MAX2170 S11 Data for VHF and L-Band Input
Abstract: This application note shows how the MAX2170 triple-band (T-DMB, DAB, FM) receiver's input-scattering parameter (S11) is measured for the VHF and L-band inputs. OverviewThe MAX2170 direct conversion to low-IF tuner has an input scattering parameter (S11), which is measured for the VHF and L-band inputs. The calibration plane is at the pin of the IC.The VHF input consists of a bandpass tracking filter followed by an LNA. The return loss will be good for the desired channel, but will look reflective for the out-of-band channels. As a result, the S11 data will change significantly as the MAX2170 tunes to a new channel. To address this issue, the series 91nH inductor, which is part of the VHF tracking filter, was removed from the input for the S11 measurements (Figure 1). Removing this component changes the tracking filter's shape but allows S11 calibration to the pin of the IC. Note, however, that the 91nH inductor is required for the tracking filter to operate properly. It must be used in the final application. The L-band input consists of ESD diodes and an LNA. The input will look resistive with some shunt capacitance. The S11 data for this input will not vary when the MAX2170 tunes to a new channel. The L-band input can be modeled as a resistor R = 23.4Ω in series with C = 4.2pF. Figure 1. Schematic of the VHF and L-band inputs to the MAX2170. The 91nH inductor for the VHF input can be removed for calibration of S11 data. Performance SummaryTable 1 shows S11 data (magnitude and phase) for the VHF and L-band inputs. The RF frequency is changed for each measurement.Table 1. S11 (Magnitude/Phase) for VHF and L-Band Input
Table 2 shows S11 data (real and imaginary) for the VHF and L-band inputs. The RF frequency is changed for each measurement. Table 2. S11 (Real/Imaginary) for VHF and L-Band Inputs
Test ResultsFigure 2. The Thevenin equivalent resistance and capacitance for the VHF input when the RF is tuned to 174.928MHz. Figure 3. The Thevenin equivalent resistance and capacitance for the VHF input when the RF is tuned to 204.64MHz. Figure 4. The Thevenin equivalent resistance and capacitance for the VHF input when the RF is tuned to 239.2MHz. Figure 5. S11 magnitude and phase for the VHF input with the MAX2170 tuned to 174.928MHz. Note that this s-parameter data will change if the MAX2170's RF frequency changes. Figure 6. The Thevenin equivalent resistance and capacitance for the L-band input. The Thevenin equivalent circuit looks the same for RF frequencies from 1450MHz to 1500MHz. The average value is R = 23.4Ω in series with C = 4.2pF. Figure 7. The Thevenin model of L-band RF input in a 50Ω system Figure 8. S11 magnitude and phase for the L-band input. Test FilesThe following test files contain S11 data in CITIFILE format for the MAX2170.
- VHF(33998)
- MAX2170(6990)
2.4G射频硬件调试 S11 灵敏度
各位专家好,
最近在一直被要求提高CC2530的通信距离,
模块是我们自己设计生产的的,最近在调S11参数,发现模块在上电和非上电状态下,S11的最低点对应频率不一样
问:是否以上电状态的S11参数为准?
另,如何测试灵敏度,S11参数越小是否对应灵敏度也会越高?
盼回复!
2018-06-24 03:13:57
MAX7219的问题
;lt;= s8;end//初始化完成 s10: if(olddata != data)currentstate <= s11;//正常送数据显示elsecurrentstate &
2022-10-12 23:00:09
S11
S11 - 10 to 500 MHz Thin Film SPST Switch - M/A-COM Technology Solutions, Inc.
2022-11-04 17:22:44
S11参数以及功率的测量
大家好,我最近用到了矢量网络分析仪,对S11参数不是特别理解。S11参数是回波损耗,即反射功率与入射功率的比值。请问这种功率是指瞬时功率,即瞬时电压电流的乘积吗?如果我想搭建一个测量这种回波损耗
2019-04-17 13:25:42
S11的带宽是什么意思?是系统工作带宽吗?
