DDR3的使用,用的是xilinx的mig-39-2 IP核,仿真并下板调试了example design文件夹
2018-06-22 17:14:40
微型Bluetooth低成本专有RF无线MCU参考设计
描述This reference design is an example of using the SimpleLink™ Bluetooth® Smart CC2543 low
2018-11-19 11:55:16
求书:Design and Implementation
求书:Low-Voltage CMOS Operational Amplifiers: Theory, Design and Implementation
2021-06-22 06:11:30
符合CoC Tier 2 2016标准的5V 2A适配器应用设计包括BOM及层图
EMI. This design uses diode rectifier for low cost and meets COC V5 Tier2 2016 specification
2018-09-13 08:56:10
RF circuit design: Basics
application•Low noise amplifier design•Mixer design•Oscillator design Basic RF circuit block
2008-11-27 22:59:1923
LinkSwitch-XT Design Guide
LinkSwitch-XT Design Guide:The LinkSwitch-XT family is designed for low power adaptersand chargers
2009-06-30 08:08:5516
PeakSwitch Design Guide
PeakSwitch Design Guide:The PeakSwitch family is a highly integrated, monolithic,off-line switcher
2009-06-30 08:09:3018
Low-Power Design Techniques an
In the world of electronics, high-performance systems often need to be designed with a low power
2009-07-21 08:44:440
SystemVerilog for Design(Secon
: A package definition ...9Example 2-2: Explicit package references using the :: scope resolution operator .10Example 2-3: Import
2009-07-22 14:45:340
Power Aware Design Methodologi
A dichotomy exists in the design of modern microelectronic systems: theymust be simultaneously low
2009-07-24 14:10:210
Filter Handbook a Practical Design Guide
Chapter 1: Introduction Chapter 2:Modem filter design:the low-pass filtcr Chapter
2009-07-25 15:49:073
Low-Power Digital Vlsi Design An Overview
Low-Power Digital Vlsi Design:An Overview:
2009-07-25 16:41:210
Analysis and design of a low-v
A CMOS low-voltage downconversion mixer is presented. With 1.69-GHz local oscillator signal input
2009-09-08 08:29:335
TMP303A,pdf ( Low-Supply TEMPE
The TMP303A is a temperature range monitor that offers design flexibility through its extra small
2010-06-01 08:54:5512
Low Power IC Design of the Wir
Low Power IC Design of the Wireless Monitoring System of the Orthopedic Implants:Abstract—A low
2010-06-09 07:43:0921
QuickChip Design Example 1 - A
QuickChip Design Example 1 - A Silicon Bipolar Broadband PLL Building Block Integrated Circuit
2008-09-17 16:14:12905
Design a Low-Jitter Clock for
Abstract: High-speed applications using ultra-fast data converters in their design often require
2009-04-16 16:34:231576
accommodate signal frequencies from 0.5GHz to 9GHz is presented. The design integrates a prescaler with selectable divide ratio, a phase detector,
2009-04-20 15:19:44815
MAX1420/MAX12553 example
MAX1420/MAX12553 example Abstract: This application note demonstrates how to quickly verify
2009-05-01 10:46:40613
Semicustom QuickChip ASICs Imp
design methodology and the more traditional full-custom design methodology. The semicustom design approach is discussed below and provides a low-
2009-05-06 09:04:20612
Layout Guidelines with Example
Layout Guidelines with Example Layout for the MAX16922 PMIC Abstract: This application note
2010-02-21 09:59:452073
