This application note provides 8 hints for improving the accuracy of your measurements using RF signal generators.
2018-10-08 11:29:49
要快速分析Android应用程序在连接的移动设备上的表现,请使用Performance Advisor从Streamline配置文件中生成易于阅读的性能摘要。
本教程介绍如何:
•执行安装任务以准备
2023-08-09 06:51:01
本教程介绍如何:
•执行安装任务以准备
2023-08-10 07:15:07
layout and components list areshown below together with measured performance data.Data at 1.9 GHz (3V
2009-05-12 13:36:57
, pcb layout and componentslist are shown below together with measured performance data.Data at 1.9
2009-05-12 13:52:47
Performance Advisor分析Streamline捕获中的性能数据,并生成一份报告,显示应用程序在移动设备上的运行情况。
捕获摘要显示您是否正在实现目标帧速率、每个处理单元花费的时间分布以及CPU和GPU利用率。
2023-08-10 06:59:21
2023-08-09 07:23:17
定期的性能报告使您能够在整个开发周期中获得即时反馈。
要自动生成每日HTML或JSON报告,帮助您的团队监控开发周期中的变化如何影响性能,请将performance Advisor集成到您的持续
2023-08-08 07:32:01
Designing High-Performance Video Systems with the AXI InterconnectHigh-performance video systems
2012-01-26 18:57:03
efficiency, high performance andhigh power converters continues to expand. Demand forsmaller, lighter
2009-05-12 11:13:19
to the performance microcontroller TM4C129XNCZAD. The implementation is made possible by using the EPI Interface
2015-04-08 10:33:35
MSM8953_ANDROID_PERFORMANCE_OVERVIEW芯片资料
2017-11-16 19:29:13
Introduction to NetMetrix Performance Center
2019-07-02 07:33:13
Installation Guide for NetMetrix Performance Center
2019-07-02 11:31:22
system verification testing reducing time to market and improving quality.
2019-09-17 14:44:38
The STM32F103xx medium-density performance line family incorporates the high-performance
2021-07-16 08:13:35
Synthesiable High Performance SDRAM ContollerSynchronous DRAMs are available in speed grades above
2009-12-17 17:02:58
This is the PDF version of the System Performance Analyzer online help for the 16700A/B-series logic analysis system (version A.02.70 software).
2019-07-18 13:59:28
the overall network capacity and performance by distributing devices across multiple bands. This helps
2023-06-08 09:59:06
alternative to ASSPs and ASICs.XC7VX690T-1FF1157C Key Features· Advanced high-performance FPGA
2018-09-04 08:56:30
《High Performance AC Drives Modelling Analysis and Control》总结恒转矩系统:提升机,传输机,活塞式压缩机。转矩与转速成比例;风机,压缩机
2021-08-31 08:26:42
`求书《Low Voltage Power MOSFETs Design, Performance and Applications》,这本书里主要讲了什么内容?`
2021-06-22 08:07:36
requirements for basic safety and essential performance GB9706.1-2020-3.27 基本性能 附 ...
GB 9706.1-2020 医用
2023-10-08 09:07:57
當藍芽產品洗板打件完成後除了SW RD build code給EE RD驗證功能外,對RF RD最重要的功課莫過於RF performance的量測及fine tune了。而藍芽RF
2019-09-20 09:05:03
10KHz,但是量测结果较差,SNR只有74dB,noise floor较高。怀疑是信号源不能满足测试需求,那请教该如何正确测量16bit ADC DC&AC performance?
2018-10-09 16:08:04
您好!能否把ADS1298RECG-FE ECG Front-End Performance Demonstration Kit的配套软件地址链接发给我,谢谢!我从官网上下载的调解不出呼吸波形,不知道是不是下错了,谢谢!
2019-06-05 11:22:18
sampling requirements of IEC 61850-9-2), simplifying system design and improving trip time
2018-10-01 06:33:57
32MCU – SAM product line High-performance - CM7 seriesUpto 300MHz, 512-2048KB FLASH, 256-384KB
2021-11-03 09:02:04
PLL Performance, Simulation, and Design 3rd Edition,Basic PLL Operation and TerminologyThis section
2008-08-16 10:21:56174 8-Lead LLP Thermal Performance and Design GuidelinesIntroductionThe new leadless leadframe package
2009-01-13 18:25:4520 Performance Differences between theMPC8240 and the MPC106Top Changwatchai and Roy
2009-04-01 22:05:3425 High DSP Performance Platform– The DSP48E Slice– Essential DSP Building Blocks• Imaging Algorithms
2009-04-09 22:05:3112 high performance stereo routing switcher
2009-04-18 20:37:2348 High-Performance 16-Point Complex FFT
•This document is (c) Xilinx, Inc. 1999. No part
2009-05-14 11:00:2815 Designing a High Performance SDRAM Controller Using ispMACH Devices
Synchronous DRAMs have become
2009-05-14 11:03:4228 Designing a High Performance SDRAM Controller Using ispMACH Devices
2009-06-14 08:55:3124 High-performance RF design for PXI:PXI presents a significant opportunity for RF instrumentation.