怎样从这张图中看出 LNA 的 S11 的带宽呢?S11的带宽是什么意思? 应该是系统工作带宽吧?一般把S11换算成dB 20*log10(abs(S11)) ,横轴是频率,然后低于-10dB的一段
2021-06-25 07:54:27
S21数据显示看到ADS也在绘制S21
-parameter simulation using data items with s1p file. the file contains only reflection parameter S11 from port 1.
2018-09-29 17:21:39
N5182A信号发生器能生成dvb-s2信号吗?
嗨,我想在L-BAND(950Mhz到1950Mhz)中生成DVB-S和DVB-S2信号(QPSK,8PSK,16APSK和16QAM)。 N5182A信号发生器能做到吗?我的目标是通过我的卫星设备
2019-08-02 12:10:18
PNA-X,S参数测量的优化
22'); ... fprintf(instrObj,'CALC:DATA:SNP:PORTs?''1,2'''); ......我认为(纠正我,如果我错了),就像这样,Port1打开两次,一次用于S11,一次用于S21测量。现在
2018-12-11 16:18:03
SOLT与不同的s11和s22为2端口cal
嗨,我们为定制界面制作了SOLT校准套件。然而,当进行两个端口校准时,我们发现s11和s22是不同的。这有什么原因吗?但是当单独进行1端口校准时,我们可以获得相同的s11和s22。只有我们做2端口
2019-02-14 15:28:12
Wallys launches high-performance Tri-Band solutions/ipq4019+qca9882.
to transmit data and provide Wi-Fi connectivity. In a typical tri-band setup, two frequency bands
2023-06-08 09:59:06
comsol仿真声表面波二维结构怎么仿真出导纳和S11曲线
comsol仿真声表面波二维结构怎么仿真出导纳和S11曲线,已仿真出振型图和谐振频率,就是不知道怎么仿出S11曲线。
2019-11-12 22:13:51
三频段RF调谐器MAX2170资料推荐
MAX2170采用6mmx6mm、40引脚QFN封装,工作在-40℃至+85℃温度范围。工作在2.7V至3.3V电源电压下,在L频段低功耗模式下消耗150mW(典型值)的功率。除了晶振和某些应用所需
2021-04-19 07:33:08
关于频率转换器件S参数的问题
Satellite Block up converters(BUC) and Low Noise Blocks.(LNB) Here input to BUC is in L-Band(1-1.5 Ghz
2018-10-12 17:21:35
利用S11求天线谐振频率
正如在我上一篇文章中我试图找出一大批未知的freq mobile&amp;便携式天线。我一直试图找到他们设计的频段,使用8720分析仪设置为S11返回损耗,然后切换到史密斯图表检查50欧姆。问题是
2018-08-29 16:44:36
在geneys中有一个12端口怎么在史密斯图表输出上看到S11,11
如果我在geneys中有一个12端口,并希望在史密斯图表输出上看到S11,11怎么办?我将什么放入图表对话框中。 S11,S33,S99分别适用于端口1,3和9。但是,当我告诉它图S11,11
2019-04-24 15:56:52
如何使用矢网PA测量S11、S21和饱和功率呢?
输入端反射的功率,因此以这种方法测到的S11实际上是DA的S11,并且由于加入了DA,矢网激励源给信号的功率一般会给得较小,因此回到A接收机的功率也比较小,导致S11迹线噪声非常大,如图2.2。 图
2023-03-22 14:39:53
如何将天线s1p文件用作源模拟给定匹配电路的S11频率?
嗨,我有两个组件(天线和射频功率计)的* .s1p文件,并希望在几个频率之间创建匹配电路。如何将天线s1p文件用作源,将powerm s1p文件用作负载端子Z,以模拟给定匹配电路的S11频率?谢谢你
2019-07-09 09:41:41
开路电缆显示S11为+7 dB
我在尝试校准VNA时遇到问题。在完成一个完整的2端口校准后,如果我将端口1打开,我会读到大约+ 7dB的S11。设置如下:* HP 8720D 20 GHz VNA,带3.5 mm连接器
2019-05-27 11:12:19
快速校准验证s11在+/-0.7 dB范围内可以接受?
