电子发烧友App
硬声App
电子发烧友网>RF/无线>Designing Output-Matching Netw
收藏
查看更多
什么是output_delay?
顾名思义,output_delay就是指输出端口的数据相对于参数时钟边沿的延时。
2022-09-26 10:07:102761
28069的IQmathLib.h出现警告no matching section
[ IQmath_fpu32.lib (IQmathTablesRam) ]出现警告 no matching section,是不是因为这个警告造成_IQsin()没有正确执行呢。希望知道的可以帮我解答下这个问题
2018-08-27 10:25:31
Designing Control Loops for Linear and Switching Power Supplies
Designing Control Loops for Linear and Switching Power Supplies全英文版,超清晰,英文原版书籍。
2016-05-12 16:34:38
Designing High-Performance Video Systems with the AXI Interconnect
Designing High-Performance Video Systems with the AXI InterconnectHigh-performance video systems
2012-01-26 18:57:03
Designing RF, Analog and Digital on PCB A Unified Systems Approach (设计射频
Designing RF, Analog and Digital on PCB A Unified Systems Approach 设计射频,模拟和数字电路板的统一的系统方法
2009-10-10 12:19:49
Designing Safe VHDL State Machines with Synplify
2012-08-13 17:54:58
AD 导出Gerber时出现 legend is not interpreted until output 的解决方法
(AD)Altium Designer(DXP) 导出 Gerber 时出现legend is not interpreted until output 的标准解决方法:AD 在导出 Gerber
2020-03-27 15:38:18
ARM System Developers Guide - Designing and Optimizing System Software 体系
2015-04-23 10:22:46
C4_OUTPUT
C4_OUTPUT - I/O Modules - Crydom Inc.,
2022-11-04 17:22:44
DXP中Project » Output Jobs怎么找不到?
在学习DXP时,实例练习,原理图pcb图完成后。设置项目输出时,怎么也找不到Project » Output Jobs?很郁闷,高手指点一下!网上下的教程原文是:项目输出,如打印和输出文件,是在
2011-12-02 12:51:19
Impedance Matching Techniques for VLSI Packaging
Impedance Matching Techniques for VLSI PackagingWhy is packaging limiting performance??Inductive
2008-09-10 14:17:54
KIT0122
CURIENEURONS KIT - A NEURAL NETW
2024-03-14 21:13:28
M_OUTPUT
M_OUTPUT - I/O Modules - Crydom Inc.,
2022-11-04 17:22:44
RAM空间不足?
with .ANY selector matching Section .bss(uip.o)..\Output\test.axf: Error: L6407W: Sections of aggregate
2020-03-26 04:35:02
SIEGET45 - Low Noise Amplifier with BFP520 Transistor at 1.9 GHz
) are the outstanding features at low current IC=7mA(@VCC=2V). Consider while designing, the device shows potential
2009-05-12 14:00:34
Smith Chart Matching Network对话框设Zg=30+j*20的阻抗,在运行之后就变成了30-j*20了?
为什么Smith Chart Utility 对话框中点击Build ADS Circuit 的时候,之前在Smith Chart Matching Network对话框设Zg=30+j*20的阻抗,在运行之后就变成了30-j*20了?
2018-04-20 20:09:44
audio output express VI
求audio output express VI ,自己的labview 找不到
2017-03-26 12:34:19
filter output和filterless output有什么区别
如图所示,filter output和filterless output接口有什么区别啊。。
2014-08-11 15:21:18
labview color Matching(颜色匹配)路径问题
本帖最后由 ye斌 于 2017-8-1 17:07 编辑 在使用视觉助手生成的VI程序,color Matching(颜色匹配)这个空间只能是当时在视觉助手里指定的颜色吗?能不能修改?控件上都没有选择路径的端口。大神们,帮帮忙,一直要苦恼着....
2017-08-01 17:05:55
labview缺少analog output子模板
新手,不耻下问,问下缺少analog output子模板怎么回事?去NI官网上下载安装过 DAQmx Base, 后measurement I/O中只有DAQmx Base--->Data
2014-04-28 18:20:07
vim:warning:output is not to a terminal 解决方法
当我输入以下命令“vi /etc/httpd/conf/httpd.conf | grep localhost ”时,就出现了以下信息:“Vim: Warning: Output
2017-04-25 22:58:45
关于ADF4360-9中datasheet问题?
transformer or a 180° microstrip coupler (see the Output Matching section)。 1+1:1 transformer 是什么意思?是否可以给出该PLL接变压器的参考电路。多谢了!!!
2018-12-11 09:59:13
如何在ADS原理图中找到2.45 GHz的匹配网络?
Dear Friends, I am designing matching networks at 2.45 GHz. I am using ADS software. I want
2019-07-22 13:40:49
如何根据S参数计算sm_gamma1()或smZ1()?