2009-07-23 22:50:2511 PLL Performance, Simulation,and Design 3rd Edition:
PLL BASICS ......9
CHAPTER 1 BASIC PLL
2009-07-25 16:51:130 High Performance CMOS Imagers and Higher IntegrationAs the CMOS imager becomes more specialized
2009-09-23 23:05:177 architectureGSC3F/LP(High Performance GPS Single Chip)GPS DSP with integrated real time clock(RTC) ARM7TDMI CPU4M
2009-09-28 12:02:3016 for AC/DCconverter with high performance versus cost ratio. It provides continuous output power up to 12W in the broad voltage range of 85V
2009-12-10 14:55:0419 Today’s class of high-performance FPGAs, such as the Altera® Stratix® III device, provide
2010-02-25 23:37:1310 OB3318 is a high performance Cold Cathode Fluorescent Lamp (CCFL) backlight controller IC dedicated
2010-03-01 15:34:5034 TDA18211HD Raising performance and lowering the cost of set-top box applications
The TDA18211HD
2010-03-08 14:18:0114 Using LME49810 to Build a High-Performance Power Amplifier –Part I:Although switching
2010-04-10 22:16:2350 HPS1007X HIGH PERFORMANCE LED POWER SUPPLY
Wide input & output voltage
2010-04-19 15:31:0213 The PCM4220 is a high-performance, two-channel analog-to-digital (A/D) converter designed for use
2010-06-13 10:38:2422 The PCM4222 is a high-performance, two-channel analog-to-digital (A/D) converter designed for use
2010-06-13 10:42:2027 Executive Summary Contactless cards are a key technology for improving the consumer
2010-06-30 00:50:055 Improving the Performance of your LabVIEW ApplicationsLearn how to identify and resolve performance
2010-07-01 11:07:37112 Abstract A high-performance data-path to implement DSP kernels is introduced in this paper.
2010-07-01 15:44:4027 Media Processing Challenges• Increasing performance requirements• Need for flexibility
2010-07-01 15:53:5812 Test engineers can now accurately and repetitively confirm performance metrics and save hours
2010-07-10 11:19:2515 Introduction:Agilent’s all new next-generation Medalist i3070 Series 5 comes with a new analog stimulus response unit (ASRU revision N) card along with software release 08.00p. The ASRU revision N card not only pr
2010-08-16 15:47:1119 Improving Receiver Sensitivity with External LNA
Abstract: This application note presents
2008-09-17 16:20:08774 High-Performance, 32-Bit Microcontroller Integrates Security Supervisor and Cryptographic Functionality for Financial Applications
The
2008-09-24 17:02:281168 High-Performance Level-Shifter Solution for LCD TVs with Gate-in-Panel (GIP) Technology
2009-02-02 16:05:311243 防火墙术语-Performance Management 英文原义:Performance Management
中文释义:性能管理
注 解:用来评定通
2010-02-24 11:00:08532 This application note will help the designer of high-performance multichannel data acquisition
2010-07-04 12:15:227206 71M6513 Broadband VARh Harmonic Performance Teridian Semiconductor Corporation has developed
2011-02-06 10:10:5128 71M6513 Harmonic Performance Teridian Semiconductor Corporation has developed a custom compute
2011-02-06 10:34:0946 HP ZR24w S-IPS Performance系列显示器采用拉丝铝制外壳,不仅外观非常时尚,出色的节能性能更是让它从众多同类产品中脱颖而出。该显示器的电源效率高达 85% 以上 *。此外,秉承尽量提高
2011-04-21 11:12:0315 The DS31415 is a flexible, high-performance timing IC for diverse frequency conversion
