电子发烧友App
硬声App
电子发烧友网>通信网络>通信设计应用>Bench Characterization of ADCs
收藏
查看更多
ADCS-1120
ADCS-1120 - Agilent CMOS Monochrome Image Sensors - Agilent(Hewlett-Packard)
2022-11-04 17:22:44
ADCS-2120
ADCS-2120 - Agilent CMOS Monochrome Image Sensors - Agilent(Hewlett-Packard)
2022-11-04 17:22:44
ADCS7476
ADCS7476 - 1MSPS, 12-/10-/8-Bit A/D Converters in SOT-23 & LLP - National Semiconductor
2022-11-04 17:22:44
ADCS7476AIMF
ADCS7476AIMF - 1MSPS, 12-/10-/8-Bit A/D Converters in SOT-23 & LLP - National Semiconductor
2022-11-04 17:22:44
ADCS7476AIMFE
ADCS7476AIMFE - 1MSPS, 12-/10-/8-Bit A/D Converters in SOT-23 & LLP - National Semiconductor
2022-11-04 17:22:44
ADCS7476AIMFX
ADCS7476AIMFX - 1MSPS, 12-/10-/8-Bit A/D Converters in SOT-23 & LLP - National Semiconductor
2022-11-04 17:22:44
ADCS7476AISDX
ADCS7476AISDX - 1MSPS, 12-/10-/8-Bit A/D Converters in SOT-23 & LLP - National Semiconductor
2022-11-04 17:22:44
ADCS7477
ADCS7477 - 1MSPS, 12-/10-/8-Bit A/D Converters in SOT-23 & LLP - National Semiconductor
2022-11-04 17:22:44
ADCS7477AIMF
ADCS7477AIMF - 1MSPS, 12-/10-/8-Bit A/D Converters in SOT-23 & LLP - National Semiconductor
2022-11-04 17:22:44
ADCS7477AIMFX
ADCS7477AIMFX - 1MSPS, 12-/10-/8-Bit A/D Converters in SOT-23 & LLP - National Semiconductor
2022-11-04 17:22:44
ADCS7477|ADCS7478|ADCS7476
ADCS747x 1-MSPS, 12-Bit, 10-Bit, and 8-Bit A/D Converters datasheet (Rev. G)
2022-11-04 17:22:44
ADCS7478
ADCS7478 - 1MSPS, 12-/10-/8-Bit A/D Converters in SOT-23 & LLP - National Semiconductor
2022-11-04 17:22:44
ADCS7478AIMF
ADCS7478AIMF - 1MSPS, 12-/10-/8-Bit A/D Converters in SOT-23 & LLP - National Semiconductor
2022-11-04 17:22:44
ADCS7478AIMFE
ADCS7478AIMFE - 1MSPS, 12-/10-/8-Bit A/D Converters in SOT-23 & LLP - National Semiconductor
2022-11-04 17:22:44
ADCS9888CVH-140
ADCS9888CVH-140 - 205/170/140 MSPS Video Analog Front End - National Semiconductor
2022-11-04 17:22:44
ADCS=5禁用DONE位?
,然后设置ADCS=5,就可以“中断”代码。实际上(ADCS=2,就像DS39739B-page 51-25中的“示例51-2:转换一个信道,手动样本启动,手动转换开始代码”),循环运行良好。
2020-04-08 10:47:34
Characterization of Microstrip Meanders in PCB Interconnects
2009-03-27 15:44:59
ACQT和ADCS值怎么选择
) ACQT - A/D Acquisition time select bits2) ADCS - A/D Conversion Clock Select bits How should i
2018-12-14 16:41:50
EFR-DI-IMG-CHAR-SITE
IMAGE CHARACTERIZATION IP CORE
2023-03-22 19:59:38
Modelsim 和Test Bench 经典教程
本帖最后由 eehome 于 2013-1-5 10:11 编辑 Modelsim 和Test Bench 经典教程
2012-08-10 22:59:12
NVIDIA英伟达上海急招实验室技术员
:- PCB rework including surface mount componentsoldering/desoldering- Memory Characterization
2014-04-25 17:43:47
STM32CubeMX配置ADCs_Common_Settings
STM32CubeMX配置ADCs_Common_Settings(ADC基础设置)  Mode(工作模式)Independent mode(独立模式):在同一引脚上仅有一个ADC在采集模拟信号
2021-08-18 08:21:46
ST是否为其MEMS器件提供特性数据?