参考快速校准验证...我已经使用TOM(Thuro-Open-Matched)进行校准......然后使用短标准来验证来自同一校准套件的校准...&amp;它显示s11测量范围+/- 0.8
2018-10-16 14:31:39
怎么使用E8361C网络分析仪测量S11参数
您好,对于我的硕士论文,我使用了E8361C网络分析仪和N4373C光波分量分析仪来测量激光二极管的电光频率响应。现在我需要使用E8361C网络分析仪测量S11参数。由于我还没有这方面的测量经验,我
2019-07-05 15:25:53
是否可以使用全双端口校准中的S11不确定性来覆盖单端口校准的不确定性?
,增强响应或响应),没有单端口校准。我们是否可以使用全双端口校准中的S11不确定性来覆盖单端口校准的不确定性?或者我们是否必须执行全双端口校准来测量单端口设备?注意:查看各种Agilent VNA
2018-12-29 16:32:11
有什么方法或技术可以改善或稳定S11参数的测量?
间隔内发生变化,有时候它重新调整74,其他73,76,75 ......所以S11也在改变。我们正在控制样品的温度(这是一个很大的瓶子,尝试持有者影响最小)并且它是相当稳定的......有什么方法或技术
2018-10-24 11:26:56
校准前S11读-7dB对吗?
,我假设)。打开机器后,没有任何SOLT校准,S11和S22读数为-6到-7 dB。两个3.5mm到N的适配器始终打开。我有一个N型短。短路时,S11和S22与开路,-6或7 dB大致相同。频率为2
2018-12-27 16:31:19
没有S参数测试装置的S11测量
称为“选项11”)。没有这些S参数测试装置,是否可以进行S11测量?有什么好处/不便?谢谢你的帮助。斯坦 以上来自于谷歌翻译 以下为原文Hi, I need to match antenna
2018-12-10 16:33:37
测量航空公司的S11和S21时的结果很奇怪
嗨,我有一个PNA E8357A,我正在使用85032A cal。套件和85055A版本。套件。我做了一个端口校准,并测量了一个短暂终止的航空公司的S11,我得到了图片2和3中的内容,然后我做了两个
2018-10-24 11:22:22
直接射频采样雷达接收器参考设计包括BOM及层图
direct RF-sampling receiver for a radar operating in HF, VHF, UHF, L-, S-, C-, and part of X-band
2018-10-15 15:11:34
MAX2170/MAX2171 DAB/T-DMB参考设计
摘要:MAX2170/MAX2171调谐器及解调IC参考设计提供了一个结构紧凑的DAB和T-DMB子卡方案。该设计可以将VHF-III和L波段的信号转
2008-08-19 12:22:121434
MAX2170, MAX2171 直接变频至低IF的调谐器,
MAX2170, MAX2171 直接变频至低IF的调谐器,用于T-DMB/DAB/FM数字无线通信
MAX2170, MAX2171 概述
MAX2170/MAX2171直接变频至低IF的调
2009-01-22 15:12:53653
MAX2170,MAX2171直接变频至低IF的调谐器用于数字音频广播
MAX2170, MAX2171 直接变频至低IF的调谐器,用于数字音频广播
MAX2170/MAX2171直接变频至低IF的调谐器设计为用于数字音频广播(DAB)和地面数字多媒体广播(T-DMB)应
2009-09-18 08:07:27956
MAX2664, MAX2665 VHF/UHF低噪声放大器
典型应用电路
The MAX2664 and MAX2665 are ultra-compact LNAs for VHF/UHF applications. These devices
2010-09-23 08:01:511197
变压器s11与s13的区别
油浸式变压器S13比S11的性能要高出很多。在主要参数中,除负载损耗参数两者一样,空载损耗和空载电流参数指标,S13都比S11要好很多。
2017-11-17 19:21:1863959
基于RFHA1027下的500W GaN Wide-Band Pulsed Power Amplifier
The RFHA1027 is a 50V 500W high power discrete amplifier designed for L-Band pulsed radar, air
2018-08-03 11:29:005
介绍MAX-HEALTH-BAND的腰带心率监护仪
shows how the MAX-HEALTH-BAND, featuring the MAX86140 AFE and MAX20303 PMIC, streams HR data
2018-10-11 04:12:003086
三星Galaxy S11将改进屏下指纹触控技术
据Sumahoinfo、91mobiles等多家媒体报道,来自韩国杂志《The Elec》的消息,三星Galaxy S11将改进的屏下指纹,检测面积增大。
2019-10-09 11:37:46753
三星S11曝光采用了Infinity-O打孔屏设计后置四摄搭载了1亿像素传感器
另外,有消息指出,三星S11将后置四摄,且将搭载1亿像素传感器,并加入5倍光学变焦摄像头。发布时间上,三星S11将有可能于2020年2月发布。