Example_DSP2803x_Watchdog
2016-01-13 16:55:474
Example_DSP2803x_SWPrioritizedInterr
Example_DSP2803x_SWPrioritizedInterr.rar。
2016-01-13 16:56:414
Example_DSP2803x_LEDblink
Example_DSP2803x_LEDblink.rar。
2016-01-13 16:57:4310
Example_DSP2803x_GpioToggle
2016-01-13 16:58:206
Example_DSP2803x_GpioSetup
Example_DSP2803x_GpioSetup.rar。
2016-01-13 16:59:0217
Example_2803xEPwmUpDownAQ
Example_2803x开发板源程序分享
2016-01-18 16:28:416
Example_2803xEPwmUpAQ
2016-01-18 16:28:232
Example_2803xECap_Capture_Pwm
2016-01-18 17:02:558
Example_2803xEPwmTripZone
2016-01-18 17:03:0910
Example_2803xCpuTimer
2016-01-18 17:03:150
Example_2803xAdc_TempSensor
Example_2803xAdcTempSensor
2016-01-21 11:04:503
Low-Sensitivity_Bandpass_Filter_Design_with_Tuning_Method
This Application Note covers the design of a Sallen-Key bandpass biquad. It gives a design with low component and op amp sensitivities。
2016-02-22 14:13:480
Low-Sensitivity, Highpass_Filter_Design_with_Parasitic_Compensation
Low-Sensitivity, Highpass Filter Design with Parasitic Compensation
2016-02-22 14:28:3517
Altium_Mod_Player_Example
Altium Mod Player Example,好东西,喜欢的朋友可以下载来学习。
2016-02-22 16:02:100
COM Programming by Example
, or helper applications of COM can stand alone — you need an example of how to use them all together
2016-06-17 17:24:540
RF放大器设计 Low Noise Amplifier Design
RF放大器设计 Low Noise Amplifier Design 030724
2017-03-05 15:25:101
D类放大器设计实例,Class D amplifier design example
D类放大器设计实例,Class D amplifier design example 关键字:D类放大器,D类放大器设计,D类放大器原理
2018-09-20 19:12:361046
ADICUP3029 Source Code Example
2021-01-29 13:53:260
EVAL-AD5592R-PMDZ & ADICUP3029 Embedded Example Code
2021-01-31 09:40:076
Example SigmaStudio Program
2021-02-03 09:21:071
ADICUP3029 Bluetooth Example
2021-02-04 10:06:090
ADuCM360 C Code Example
2021-02-19 14:15:263
2021-02-19 14:34:285
LTC6362/LTC5599 Demo Circuit - Low-Power I/Q Modulator Driver (Baseband Design)
2021-03-10 13:30:360
Xilinx平台Aurora IP介绍(四)Example Design介绍
多看一些example design之后,你就会发现都是熟悉的配方。
2022-02-19 19:13:203685
在CtrlSim中加入电机控制几个example
ctrlsim里面也已经加入了电机控制几个example,感兴趣的同学可以玩玩,具体的文档和讲解得后面整理了。
2022-09-09 10:42:46404
Application Example for Cloud Connectivity(AE-CLOUD1) 用户手册
Application Example for Cloud Connectivity (AE-CLOUD1) 用户手册
2023-03-16 19:13:010
Product Example HMI1(PE-HMI1) 快速入门指南
Product Example HMI1 (PE-HMI1) 快速入门指南
2023-03-22 18:44:170
Application Example for Capacitive Touch(AE-CAP1) 用户手册
Application Example for Capacitive Touch (AE-CAP1) 用户手册
2023-03-22 19:03:580
S7G2HMI Product Example(PE-HMI1) 快速入门指南補足資料
S7G2 HMI Product Example (PE-HMI1) 快速入门指南補足資料
2023-03-24 18:32:340
S7G2HMI Product Example(PE-HMI1) 用户手册
S7G2 HMI Product Example (PE-HMI1) 用户手册
2023-03-29 19:03:200
2023-07-06 19:58:340
Application Example for Cloud Connectivity(AE-CLOUD2) 用户手册
Application Example for Cloud Connectivity (AE-CLOUD2) 用户手册
2023-07-06 20:38:560
2023-07-07 20:33:520
2023-07-07 20:53:370
2023-07-10 20:22:160
2023-07-11 19:28:040
PICO Example Clion开发
以下是一些在 linux 环境下,使用 Clion 开发基于 C/C++ SDK 的 PICO-Example 的注意事项,使用 Clion 的下载和调试配置在上一篇文章中已经介绍。
2023-10-09 10:16:30449
已全部加载完成