ST是否为其MEMS器件提供特性数据? #mems #characterization以上来自于谷歌翻译以下为原文 Does ST provide characterization data for its MEMS devices? #mems #characterization
2018-11-09 09:46:51
Test bench
test bench
2012-10-27 13:51:22
【MPS电源评估板试用体验】测评之五:EVREF0103A电源板之released-virtual_bench_pro配置 ,示波器查看
`` 看到测评人员无法连接released-virtual_bench_pro配置EVREF0103A出现问题,周末出个教程测试一下。首先打开released-virtual_bench
2020-07-12 16:58:15
【TI社招】新推TI多个研发职位! 有志者快来申请!
Engineer (DC-DC)DESCRIPTION:Bench validation and characterization on DC/DC power management IC
2014-09-18 16:13:27
上海阿尔斯通急聘Electrical Engineer for test bench
Responsibilities• To participate in the definition/configuration of the Test Bench facilities
2013-08-24 22:29:54
什么是总ADCs转化率?
什么是总ADCs转化率?数据表(PSoC®5LP:CY8C58LP系列)只提到了采样率。
2019-10-22 09:52:53
如何创建Test Bench WaveForm
我已经安装了ISE webpack(大小:约5G)30天免费。我的问题是我的新源向导窗口上没有Test Bench WaveForm行。为此,我是否必须再次安装另一个?如果是这样,它是什么?谢谢你
2018-11-21 14:22:43
怎样去使用Makefile+VCS+Verdi做个简单的Test Bench
怎样去使用Makefile+VCS+Verdi做个简单的Test Bench?有哪些操作步骤?
2021-06-18 06:28:09
无法生成test bench files
请问各位大佬:modelsim安装破解都正常,但是不能生成test bench files是怎么回事?Quartus版本12.1,modelsim版本10.1
2017-07-08 21:23:46
求分享Motor Work Bench通信协议文档
正在寻找 Motor Work Bench 通信协议文档,因为我们想使用 STSPIN32F0 控制多个电机,因此我无法使用 Motor COntrol Work Bench
2023-01-29 06:41:10
请教大神SFUD bench测试失败的原因是什么?
FF ................4、sf bench 测试,读失败msh >sf bench yesErasing the sf_cmd 16777216 bytes data
2023-03-07 14:07:41
请问ADCS的计算方法是什么?
亲爱的大家,我使用的是PIC24FJ64GB004。在ADC部分,A/D转换时钟周期计算有一个注释“基于TCY=2*TOSC,打瞌睡模式和锁相环被禁用。”所以如果我使用的是PLL(32MHZ,FCy 16Mhz),那么ADCS的计算方法是什么?请参考附件图像。谢谢,Gaurav Patni。
2019-09-25 07:04:20
请问使用AMOX与ADCs有一些已知的bug吗?
的输出。使用AMOX与ADCs有一些已知的bug吗?AMUX数据表没有列出稳定时间或任何必要的信息。有什么建议吗?我的目标是尽可能低的周期,所以有一个延迟是不理想的。谢谢
2019-08-12 09:34:43
请问谁有如何写test bench的资料么?