2019-10-16 11:35:25510
三星Galaxy S11延续挖孔屏方案,后置采用四摄组合设计
日前有报道称,三星Galaxy S11的研发工作已经完成。作为年度旗舰机型,三星Galaxy S11将会延续三星Galaxy S10的挖孔屏方案,同时也会对挖孔进行进一步的打磨,做到更小,更窄。
2019-10-30 15:47:022384
三星Galaxy S11系列新机有望在2月份亮相
11月4日消息,据消息报道,三星Galaxy S11系列包含Galaxy S11e、Galaxy S11和Galaxy S11+三款,它们采用Infinity-O显示屏(挖孔屏),新机有望在2月份亮相。
2019-11-04 15:35:122035
三星停止定制CPU的生产,正在开发Galaxy S11软件
据外媒报道,日前,来自XDA的Max Weinbach在推特上表示,三星已经开始开发用于美版Galaxy S11手机的软件,三个型号都支持5G网络。
2019-11-04 16:36:342721
三星Galaxy S11系列部分细节曝光,有几项重大功能升级
11月11日消息,爆料人士Ishan Agarwal得到独家消息,曝光了Galaxy S11系列的部分细节。
2019-11-12 15:12:502686
三星Galaxy S11新渲染图曝光,采用带有弧度的“瀑布屏”
刚刚,曝光了一组三星Galaxy S11的新渲染图。此次三星Galaxy S11/S11e渲染出自印度的设计师Nitish Jalota,新机或采用带有弧度的瀑布屏,前置镜头更小,后置3摄外加
2019-11-14 14:13:063018
三星Galaxy S11系列的部分细节泄露,支持8K视频录制
11月18日消息,XDA主编Max Winebach在三星最新版相机应用程序中发现了Galaxy S11系列的部分细节。
2019-11-18 16:03:592322
Galaxy S11将带来全新的Single Take和Video Spin体验
根据目前已知的信息,三星 Galaxy S11 产品线或有三款不同的机型。除了入门级的 Galaxy S11e,预计还有标准版和 Plus 版。
2019-11-22 17:55:533567
三星Galaxy S11将会采用与三星Galaxy Note 10一样的PMP电池封装技术
根据目前曝光的消息来看,三星Galaxy S11系列S11e、S11、S11+(暂定名称)的电池容量可能分别是3800~3900mAh、4300mAh以及5000mAh。
2019-11-24 10:45:031091
外媒制作三星S11全新渲染图 后置摄像头亮眼
即将于2020年2月18日发布的三星Galaxy S11无疑是接下来最重磅的机型之一,其机身参数也大致曝光,现在唯一还有神秘感的的就是S11的机身设计。
2019-12-16 08:35:042073
ADMV8913: X Band, Digitally Tunable, High-Pass and Low-Pass Filter Preliminary Data Sheet
2021-01-27 20:24:179
ADMV8052: 30 MHz to 520 MHz Digitally Tunable Band-Pass Filter Preliminary Data Sheet
2021-01-27 20:27:186
ADMV7320: E-Band Upconverter SiP, 81 GHz to 86 GHz Data Sheet
2021-01-28 00:33:3310
LTC2311-12: 12-Bit + Sign, 5Msps Differential Input ADC with Wide Input Common Mode Range Data Sheet
2021-01-28 00:43:330
ADMV8420: 10 GHz to 21.7 GHz, Tunable Band-Pass Filter Data Sheet
2021-01-28 11:31:158
ADMV8416: 6.3 GHz to 18 GHz, Tunable Band-Pass Filter Data Sheet
2021-01-31 13:19:210
VHF 和 L 波段输入的 MAX2170 S11 数据
2022-11-18 23:45:330
MAX2170 S11数据用于VHF和L波段输入
本应用笔记介绍了如何测量MAX2170三频(T-DMB、DAB、FM)接收器的输入散射参数(S11)对VHF和L波段输入的测量。
2023-01-10 10:16:55530
MAX2170/MAX2171 DAB/T-DMB数字无线电调谐器
本应用笔记分别介绍了数字音频广播和手机电视加音乐的DAB和T-DMB标准。给出了一个集成MAX2170/MAX2171调谐器的DAB/T-DMB接收器。
2023-01-10 13:53:57741
MAX2170EVKIT+ 射频评估和开发套件,开发板
电子发烧友网为你提供Maxim(Maxim)MAX2170EVKIT+相关产品参数、数据手册,更有MAX2170EVKIT+的引脚图、接线图、封装手册、中文资料、英文资料,MAX2170EVKIT+真值表,MAX2170EVKIT+管脚等资料,希望可以帮助到广大的电子工程师们。