如何做到这一点,请告诉我。提前致谢。 :) 以上来自于谷歌翻译 以下为原文Hi all, I am designing the conjugate matching circuit for my
2019-07-11 14:15:44
如何解决no space in execution regions问题?
debug\igpio_led_output.out: Error: L6406E: No space in execution regions with .ANY selector
2022-01-12 07:30:16
编译出现warning:no matching section -l rts2800_XXXXX.lib<bootXXX.obj>(.text)如何解决
(.text) } > FLASHH PAGE = 0但当我们更换编译器或者CCS 版本时,经常会碰到编译时出现如下 warning:no matching section-l
2022-11-08 07:37:46
请问Output Voltage Range和Output Saturation Voltage有什么关系?
大家好,你们好: 好吧,刚才有这个疑惑,但是仔细看了看,明白怎么回事了,写出来分享一下。 我在阅读AD8007的datasheet时,想查看AD8007的输出电压范围,也就是Output
2023-11-20 08:14:25
通过教程安装RTOS之后编译报错如何解决?
: No space in execution regions with .ANY selector matching board.o(.bss.rt_heap). .\\\\Output\\\\Debug
2023-09-03 09:42:46
MAX2831/MAX2832 pdf datasheet
The biascurrent and output-matching network for the two-stage PA have been optimized to nominally deliver +18.5dBmwhile consuming 2
2008-08-11 08:47:3014
IC Package Impedance Matching
Impedance Matching Techniques for VLSI Packaging Problem Statement•Reflections from
2008-09-10 14:16:4113
Designing with 1.5-V Devices
Designing with 1.5-V Devices The Cyclone® FPGA family provides the best solution
2009-05-14 10:46:0315
Designing a 33MHz, 32-Bit PCI
Designing a 33MHz, 32-Bit PCI Target Using ispMACH Devices The evolution of digital systems over
2009-05-14 11:02:3421
Designing a High Performance S
Designing a High Performance SDRAM Controller Using ispMACH Devices Synchronous DRAMs have become
2009-05-14 11:03:4228
利用HA5024设计的视频多路复用器减少了信号失真
, such as matching the inputline impedance, signal amplification, signal switching, anddriving the output line, without degrading or adding
2009-06-05 14:26:1619
2009-06-14 08:47:1960
2009-06-14 08:55:3124
1.6W Dual Output Flyback Conve
1.6W Dual Output Flyback Converter using LNK304P:This document is an engineering prototype report
2009-06-28 22:38:4017
High Efficiency, Dual Output B
output voltages without the needfor a transformer. Typical applications include metering power supplies,where a 3.3 V supply is r
2009-06-28 22:40:2413
48W 2 Output Power Supply usin
48W 2 Output Power Supply using TOP246Y:This document is an engineering report describing
2009-07-01 00:20:3532
Designing Boards with Atmel AT
Designing Boards with Atmel AT89C51, AT89C52, AT89C1051, and AT89C2051 for Writing Flash
2009-09-18 09:30:2625
AD9752,pdf datasheet (TxDAC D/
output impedance.Differential current outputs are provided to support singleendedor differential applications. Matching between
2009-09-21 10:04:2011
LP5524,pdf datasheet (Parallel
with a total output currentof 100mA. Regulated high side internal current sources deliverexcellent current and brightness matching
2009-09-30 09:47:4910
Designing auto power systems w
Designing auto power systems with ultracapacitors:Over the last decade, advances in materials
2009-10-01 18:42:2312
平衡的叠层设计(Designing Balanced Pri
平衡的叠层设计(Designing Balanced Printed Circuit Boards):Designers can be tempted to design printed
2009-10-16 00:09:410
LC Filter Design
Designing a single-stage filter is straightforward. The inductoris selected to give about 20
2009-10-17 10:00:0424
Designing the Power Train of a
Designing the Power Train of a 200W Power Supply with PFC:Design Issues•System
2009-11-26 11:08:244
This document is an engineering report describing a prototype 2 output universal inputpower supply
2010-01-07 09:22:1118
Voltage-Output DAC
Voltage-Output DAC GENERAL DESCRIPTIONThe AD5532 is a 32-channel voltage-output 14-bit DAC withan
2010-04-07 10:23:4617
NCP5623 Triple Output I2C Cont
NCP5623 Triple Output I2C Controlled RGB LED Driver The NCP5623 mixed analog circuit is a triple
2010-04-19 14:10:0832
The third generation non-isola
Outline• Selecting the right POL Module– T-LynxTM and Naos RaptorTM series• Designing
2010-06-30 19:34:4316
Multi-Output Flyback Off-Line
Basic ConceptR26; Outputs can be positive or negative depending on which side ofthe output (top or bottom) is grounded.