2011-08-01 16:27:0425 HPL is a parallel Linpack benchmark package widely adopted inmassive cluster system performance
2011-11-03 22:24:3318 and focuses on the hover performance improvements over a conventional unshrouded micro quad rotor
2016-05-13 11:28:057 全新手动激光焊接系统Performance再添新成员
2016-12-25 22:27:010 无限能量传输论文
Performance of Three-Phase Analog Network Coding with
Relay Selection in Nakagami-m Fading
2017-02-15 22:24:2110 8-Lead LLP Thermal Performance and Design Guideleines
2017-03-24 16:24:091 Improving Amplifier Noise Figure for High 3rd Intercept Amplifiers
2017-03-24 15:52:190 Measuring And Improving Differential Gain and Differential Phase For Video Buffers w_Disable
2017-03-24 15:00:370 The Intel® MPI Library offers many configuration options for improving application performance
2018-10-16 04:10:002410 The Intel® MPI Library offers many configuration options for improving application performance
2018-10-15 03:57:002089 The Intel® MPI Library offers many configuration options for improving application performance
2018-09-29 06:13:002467 The Intel® MPI Library offers many configuration options for improving application performance
2018-09-10 10:00:003048 12 月 10 日消息,据国外媒体报道,在大规模生产标准续航升级版和长续航版 Model 3 之后,特斯拉位于上海的超级工厂,又将开始生产 Performance 高性能版 Model
2020-12-09 17:31:541971 AD9984A: High Performance 10-Bit Display Interface Data Sheet
2021-01-28 02:21:3912 Performance Gallery
2021-02-04 14:20:251 Improving Color Sensor Lux Accuracy
2021-02-24 08:11:202 090-国外技术干货:facebook_performance_caching-dc(波兰电源插座)-国外技术干货:facebook_performance_caching-dc
2021-07-26 13:15:0114 充电桩 OBC DCDC—High Performance Solution for EV Char(笔记本电源电压缓慢上升)-充电桩、OBC、DCDC—High Performance Solution for EV Charging
2021-07-26 14:32:4863 MPSoC的DDR控制器的数据通道上集成了 AXI performance monitors (APM)。具体情况,可以参考Xilinx UG1085 (v2.2)中Chapter 15的“Figure 15‐1: PS Interconnect”或者Figure 17-1。
2022-08-02 14:20:081830 UM-PM-051 DA9168 Performance Board User 手册
2023-01-10 19:06:230 UM-PM-028 DA6102 Performance Board 用户指南
2023-03-22 19:02:300 User 手册 UM-PM-019 DA9313 Performance Board
2023-03-22 19:13:150 High-performance Embedded Workshop V.4.09 用户手册 Rev.1.00
2023-04-17 19:49:230 High-performance Embedded Workshop HewTargetServer 用户手册 Rev.8.00
2023-04-18 18:37:120 High-performance Embedded Workshop V.4.08 用户手册
2023-04-18 19:39:270 AZ850V4 Ver.4.10 System Performance Analyzer 用户手册
2023-05-04 19:33:360 AZ850 Ver.3.30 System Performance Analyzer 用户手册
2023-05-06 18:54:450 High-performance Embedded Workshop V.3补充文件(关于如何查看工具链版本)
2023-05-11 20:16:480 AZ850 Ver.3.30 System Performance Analyzer 用户手册
2023-06-26 20:41:120 High-performance Embedded Workshop V.3补充文件(关于如何查看工具链版本)
2023-06-28 20:41:190 UM-PM-051 DA9168 Performance Board User 手册
2023-06-30 19:52:030 UM-PM-028 DA6102 Performance Board 用户指南
2023-07-07 20:52:220 User 手册 UM-PM-019 DA9313 Performance Board
2023-07-10 18:32:340 Performance Distributor大奖。这项荣誉是对安富利GC(大中华区)团队出色表现的认可,也是对NXP和安富利携手共创成就的肯定。 获此荣誉,安富利中国区总裁董花女士对NXP在AA业务中提
2023-09-19 10:55:58490 电子发烧友网为你提供ADI(ADI)MAX30009: Low-Power, High-Performance Bioimpedance Analog Front-End Data Sheet相关
2023-10-13 18:42:02
近日,一辆未加遮掩的Model 3 Performance原型车在西班牙瓦伦西亚现身,推测在进行广告拍摄工作。尾部“Ludicrous”标签提示该型号性能相当卓越,该标识曾用于Model S Performance车型,后被“Plaid”替代。
2024-02-27 15:18:25146
查看更多