2023-02-04 19:06:42
MAX-HEALTH-BAND 评估板 - 传感器
电子发烧友网为你提供Maxim(Maxim)MAX-HEALTH-BAND相关产品参数、数据手册,更有MAX-HEALTH-BAND的引脚图、接线图、封装手册、中文资料、英文资料,MAX-HEALTH-BAND真值表,MAX-HEALTH-BAND管脚等资料,希望可以帮助到广大的电子工程师们。
2023-02-07 18:10:14
MAX2170/MAX2171低中频调谐器用于数字音频广播(DAB)和地面数字多媒体广播(T-DMB)系统,覆盖168MHz到240MHz (VHF-III)和1452MHz到1492MHz
2023-06-12 14:55:00374
MAX98388/MAX98389: Digital Input Class-D Amplifier with IV Feedback and Brownout Protection Data Sheet MAX98388/MAX98389: Digital Input Clas
Protection Data Sheet相关产品参数、数据手册,更有MAX98388/MAX98389: Digital Input Class-D Amplifier with IV
2023-10-12 18:37:17
MAX44284: 36V, Input Common-Mode, High-Precision, Low-Power Current-Sense Amplifier Data Sheet MAX44284: 36V, Input Common-Mode, High-Precis
Amplifier Data Sheet相关产品参数、数据手册,更有MAX44284: 36V, Input Common-Mode, High-Precision, Low-Power Current-Sense
2023-10-13 18:35:03
MAX77839: 5.5V Input, 4.4A/3.6A Switching Current 6μA I<sub>Q</sub> Buck-Boost Converter Data Sheet MAX77839: 5.5V Input, 4.4A/3
; Buck-Boost Converter Data Sheet相关产品参数、数据手册,更有MAX77839: 5.5V Input, 4.4A/3.6A Switching Current
2023-10-13 18:44:28
MAX14906: Quad-Channel Industrial Digital Output, Digital Input Data Sheet MAX14906: Quad-Channel Industrial Digital Output, Digital Input D
电子发烧友网为你提供ADI(ADI)MAX14906: Quad-Channel Industrial Digital Output, Digital Input Data Sheet相关产品参数
2023-10-13 18:44:47
MAX20481: Four- to Seven-Input Automotive Power-System Monitor Family Data Sheet MAX20481: Four- to Seven-Input Automotive Power-System Moni
电子发烧友网为你提供ADI(ADI)MAX20481: Four- to Seven-Input Automotive Power-System Monitor Family Data Sheet
2023-10-13 18:57:52
MAX17220-MAX17225: 400mV to 5.5V Input, nanoPower Synchronous Boost Converter with True Shutdown Data Sheet MAX17220-MAX17225: 400mV to 5.5V
with True Shutdown Data Sheet相关产品参数、数据手册,更有MAX17220-MAX17225: 400mV to 5.5V Input, nanoPower
2023-10-16 18:40:00
MAX40213: Transimpedance Amplifiers with Selectable Gain and Input Current Clamp Data Sheet MAX40213: Transimpedance Amplifiers with Selecta
Data Sheet相关产品参数、数据手册,更有MAX40213: Transimpedance Amplifiers with Selectable Gain and Input Current
2023-10-16 18:40:19
MAX22199: Octal Industrial Digital Input Data Sheet MAX22199: Octal Industrial Digital Input Data Sheet
电子发烧友网为你提供ADI(ADI)MAX22199: Octal Industrial Digital Input Data Sheet相关产品参数、数据手册,更有MAX22199: Octal
