用cc5调试的时候,有时候总是曝出在low-power mode下工作?这个是为什么?谢谢前辈们指点,新手
2014-06-29 10:42:21
分享一本书:Design of low-voltage low-power CMOS operational amplifier cells
2021-06-22 07:01:47
• Low-power • Cost-effective• Shows implementation of smbuslib as Master and Slave• Uses TMP006
2015-03-23 10:02:29
Low-Power DC-DC Converter Derives 5V From 3V Battery。
2009-04-30 09:16:3214
and elegant desktop computers, and now to low-power, ultra-portable handheld devices.
With each passing generation, computers co
2009-07-20 09:31:450
Low-Power Digital Vlsi Design:An Overview:
2009-07-25 16:41:210 The MAXQ612/MAXQ622 are low-power, 16-bit MAXQ® microcontrollers designed for low-power
2010-03-03 22:26:2020 The ADS8331 is a low-power, 16-bit, 500k samples-per-second (SPS) analog-to-digital converter (ADC
2010-06-03 12:25:2126 The ADS8331 is a low-power, 16-bit, 500k samples-per-second (SPS) analog-to-digital converter (ADC
2010-06-03 12:33:4123 The TLC2551, TLC2552, and TLC2555 are a family of high performance, 12-bit, low-power, miniature
2010-06-05 16:26:4526 The PCM1870 is a low-power stereo ADC designed for portable digital audio applications
2010-06-13 10:21:2135 The PCM1870A is a low-power stereo ADC designed for portable digital audio applications
2010-06-13 10:28:5614 The TLV320ADC3001 is a low-power, stereo audio analog-to-digital converter (ADC) supporting
2010-06-13 10:45:5220 The TLV320ADC3101 is a low-power, stereo audio analog-to-digital converter (ADC) supporting
2010-06-13 10:49:2034 The TLV320AIC3110 is a low-power, highly integrated, high-performance codec which supports stereo
2010-06-25 22:49:0229 The TLV320AIC3111 is a low-power, highly integrated, high-performance codec which provides a stereo
2010-06-25 23:18:098 The TLV320AIC3120 is a low-power, highly integrated, high-performance codec which features a mono
2010-06-26 09:25:2734 The TLV320AIC36 (sometimes referred to as the AIC36) is a flexible, low-power, low-voltage stereo
2010-06-26 09:51:2527 The PCM1774 is a low-power stereo DAC designed for portable digital audio applications. The device
2010-06-26 12:18:1418 The TLV320DAC3100 is a low-power, highly integrated, high-performance stereo audio DAC with 24-bit
2010-06-26 19:55:4724 VLSI systems. Thispaper reviews several approaches for low-power implementationsof building blocks for digital subscriber line
2010-06-27 22:36:392 The CC11x1-Q1 device family is designed for very low-power wireless applications. The circuits
2010-06-29 19:54:0221 The CC11x1-Q1 device family is designed for very low-power wireless applications. The circuits
2010-06-29 19:57:4818 ) designed forminiature, ultra low-power, audio signalprocessing applications. The
2010-07-01 14:34:443 The CC2400 is a true single-chip 2.4 GHz RF transceiver designed for low-power and low
2010-07-02 12:59:5857 The AUP family is TI’s premier solution to the industry’s low-power needs in battery-powered
2010-07-17 20:11:1219 The AUP family is TI’s premier solution to the industry’s low-power needs in battery-powered
2010-07-17 20:14:1112 The AUP family is TI’s premier solution to the industry’s low-power needs in battery-powered
2010-07-17 20:15:4710 The AUP family is TI’s premier solution to the industry’s low-power needs in battery-powered
2010-07-17 20:17:3615
2010-07-29 15:35:096
2010-07-29 15:36:4512 The AUP family is TI’s premier solution to the industry’s low-power needs in battery-powered
2010-08-04 17:40:578 The AUP family is TI’s premier solution to the industry’s low-power needs in battery-powered
2010-08-06 15:09:387 The AUP family is TI’s premier solution to the industry’s low-power needs in battery-powered
2010-08-06 23:43:2626 The AUP family is TI’s premier solution to the industry’s low-power needs in battery-powered
