安路 SALEAGLE® (以下简称 AL3)系列 FPGA 有 5 个器件,定位低成本、低功耗可编程市场。AL3 器件旨在用于大批量,成本敏感的应用,使系统设计师在降低成本的同时又能够满足不断增长
2022-10-27 07:58:23
How to upload document? 谢谢
2014-09-19 09:02:59
各位好!请教AD1852相关问题。
1, AD1852 datasheet中的BCLK(或LRCLK)、fs、MCKL三者是什么关系?
2, 图中1852输入数据 SDATA左
2023-12-22 06:05:21
Technical specifications and product information for the E1852A.
2019-05-29 16:04:04
Learn about what the E1852B Bluetooth® Test Set can do for you.
2019-06-18 08:42:15
E1852B蓝牙测试仪安装指南
2019-07-30 08:17:00
Software release information for the E1852B Bluetooth test set.
2019-07-24 12:49:09
我的两块ESP8266(AL-THINKER)开发板都不能读防水DS18B20,但是可以读标准DS18B20/To-92封装。测试了 4.7 K 和更低的上拉电阻。3.3 V 和 5 V 电源均经过
2023-05-30 11:42:02
帧存储器AL440B具有什么特点?AL440B的典型应用是什么?
2021-06-04 06:19:17
各位好!请教AD1852相关问题。1, AD1852 datasheet中的BCLK(或LRCLK)、fs、MCKL三者是什么关系?2, 图中1852输入数据 SDATA左=0x007FFFFF
2018-11-13 09:37:03
请教个问题
AD1852能否输出直流?若要输出直流,在硬件和软件上如何设计?
谢谢!
2023-11-30 08:22:59
请教个问题AD1852能否输出直流?若要输出直流,在硬件和软件上如何设计?谢谢!
2018-11-12 15:08:55
AL128.pdf
2007-12-24 22:10:202 AL250.pdf
2007-12-24 22:10:434 The AD1852’s flexible serial data input port accepts data intwos-complement, MSB-first format.
2009-09-12 15:00:4622 This app note shows how to connect a DS1390 to a Motorola DSP that has a built-in SPIinterface
2010-04-25 10:21:1018 Processing (DSP) unit using a SPI interface. This app note shows how to connect a DS1390 to a Motorola DSP that has a built-in SPI interface
2010-05-29 08:37:4911 How to Calculate the Wiper Voltage of a Digital Potentiometer
2008-10-01 12:08:38882 How to Use the DS2482 I²C 1-Wire® Master
Abstract: The DS2482 is an I²C to 1-Wire bridge. The
2008-12-18 09:54:061317
Calculating Energy Usage: How Costs Drive Conservation
By: Moe Rubenzahl
2009-03-23 21:46:28618 How to Replace a DS1213 SmartSocket with an Equivalent-Density NV SRAM Module
Abstract: The DS1213 SmartSocket products have reache
2009-03-31 08:20:10965 How to Use the DS1678 Real-Time Event Recorder
Abstract: This note demonstrates an application
2009-03-31 22:42:241068 Abstract: The DS1854, DS1857, and DS1858 monitor VCC, ambient temperature, and external analog
2009-04-17 11:40:09775 Abstract: The DS1852 is a digital potentiometer with five analog inputs that can be used
2009-04-17 11:42:47434
How to Interpret DS1847/DS1848 Temperature Readings
Abstract: The DS1847 and DS1848 have
2009-04-17 11:43:37821 Abstract: This application note describes how the DS18B20-PAR, DS18S20-PAR and DS
2009-04-17 11:45:101224 Abstract: This application note provides an example of how to configure a single T1 port on DS
2009-04-18 11:29:24986 Abstract: This application note provides an example of how to configure a single T1 port on DS
2009-04-18 11:30:32785 Abstract: This application note shows how to configure various loopback modes of the DS31256 HDLC
2009-04-18 11:31:23731 Abstract: How to interface the DS2172/DS21372 BERT to all Dallas Semiconductor family of T1/E1
2009-04-18 11:33:54718 Abstract: This application note explains how to configure the bit-error-rate tester (BERT
2009-04-18 11:39:25888 Abstract: This application note shows how to configure the Interleaved Bus Operation (IBO
2009-04-18 11:49:17994 Abstract: Application Note 3344 shows how to configure the hardware connections that can
2009-04-20 08:44:22851 Abstract: This application note provides an example of how to configure a single T3/E3/HSSI/VDSL
2009-04-20 08:51:19857 Abstract: The DS2151DK and DS2153DK are ordered and shipped for either T1 or E1 operation. However
2009-04-20 10:25:02559 Semiconductor DS2151 T1 single chip transceiver (SCT) and how to configure them.