2023-10-16 18:41:07
MAX40077-MAX40089: Single/Dual/Quad Ultra-Low Input Bias Current, Low-Noise Amplifiers Data Sheet MAX40077-MAX40089: Single/Dual/Quad Ultra-
Amplifiers Data Sheet相关产品参数、数据手册,更有MAX40077-MAX40089: Single/Dual/Quad Ultra-Low Input Bias Current
2023-10-16 18:44:23
MAX77831: 2.5V to 16V Input, 7A Switching Current High-Efficiency Buck-Boost Converter Data Sheet MAX77831: 2.5V to 16V Input, 7A Switching
Converter Data Sheet相关产品参数、数据手册,更有MAX77831: 2.5V to 16V Input, 7A Switching Current High-Efficiency
2023-10-16 18:48:58
MAX22005: 12-Channel Factory-Calibrated Configurable Industrial-Analog Input Data Sheet MAX22005: 12-Channel Factory-Calibrated Configurable
电子发烧友网为你提供ADI(ADI)MAX22005: 12-Channel Factory-Calibrated Configurable Industrial-Analog Input Data
2023-10-16 19:14:42
MAX16143-MAX16149: High-Voltage Supervisors with Manual Reset Input Data Sheet MAX16143-MAX16149: High-Voltage Supervisors with Manual Reset
电子发烧友网为你提供ADI(ADI)MAX16143-MAX16149: High-Voltage Supervisors with Manual Reset Input Data Sheet相关
2023-10-16 19:17:18
MAX17227A: 400mV to 5.5V Input, 2A nanoPower Boost Converter with Short-Circuit Protection and True Shutdown Data Sheet MAX17227A: 400mV to
Protection and True Shutdown Data Sheet相关产品参数、数据手册,更有MAX17227A: 400mV to 5.5V Input, 2A nanoPower
2023-10-16 19:28:37
MAX98395: 11.7W Digital Input Class DG Amplifier with I/V Sense and Ultra-Low Quiescent Power Data Sheet MAX98395: 11.7W Digital Input Class
Quiescent Power Data Sheet相关产品参数、数据手册,更有MAX98395: 11.7W Digital Input Class DG Amplifier with I/V Sense
2023-10-17 18:32:58
MAX77533: 14V Input, 1.5A High-Efficiency Buck Converter with 9μA I<sub>SUP</sub> Data Sheet MAX77533: 14V Input, 1.5A High-Effi
;SUP</sub> Data Sheet相关产品参数、数据手册,更有MAX77533: 14V Input, 1.5A High-Efficiency Buck Converter
2023-10-17 18:50:20
MAX98396: 20V Digital Input Class-DG Amplifier with I/V Sense and Brownout Prevention Data Sheet MAX98396: 20V Digital Input Class-DG Amplif
Prevention Data Sheet相关产品参数、数据手册,更有MAX98396: 20V Digital Input Class-DG Amplifier with I/V Sense
2023-10-17 19:12:42
MAX22195: High-Speed, Octal, Industrial Digital Input with Parallel Output Data Sheet MAX22195: High-Speed, Octal, Industrial Digital Input
电子发烧友网为你提供ADI(ADI)MAX22195: High-Speed, Octal, Industrial Digital Input with Parallel Output Data
2023-10-17 19:15:17
查看更多