2010-08-08 21:18:1114 The AUP family is TI’s premier solution to the industry’s low-power needs in battery-powered
2010-08-08 23:39:0715 The AUP family is TI’s premier solution to the industry’s low-power needs in battery-powered
2010-08-08 23:43:4319 The AUP family is TI’s premier solution to the industry’s low-power needs in battery-powered
2010-08-08 23:49:5820 The AUP family is TI’s premier solution to the industry’s low-power needs in battery-powered
2010-08-08 23:54:5525 The AUP family is TI’s premier solution to the industry’s low-power needs in battery-powered
2010-08-08 23:57:3222 The AUP family is TI’s premier solution to the industry’s low-power needs in battery-powered
2010-08-09 00:13:0624 The AUP family is TI’s premier solution to the industry’s low-power needs in battery-powered
2010-08-09 00:15:1823 The AUP family is TI’s premier solution to the industry’s low-power needs in battery-powered
2010-08-09 00:17:3430 The AUP family is TI’s premier solution to the industry’s low-power needs in battery-powered
2010-08-09 16:12:4612 The AUP family is TI’s premier solution to the industry’s low-power needs in battery-powered
2010-08-09 16:15:427 The AUP family is TI’s premier solution to the industry’s low-power needs in battery-powered
2010-08-09 16:24:3910 The AUP family is TI’s premier solution to the industry’s low-power needs in battery-powered
2010-08-09 16:26:2117 The AUP family is TI’s premier solution to the industry’s low-power needs in battery-powered
2010-08-09 16:28:3313 The AUP family is TI’s premier solution to the industry’s low-power needs in battery-powered
2010-08-09 16:34:3314 The AUP family is TI’s premier solution to the industry’s low-power needs in battery-powered
2010-08-09 16:38:5317 The AUP family is TI’s premier solution to the industry’s low-power needs in battery-powered
2010-08-09 16:51:0113 The AUP family is TI’s premier solution to the industry’s low-power needs in battery-powered
2010-08-09 17:05:4216 The AUP family is TI’s premier solution to the industry’s low-power needs in battery-powered
2010-08-09 17:08:5312 The AUP family is TI’s premier solution to the industry’s low-power needs in battery-powered
2010-08-09 17:14:5213 The AUP family is TI’s premier solution to the industry’s low-power needs in battery-powered
2010-08-16 16:32:1427 The AUP family is TI’s premier solution to the industry’s low-power needs in battery-powered
2010-08-16 16:35:5619 The AUP family is TI’s premier solution to the industry’s low-power needs in battery-powered
2010-08-16 16:38:3313 The AUP family is TI’s premier solution to the industry’s low-power needs in battery-powered
2010-08-16 16:40:2721 The AUP family is TI’s premier solution to the industry’s low-power needs in battery-powered
2010-08-16 16:43:3312 The AUP family is TI’s premier solution to the industry’s low-power needs in battery-powered
2010-08-16 16:46:0810 The SN75LP196 is a low-power bipolar device containing five drivers and three receivers, with 15 kV
2010-09-01 23:23:5114 The SN75LBC241 is a low-power LinBiCMOSTM line-interface device containing four independent drivers
2010-09-01 23:36:3112 The SN75C185 is a low-power BiMOS device containing three independent drivers and five receivers
2010-09-02 00:09:5311 The OPA2830 is a dual, low-power, single-supply, wideband, voltage-feedback amplifier designed
2010-09-11 20:22:2524 The OPA4830 is a quad, low-power, single-supply, wideband, voltage-feedback amplifier designed
2010-09-11 20:35:328 The OPA830 is a low-power, single-supply, wideband, voltage-feedback amplifier designed to operate
2010-09-11 20:46:0822 Fabricated using the BiCom-II process, the THS4281 is a low-power, rail-to-rail input and output