请问谁有如何写test bench的资料么,麻烦发一份 谢谢
2015-11-02 21:20:07
跪求Hybrid ADCs Smart Sensors
求ebook之Advances in Analog Circuit Design 2017:Hybrid ADCs, Smart Sensors。
2021-06-22 07:30:42
USB速度测试软件
USB速度测试软件:bench32.exe
2009-03-21 11:30:1284
Characterization of Microstrip Meanders in PCB Interconnects Meandering traces are often used
2009-03-24 13:03:120
ADUC834,pdf datasheet (ADCs wi
The ADuC834 is a complete smart transducer front end,integrating two high resolution - ADCs
2009-09-04 10:05:3425
ADUC836,pdf datasheet (ADCs wi
The ADuC836 is a complete smart transducer front end, integratingtwo high resolution ?-? ADCs
2009-09-04 10:09:0730
6-Channel SAR ADCs for Industr
6-Channel SAR ADCs for Industrial Monitoring and PortableInstruments:The 14-bit LTC2351-14
2009-09-23 22:57:517
Interfacing to High Speed ADCs
Interfacing to High Speed ADCs via SPI:This application note describes how to use the SPI port
2009-09-30 19:43:3915
ADCS7476/ADCS7477/ADCS7478,pdf
ADCS7476/A
2009-10-12 09:33:4219
Characterization fo Cdv_dt Ind
Characterization fo Cdv_dt Induced Power Loss in Synchronous Buck DC-DC Converters:Synchronous buck
2009-11-28 15:41:2020
Thermal Characterization of Pa
Thermal Characterization of Packaged Semiconductor Devices:With the continuing industry trends
2009-11-29 17:16:0122
10-/12-Bit ADCs in 6-Lead SC70
10-/12-Bit ADCs in 6-Lead SC70GENERAL DESCRIPTIONThe AD7910/AD7920 are, respectively, 10-bit
2010-04-07 10:14:5315
AD9653BCPZ-125 ADCs 4-Channel Quad ADC Pipelined 125Msps 16-bit S
Analog DevicesAD9653BCPZ-125Analog to Digital Converters - ADCs4-Channel Quad ADC Pipelined 125Msps
2023-11-07 19:03:41
Continuous Dynamic Analysis an
Introduction Nanoscale characterization of biological materials continues to be a challenge
2010-08-13 10:15:467
Mechanical Characterization of
Introduction This application note presents the results of nanomechanical tests in which an Agilent Nano Indenter G200 was used to measure the Young’s modulus and hardness of three sol-gel coatings. The same instr
2010-08-13 10:29:464
Introduction This application note presents the results of nanomechanical tests in which an Agilent Nano Indenter G200 was used to measure the force and displacement while crushing single ceramic particles. Two type
2010-08-16 15:27:137
Pipeline ADCs Come of Age
Pipeline ADCs Come of Age Abstract: In the mid 1970s, a new data converter architecture
2009-04-16 16:21:01965
and mixed-signal community, called pipeline ADCs. The following article takes the knowledge of advantages and disadvantages of the pipeline architec
2009-04-25 10:22:04979
流水线模数转换器的时代-Pipeline ADCs Come
2009-05-01 10:57:54970
Understanding SAR ADCs
Abstract: Successive-approximation-register (SAR) analog-to-digital converters (ADCs) represent
2009-05-08 09:34:21783
2009-05-08 09:35:34654
类比数位转换器的同步采样-ADCs for Simultan
Abstract: Multichannel analog-to-digital converters (ADCs) typically convert each input channel
2009-05-08 09:54:54895
可调的实验电源:Programmable Bench Pow
可调的实验电源:Programmable Bench Power Supply The complete power supply shown in Figure 30 is a programmable positive and negativ