Special Mode #1: 3 State OutputsWhen the S
2009-04-20 10:27:551173 Abstract: This application note describes how the DS2141A, DS2143, DS2151, and DS2153 interface
2009-04-20 10:31:04536 the adequate information and schematic on how to use this device DS2141A to create this Channel Service Unit.
2009-04-20 10:32:45904 Abstract: This application note describes how the DS2141A, DS2143, DS2151, and DS2153 interface
2009-04-20 10:37:00899 Abstract: This application note describes how the DS2141A, DS2143, DS2151, and DS2153 interface
2009-04-20 10:41:16744 software download become unusable for any reason. This application note describes how the DS4510, DS4520, and DS4550 non-volatile I/O expande
2009-04-20 11:08:51995 Abstract: This application note describes how to interface a DS1302 in an application
2009-04-21 09:28:46793 Abstract: This application note provides information on how to interface a DS1307 real-time clock
2009-04-21 11:04:331013 Abstract: The DS1847 and DS1848 have an on-chip direct-to-digital temperature sensor.
2009-04-22 12:03:231008 Abstract: The DS1852 is a digital potentiometer with five analog inputs that can be used
2009-04-22 12:05:21865 Abstract: The DS1854, DS1857, and DS1858 monitor VCC, ambient temperature, and external analog
2009-04-22 12:07:181097 Abstract: The following application note discusses how the DS1233 can be used to save data during
2009-04-23 09:58:011940 Abstract: The application note demonstrates how to configure the MAXQ2000 microcontroller EV kit
2009-04-23 16:34:16676 software download become unusable for any reason. This application note describes how the DS4510, DS4520, and DS4550 non-volatile I/O expande
2009-04-24 09:20:51686 Abstract: The purpose of this application note is to show how to apply a temperature offset
2009-04-28 10:23:19844 1859, and DS1856. This application note describes how to use the DS186xEVKIT with the DS1856, a part that was introduced after the EV Kit was develop
2009-04-28 11:19:31842 Abstract: The DS1854, DS1857, and DS1858 monitor VCC, ambient temperature, and external analog
2009-04-28 11:23:101199 Abstract: This application note describes how to use the DS3900 PC serial port to 3-wire interface
2009-04-28 11:50:56812 Abstract: The DS2151DK and DS2153DK are ordered and shipped for either T1 or E1 operation. However
2009-04-29 10:13:031037 the adequate information and schematic on how to use this device DS2141A to create this Channel Service Unit.
2009-04-29 10:17:37754 Abstract: This application note describes how the DS2141A, DS2143, DS2151, and DS2153 interface
2009-04-29 10:18:40496 Abstract: This application note describes how the DS2141A, DS2143, DS2151, and DS2153 interface
2009-04-29 10:20:011154 Abstract: This application note describes how the DS2141A, DS2143, DS2151, and DS2153 interface
2009-04-29 10:21:40752 Abstract: This application note describes how CCFL lamps can be dimmed and how a user can maximize
2009-05-02 10:40:301359 Abstract: The DS1852 is a digital potentiometer with five analog inputs that can be used
2009-05-08 09:06:21723 Abstract: This application note describes how to use the DS3900 PC serial port to 3-wire interface
2009-05-08 09:09:22696 How to Cal
2009-09-27 14:22:091127 How to Switch the DisplayPort Hot-Plug-Detect Signal with the MAX4928
Abstract: The MAX4928A/B are DisplayPort™ swi
2009-09-27 14:44:331861 How to bui
2010-08-01 11:38:28935 AL8806资料。
2016-03-30 16:34:507 该文档是AD1852(立体声数字音频回放系统)中文资料用户手册,AD1852的应用特征、功率参数、应用范围和基本电路。还包括AD1852应用电路图和引脚配置图,是最全的AD1852中文资料,欢迎大家免费下载。
2017-10-29 14:12:2918 This video provides step-by-step instructions on how to download, compile, and configure DPDK.
2018-10-23 06:11:002276 电子发烧友网为你提供ADI(ti)AD1852相关产品参数、数据手册,更有AD1852的引脚图、接线图、封装手册、中文资料、英文资料,AD1852真值表,AD1852管脚等资料,希望可以帮助到广大的电子工程师们。
2019-02-22 13:12:34
Linux操作系统的Configure参数解释说明Linux环境下的软件安装,并不是一件容易的事情;如果通过源代码编译后在安装,当然事情就更为复杂一些;现在安装各种软件的教程都非常
2019-04-02 14:46:25472 从“Al换脸”到模仿人类灵感,Al深度伪造技术引发担忧!人工智能的强大毋需多言,其富有的惊人创造力令人叹为观止,但当Al脱离了人类的掌控,它的可怕之处同样是你无法想象的…近日,Google开发出一款
2019-07-04 15:07:415168 很多代码都有 configure文件,需要执行一下 configure 才能产生Makefile。
2020-06-23 08:56:062596 DC1852A-演示手册
2021-05-11 20:02:341 DC1852A-模式
2021-05-12 15:47:402 DC1852A-设计文件
2021-06-08 08:11:282 View the reference design for EVAL-AD1852EB. http://www.elecfans.com/soft/ has thousands of reference designs to help bring your project to life.