2010-07-30 10:14:5011
Agilent E3631A Triple Output D
The Agilent E3631A is a high performance 80 watt-triple output DC power  supply with GPIB
2010-08-20 11:47:5536
THS9000,pdf(50 MHz to 400 MHz
The amplifier incorporates internal impedance matching to 50 Ω. The part mounted on the standard EVM achieves greater than 15-dB input and output
2010-09-27 19:17:325
TPS61150A,pdf(DUAL OUTPUT BOOS
WLEDs. Each current output can be individually programmed through external resistors. There is dedicated selection pin for each output, so
2010-10-02 00:51:5011
PTB48500A,pdf(Dual-Output, 48-
The PTB4850x power modules are a dual-output isolated DC/DC converter, designed to provide
2010-11-12 14:37:248
PTB48501A,pdf(Dual-Output, 48-
2010-11-12 14:44:5410
PTB48502A,pdf(Dual-Output, 48-
2010-11-12 14:46:3813
Input and Output Capacitor Sel
ABSTRACTWhen designing with switching regulators, application requirements determine howmuch input
2010-11-16 17:05:4536
PT6947,pdf(6-A Dual Output 5-V
The PT6940 Excalibur™ power modules are a series of high-efficiency dual-output regulators
2010-11-16 21:41:006
PT6946,pdf(6-A Dual Output 5-V
2010-11-16 21:44:136
PT6944,pdf(6-A Dual Output 5-V
2010-11-16 22:44:1710
Dual, Voltage-Output DAC Consu
Dual, Voltage-Output DAC Consumes Miniscule Power The dual, voltage-output DACs shown
2008-11-24 10:19:58882
Designing the DS2726 to Protec
Designing the DS2726 to Protect Li+ Batteries During a Reverse Charger Event Abstract:
2008-12-18 10:05:47800
2008-12-20 12:46:351005
MAX15034 Dual-Output, Synchron
MAX15034 Dual-Output, Synchronous Step-Down Controller Provides Two 25A Outputs or a Single 50A
2009-01-11 11:38:24844
MAX15023 Dual-Output, Synchron
MAX15023 Dual-Output, Synchronous DC-DC Controller with Wide Operating Range Delivers Up to 25A
2009-01-28 15:00:30954
设计一个200×16非易失性内存子系统-Designing
Abstract: When designing microprocessor cards and memory subsystems cards for backplane-based
2009-04-24 09:53:22885
PWM Sets Output of LCD/LED Dri
Abstract: The digital, pulse-width-modulation (PWM) output available from many microprocessors
2009-04-26 16:50:55817
Class D Audio Amplifier Output
Abstract: This application note examines the effect of the output filter on audio Class D amplifier
2009-05-06 11:59:231450
设计基于LED的视频显示板,Designing an LED
设计基于LED的视频显示板 Designing an LED-Based Video-Display Board Abstract: Currently, all of the top LED
2009-07-18 11:12:251631
Adjusting the output voltages
Adjusting the output voltages of the MAX8660/MAX8661 Abstract: The MAX8660/MAX8661 PMICs (power management ICs) have the most common output v
2009-12-26 00:02:26620
简单的多输出范围16位DAC设计
in industrialprocess control equipment, analytical and scientificinstruments and automatic test equipment. In the past,designing a universal output modu
2012-02-03 15:55:2756
东芝光耦 MOSFET Output
东芝光耦 MOSFET Output,Photorelays (MOSFET Output)
2012-03-16 13:44:59579
Matching阻抗匹配计算软件(dos)
电子发烧友网站提供《Matching阻抗匹配计算软件(dos).exe》资料免费下载
2014-06-12 16:32:1410
Designing_Low-cost,Multiple_Output_DC-DC_Converters
DC TO DC INVERTER 詳細介紹 歡迎免費下載
2016-01-11 14:48:3325
Designing with a New Super Fast