2009-05-16 16:44:52969
Understanding flash ADCs
Flash analog-to-digital converters, also known as parallel ADCs, are the fastest way to convert
2010-09-17 13:13:131122
2010-09-19 10:56:52907
MAX11634–MAX11637(12-bit analog-to-digital converters ADCs )
The MAX11634MAX11637 are serial 12-bit analog-todigitalconverters (ADCs) with an internal reference
2011-09-28 10:59:2917
ASimplifiedTestSetforOpAmp
A Simplified Test Set for Op Amp Characterization
2017-03-24 08:00:000
NI Virtual Bench和Cloudium两款产品的介绍
观看Xilinx Xcell每日博客编辑Steve Leibson,介绍NI Virtual Bench和Cloudium集成媒体处理平台的两款产品。
2018-11-27 06:46:003457
AD7938-6: 8-Channel, 625 kSPS, 12-Bit Parallel ADCs with a Sequencer Data Sheet
2021-01-28 11:03:131
AD7938/AD7939: 8-Channel, 1.5 MSPS, 12-Bit and 10-Bit Parallel ADCs with a Sequencer Data Sheet
2021-01-28 14:50:281
AD4682/AD4683: Pseudo Differential Input, 1 MSPS/500 kSPS, Dual, Simultaneous Sampling, 16-Bit, SAR ADCs Data Sheet
2021-01-29 08:35:042
AD4680/AD4681: Differential Inputs, 1 MSPS/500 kSPS, Dual Simultaneous Sampling SAR ADCs Data Sheet
2021-01-29 08:37:041
10 lead Pulsar ADCs Evaluation Software
2021-02-01 13:17:220
AD7822/AD7825/AD7829:3 V/5 V,2 MSPS,8位,1/4/8通道采样ADCs数据谢伊
2021-04-16 20:49:216
AD7788/AD7789:低功率、16/24位、西格玛-德尔塔ADCs数据谢伊
2021-04-17 09:05:513
LTC2228/LTC2227/LTC2226:12位、65/40/25MSps低功率3V ADCs数据谢伊
2021-04-21 16:42:303
AD7912/AD7922:2频道,2.35 V对5.25V 1MSPS,10/12位ADCs数据Sheet
2021-04-26 21:01:176
AD7910/AD7920:250 kSPS,10/12位ADCS在6个Lead SC70数据Sheet中
2021-04-28 19:25:031
AD7911/AD7921:2频道,2.35 V对5.250KSPS,10/12位ADCs数据谢伊
2021-04-29 08:13:188
AD7466/AD7467/AD7468:1.6V,Micropower 12/10/8位ADCs数据Sheet
2021-04-29 15:25:492
LTC2238/LTC2237/LTC2236:10位,65/40/25mps的低功率3V ADCs数据Sheet
2021-04-30 08:55:477
LTC2253/LTC2252:12位,125/105msps低功率3V ADCs数据盘
2021-05-08 21:34:591
LTC2421/LTC2422:1/2频道20-MSOP-10数据Shet中的非拉丁Digma Sigma ADCS
2021-05-09 19:40:151
AD7273/AD7274:3 MSPS,8-Lead TSOT数据Sheet中的10-12位ADCS
2021-05-11 09:57:420
AD7476/AD7477/AD7478:1 MSPS,6-Lead SOT-23数据Sheet中的12/10/8位ADCS
2021-05-14 19:04:566
AD7276/AD7277/AD7278:3 MSPS,6-Lead TSOT数据Sheet中的12/10/8位ADCS
2021-05-14 20:45:160
LTC1860/LTC1861:MSOP数据Sheet中的微功率、12位、250ksps 1和2通道ADCS
2021-05-19 17:06:5410
AD7475/AD7495:1 MSPS,12位ADCs数据Sheet
2021-05-26 11:15:045
AD7616的国产替代方案—ADCS16162(16位16通道同步采样ADC)
一款完全兼容AD7616的国产替代方案—芯动神州的ADCS16162,16位16通道同步采样ADC
2022-10-28 09:13:289880
对OP AC特性仿真Bench的理解
下图是我们常见的用于仿真OP的AC特性(DC增益、GBW等)的Bench。我们通过在OP的输出和输入之间串联一个一阶RC网络(R、C值通常都很大)的形式组成一个闭环系统,而我们需要的其实是OP的开环特性。
2023-05-23 18:26:501068
AD4680/AD4681: 不同输入、1 MSPSP/500 kSPS、双同时抽样SAR ADCs数据表 ADI
电子发烧友网为你提供ADI(ADI)AD4680/AD4681: 不同输入、1 MSPSP/500 kSPS、双同时抽样SAR ADCs数据表相关产品参数、数据手册,更有AD4680/AD4681
2023-10-09 18:33:39
AD4682/AD4683: 优度差异输入, 1 MSPSP/500 kSPS, 双、同声抽样, 16比特, SARS ADCs数据表 ADI
电子发烧友网为你提供ADI(ADI)AD4682/AD4683: 优度差异输入, 1 MSPSP/500 kSPS, 双、同声抽样, 16比特, SARS ADCs数据表相关产品参数、数据手册,更有
2023-10-09 18:50:46
AD4684/AD4685: 1 MSPS/500 kSPS, 4-通道, 16-Bit 双筒, 同步取样 SAR ADCs数据表 ADI
电子发烧友网为你提供ADI(ADI)AD4684/AD4685: 1 MSPS/500 kSPS, 4-通道, 16-Bit 双筒, 同步取样 SAR ADCs数据表相关产品参数、数据手册,更有
2023-10-09 18:56:19
已全部加载完成