2021-06-29 09:49:232 View the reference design for DC1852A. http://www.elecfans.com/soft/ has thousands of reference designs to help bring your project to life.
2021-07-28 15:44:091 电子发烧友网为你提供ADI(ti)DC1852A相关产品参数、数据手册,更有DC1852A的引脚图、接线图、封装手册、中文资料、英文资料,DC1852A真值表,DC1852A管脚等资料,希望可以帮助到广大的电子工程师们。
2021-08-05 16:00:03
./oschina_soft/xcode-configure.zip
2022-05-18 11:02:411 本应用笔记旨在说明如何配置DS1852,使报警和警告门限符合SFF-8472标准的存储器位置要求。
2023-01-11 11:43:48379 PS9307AL、PS9307AL2 数据表
2023-01-13 19:06:400 DS1852是一款数字电位器,具有5路模拟输入,可与电位器配合使用,收集模拟系统的反馈信息,并提供模拟控制功能。其预期应用是在激光收发器中提供高水平的控制和仪表,但它可用于需要这种仪器和控制的任何类型的控制系统。
2023-01-16 09:41:42358 PS2581AL1、PS2581AL2 数据表
2023-02-03 19:09:370 UPD23C32040AL, 23C32080AL 数据表 (M15772EJ4V0DS00)
2023-05-09 18:54:510 UPD23C32000AL 数据表 (M15773EJ5V0DS00)
2023-05-09 18:55:110 本应用笔记重点介绍光模块的SFF-8472和XENPAK标准。它显示了光电探测器增益的变化如何影响测量的功率水平。光电探测器针对光纤应用进行了校准。图中显示了光收发器监视器的内部和外部校准方法。内置DS1852光收发器诊断监视器。
2023-06-10 11:30:32578 UPD23C32040AL, 23C32080AL 数据表 (M15772EJ4V0DS00)
2023-06-27 20:16:090 UPD23C32000AL 数据表 (M15773EJ5V0DS00)
2023-06-27 20:16:220 PS9307AL、PS9307AL2 数据表
2023-07-03 19:49:010 PS2581AL1、PS2581AL2 数据表
2023-07-04 19:41:450 电子发烧友网为你提供Maxim(Maxim)MAX1852EXT+T相关产品参数、数据手册,更有MAX1852EXT+T的引脚图、接线图、封装手册、中文资料、英文资料,MAX1852EXT+T真值表,MAX1852EXT+T管脚等资料,希望可以帮助到广大的电子工程师们。
2023-07-07 19:00:35
电子发烧友网为你提供Maxim(Maxim)DS1852B-000+T&R相关产品参数、数据手册,更有DS1852B-000+T&R的引脚图、接线图、封装手册、中文资料、英文资料,DS1852B-000+T&R真值表,DS1852B-000+T&R管脚等资料,希望可以帮助到广大的电子工程师们。
2023-07-19 18:54:23
电子发烧友网为你提供Maxim(Maxim)DS1852B-000+相关产品参数、数据手册,更有DS1852B-000+的引脚图、接线图、封装手册、中文资料、英文资料,DS1852B-000+真值表,DS1852B-000+管脚等资料,希望可以帮助到广大的电子工程师们。
2023-07-19 18:55:32
电子发烧友网为你提供Maxim(Maxim)DS1852B-000相关产品参数、数据手册,更有DS1852B-000的引脚图、接线图、封装手册、中文资料、英文资料,DS1852B-000真值表,DS1852B-000管脚等资料,希望可以帮助到广大的电子工程师们。
2023-08-16 18:41:26
电子发烧友网为你提供Maxim(Maxim)DS1852B-000/T&R相关产品参数、数据手册,更有DS1852B-000/T&R的引脚图、接线图、封装手册、中文资料、英文资料
2023-08-16 18:41:38
电子发烧友网为你提供Maxim(Maxim)DS1852B-00C+T&R相关产品参数、数据手册,更有DS1852B-00C+T&R的引脚图、接线图、封装手册、中文资料、英文资料,DS1852B-00C+T&R真值表,DS1852B-00C+T&R管脚等资料,希望可以帮助到广大的电子工程师们。
2023-08-16 18:54:31
电子发烧友网为你提供Maxim(Maxim)DS1852B-00C+相关产品参数、数据手册,更有DS1852B-00C+的引脚图、接线图、封装手册、中文资料、英文资料,DS1852B-00C+真值表,DS1852B-00C+管脚等资料,希望可以帮助到广大的电子工程师们。
2023-08-16 18:55:26
查看更多