Designing with a New Super Fast Dual Norton Amplifier
2017-03-24 15:48:300
Designing High Speed Active Filt
Designing High Speed Active Filters
2017-03-24 15:32:380
使用CALIBRE PATTERN MATCHING的复杂器件验证
不符,并影响硅片上的性能。相比之下,采用Calibre@ Pattern MatcHing方法更为合理,其代码可轻松编写到SVRF中,验证器件版图并通过与图形交互输出不匹配的形状。
2018-03-05 15:16:3815
使用CALIBRE PATTERN MATCHING进行DFM线末端强化
为设计增加线末端延长量是一种提高良率和可靠性的简单方法。但是,将这些强化技术编码到物理验证规则集中则需要专家级的代码编写能力,并会加重未来改进规则集的支持负担。使用Calibre Pattern Matching功能以图形方式识别合规区域可降低所需的编码专业水平,并可在增加额外标准时轻松更新。
2018-03-06 16:16:325
使用 RPi.GPIO 模块的输出(Output)功能
, GPIO.OUT)2、设置某个输出针脚状态为高电平:12345GPIO.output(12, GPIO.HIGH) # 或者GPIO.output(12, 1) # 或者GPIO.output
2019-04-02 14:42:37749
LTspice AD5679R-LTC3307B Power supply output margining
2021-01-27 22:14:251
SCP-OUTPUT-EVALZ SCP-OUTPUT-EVALZ评估板
电子发烧友网为你提供ADI(ti)SCP-OUTPUT-EVALZ相关产品参数、数据手册,更有SCP-OUTPUT-EVALZ的引脚图、接线图、封装手册、中文资料、英文资料,SCP-OUTPUT-EVALZ真值表,SCP-OUTPUT-EVALZ管脚等资料,希望可以帮助到广大的电子工程师们。
2021-07-09 21:00:04
N7DCC Matching 1.8到50MHz频段的天线设备
电子发烧友网站提供《N7DCC Matching 1.8到50MHz频段的天线设备.zip》资料免费下载
2022-07-22 15:18:132
如何通过Output Job输出原理图变量
Output Job中选择[Project Physical Documents],将会显示编译后的原理图图纸,其中包含图纸上不同的变量元素。
2022-09-08 11:20:46615
编译时出现warning:no matching section -l rts2800_XXXXX.lib<bootXXX.obj>(.text)的解决方案
编译时出现warning:no matching section -l rts2800_XXXXX.lib(.text)的解决方案
2022-10-31 08:23:310
Virtual Input/Output IP核的几个重要参数
大家好!今日给大家介绍下Virtual Input/Output IP 核的几个重要参数。
2023-06-01 09:18:32737
聊聊不一样的衰减器Matching PAD
相对于电感、电容构成的阻抗匹配网络而言,Matching PAD具有更平坦的幅频响应、更好的阻抗匹配效果,广泛应用于广播、电视信号测试系统。
2023-06-12 10:25:56555
Evaluation Kit for MAXM17572 in 5V Output Application Data Sheet Evaluation Kit for MAXM17572 in 5V Output Application Data Sheet
电子发烧友网为你提供ADI(ADI)Evaluation Kit for MAXM17572 in 5V Output Application Data Sheet相关产品参数、数据手册,更有
2023-10-12 18:50:51
HMC955: 32 Gbps, 1:2 Demux with Programmable Output Voltage Data Sheet HMC955: 32 Gbps, 1:2 Demux with Programmable Output Voltage Data Shee
电子发烧友网为你提供ADI(ADI)HMC955: 32 Gbps, 1:2 Demux with Programmable Output Voltage Data Sheet相关产品参数、数据手册
2023-10-13 18:32:14
HMC954: 32 Gbps, 2:1 Mux with Programmable Output Voltage Data Sheet HMC954: 32 Gbps, 2:1 Mux with Programmable Output Voltage Data Sheet
电子发烧友网为你提供ADI(ADI)HMC954: 32 Gbps, 2:1 Mux with Programmable Output Voltage Data Sheet相关产品参数、数据手册
2023-10-13 18:32:27
MAX25250: Four Output Mini PMIC for Camera Applications Data Sheet MAX25250: Four Output Mini PMIC for Camera Applications Data Sheet
电子发烧友网为你提供ADI(ADI)MAX25250: Four Output Mini PMIC for Camera Applications Data Sheet相关产品参数、数据手册,更有
2023-10-17 18:51:43
功放output接口有什么作用
功放(Power Amplifier)的output接口是指功放器件输出信号的端口,用于连接音箱或扬声器等音频设备。功放的output接口具有以下作用: 功率输出:功放的主要功能是将低功率的音频
2024-02-23 10:32:04358
功放机OUTPUT是什么接口
功放机是音频系统中不可或缺的组成部分。作为信号处理与扩大音频信号的设备,功放机的OUTPUT接口在连接音频信号与外部设备之间起到了桥梁的作用。本文将详细介绍功放机的OUTPUT接口的类型、功能
2024-02-23 10:34:001026
output1和output2有什么区别
在计算机科学领域,输出被认为是一个程序或系统产生的结果。output1和output2是两个常见的输出标识,它们在不同的上下文中具有不同的含义和用途。 output1的定义和用途 output1通常
2024-02-23 13:45:03184
output函数怎么用
output 函数是一个通用的术语,并不特指某个具体的编程语言或软件工具。 如果你在使用 Python 编程语言,那么可能是指 print 函数。Python 中的 print 函数用于将指定的内容
2024-02-23 14:21:16183
已全部加载完成