2010-09-11 21:56:2914 The THS6072 is a high-speed, low-power differential receiver designed for ADSL communication
2010-09-11 22:19:2128 The OPA2683 provides a new level of performance for dual, very low-power, wideband
2010-09-11 22:39:3513 The OPA3684 provides a new level of performance in low-power, wideband, current-feedback (CFB
2010-09-11 22:45:417 The OPA4684 provides a new level of performance in low-power, wideband, current-feedback (CFB
2010-09-11 22:55:2317 The THS6032 is a low-power line driver ideal for asymmetrical digital subscriber line (ADSL
2010-09-12 22:28:4118 extremely low-power dissipation is ideal for ADSL systems that must achieve high densities in ADSL central office rack applications. The un
2010-09-12 22:44:2324 The OPA2832 is a dual, low-power, high-speed, fixed-gain amplifier designed to operate on a single
2010-09-12 23:31:1611 The OPA3832 is a triple, low-power, high-speed, fixed-gain amplifier designed to operate
2010-09-12 23:33:1615 The OPA2684 provides a new level of performance in low-power, wideband, current-feedback (CFB
2010-09-13 00:11:1922 The devices in the TLV246x family of low-power rail-to-rail input/output operational amplifiers
2010-09-14 07:08:026 The TL022 is a dual low-power operational amplifier designed to replace higher power devices
2010-09-17 05:09:0416 the TL06x family of low-power BiFET operational amplifiers. On-chip zener trimming of offset voltage yields precision grades as low as 1
2010-09-17 05:11:3653 The LP2901 is a low-power quadruple differential comparator. The device consists of four
2010-09-23 19:08:189 The INA332 and INA2332 are rail-to-rail output, low-power CMOS instrumentation amplifiers
2010-09-24 20:53:5352 is a low-power, single-supply 2.7-V to 5-V, 3-channel integrated video buffer. It incorporates a selectable 5th order Butterworth fi
2010-09-27 19:31:3213 The TPS799xx family of low-dropout (LDO) low-power linear regulators offers excellent ac
2010-10-19 22:07:4822 The device is a Low-power applications processor based on an ARM926EJ-S™ and a C674x DSP
2010-12-12 22:42:5497 digital-to-analog converter (DAC) and comparitors to create a low cost ADC that is 0.05% linear. The simple 3V analog-to-digital
2009-05-08 10:02:13895 MAX9613, MAX9615 Low-power op amps with self-calibration minimize drift in portable instrumentation and medical applications
2010-10-07 11:25:361165 MAX44007 Low-Power Digital Ambient Light Sensor with Enhanced Sensitivity
概述
The MAX44007
2010-12-19 10:25:261199 Low-Power Narrowband FM Receiver
2011-04-11 10:54:24115 The MAX44268 is an ultra-small and low-power dualcomparator ideal for battery-powered applications
2012-01-31 10:32:0335 MSP430 MCUs, Passive RF and Low-Power RF Solutions Guide能量收集
2017-10-12 14:58:363 LTC6362/LTC5599 Demo Circuit - Low-Power I/Q Modulator Driver (Baseband Design)
2021-03-10 13:30:360 本应用笔记介绍了使用集成数模转换器(DAC)和比较器的微控制器(μC)来创建线性度为0.05%的低成本ADC。
2023-02-10 11:21:15167 电子发烧友网为你提供ADI(ADI)MAX30009: Low-Power, High-Performance Bioimpedance Analog Front-End Data Sheet相关
2023-10-13 18:42:02
电子发烧友网为你提供ADI(ADI)MAX22290-MAX22291: Reinforced, Fast, Low-Power, Two-Channel Digital Isolators
2023-10-16 18:32:51
电子发烧友网为你提供ADI(ADI)MAX32655: Low-Power, Arm Cortex-M4 Processor with FPU-Based Microcontroller
2023-10-16 18:42:40
电子发烧友网为你提供ADI(ADI)MAX40023-MAX40024: Low-Noise, Low-Power, Low-Bias-Current Amplifiers Data Sheet相关
2023-10-16 19:26:16
电子发烧友网为你提供ADI(ADI)MAX41400: Low-Power, Precision Instrumentation Amplifier with Programmable Gain
2023-10-16 19:29:54
电子发烧友网为你提供ADI(ADI)MAX32570: Low-Power Arm Cortex-M4 Microcontroller with Contactless Radio
2023-10-17 19:18:31
电子发烧友网为你提供ADI(ADI)MAX40100: Precision Low-Power and Low-Noise Op Amp with RRIO Data Sheet相关产品参数、数据
2023-11-09 10:07:01
查看更多
