74ALVC16839 - Low Voltage 20-Bit Selectable Register/Buffer with 3.6V Tolerant Inputs and Outputs - Fairchild Semiconductor
2022-11-04 17:22:44
74VCX16839 - Low Voltage 20-Bit Selectable Register/Buffer with 3.6V Tolerant Inputs and Outputs - Fairchild Semiconductor
2022-11-04 17:22:44
special EMI filters for suppression.The high voltage linear regulator is simple indesign, cheap
2009-05-12 11:01:35
High Power LED封装尺寸及参数说明产品说明:ChipMaterial:GaNEmitted Color:Super Blueλσ(nm):470Lens Color:Water
2008-09-28 17:55:06
Linear LT3760 8路LED驱动方案
2019-03-18 11:30:27
Linear拥有30年的模拟工程优势
2019-05-20 09:59:19
本人从事煤矿产品的研发与设计工作,在电路设计中用到的电源芯片很多,但Linear的电源管理芯片LT1641-2I和镍氢/镍镉电池充电管理芯片LTC4011使用,让我对Linear产品的品质产生了信心
2018-07-27 06:38:02
MAX16839_11 - High-Voltage, Linear High-Brightness LED Driver with Open-LED Fault Detect - Maxim Integrated Products
2022-11-04 17:22:44
Designing Control Loops for Linear and Switching Power Supplies全英文版,超清晰,英文原版书籍。
2016-05-12 16:34:38
IntroductionAs the complexity of sophisticated, modern day equipmentgrows, the need for high
2009-05-12 11:13:19
Devices High-Temperature Applications Military/DoD and Aerospace Toys 图1.MAX17710应用示意图图2.MAX17710应用框图图3.
2015-04-23 11:19:52
吴恩达机器学习-手写笔记三 - Multivariate Linear Regression 多变量线性回归
2020-06-11 17:02:50
正式接触Power By Linear产品是在研究生期间。研究生入学第一天,来到实验室老师就扔给我一包器件(LT3029)让我测试验证,以前从来没用过Linear的器件,所以一时间很蒙圈。然后根据
2018-11-01 10:43:12
请问Linear Lab Tool具体是做什么的呢?
2024-01-05 12:52:00
请高手指点TEK示波器测试波形电压时:High,Low,Max,Min的区别,主要是High和Low的意义???
2012-07-30 20:48:16
概述:MAX16839可编程电流调节器工作在5V至40V输入电压范围,具有漏极开路、恒定吸电流输出,可提供100mA输出驱动。MAX16839非常适合汽车应用以及需要通用线性LED驱动器的应用。该
2021-05-17 06:03:47
The MAX1792 low-dropout linear regulator operates from a +2.5V to +5.5V supply and delivers
2008-08-20 12:20:2019 The MAX038 is a high-frequency, precision functiongenerator producing accurate, high
2008-10-24 10:28:5443 The MAX8704 high-current linear regulator uses anexternal n-channel MOSFET to generate
2008-10-24 13:56:167 The MAX5427/MAX5428/MAX5429 linear-taper digitalpotentiometers function as mechanical
2008-11-19 10:24:3021 The MAX9610 high-side current-sense amplifier offers precision accuracy specifications of VOS less
2008-12-02 23:11:0610 The MAX4806/MAX4807/MAX4808 integrated circuits generate high-voltage, high-frequency, unipolar
2008-12-02 23:48:5924 The MAX5087 high-voltage linear regulator operatesfrom an input voltage of 6.5V to 45V and delivers
2009-01-06 14:41:2031 The MAX1886 is a high-current operational transconductanceamplifier. The MAX1886 is ideal
2009-01-11 11:04:235 transistor liquidcrystal displays (TFT LCDs). It combines a high-performancestep-up regulator with two linear-regulator controllers
2009-01-11 11:13:0016 liquid-crystal displays(TFT LCDs). Both combine a high-performance step-upregulator with two linear-regulator controllers, input protectio
2009-01-11 11:14:5919 The MAX1516A/MAX1517A/MAX1518A include a highperformancestep-up regulator, two linear
2009-01-11 11:17:2912 The MAX8795A includes a high-performance step-upregulator, two linear-regulator controllers
2009-01-11 11:21:45118 2531/MAX2537/MAX2538/MAX2539 implement multiple LNA and mixer states, including high gain/high linearity, high gain/low linearity, mid gain, low g
2009-02-16 15:38:516 The MAX17103 includes a high-performance step-up regulator, a 350mA low-dropout linear regulator
2009-02-25 19:48:2532 The MAX13041 ±80V fault-protected, high-speed controllerarea network (CAN) transceiver is ideal
2009-06-19 07:40:1096 The MAX3806 is a high-gain linear preamplifier for distance measurement applications using a laser
2009-07-18 17:54:1940 The MAX16910 ultra-low quiescent current, high-voltage linear regulator is ideal for use
2009-08-21 09:52:1915 to a total of350mA to one or more strings of high-brightness LEDs(HB LEDs). The output current of the MAX16803 isadjusted by usin
2009-09-18 08:42:2326 The MAX8922L linear battery charger safely charges a single-cell lithium-ion (Li+) battery.
2009-11-16 18:07:0023 The MAX4885AE integrates high-bandwidth analog switches, level-translating buffers
2009-11-16 18:20:0227 for a variety of portable devices including cellular handsets. The PMICs include a high-efficiency step-down DC-DC converter, five low-dropout linear
2009-12-26 10:06:2732 The MAX15054 is a high-side, n-channel MOSFET driver for high-voltage applications capable
2010-01-28 08:41:1832 , dual fixed output Quick-PWM™ step-down controllers, and dual keep-alive linear regulators:
Charger: The high-frequency (
2010-02-21 09:50:2650 The RF3267 is a high-power, high-efficiency, linear PA module designed for use asthe final RF
2010-03-03 10:34:1316 AIC1748 datasheet,pdf(High PSRR, 600mA Linear Regulator With Bypass Pin)
A low noise, high PSRR
2010-03-22 17:51:3741 The MAX17117 includes a high-performance step-up regulator, a 350mA low-dropout (LDO) linear
2010-05-20 08:45:1335 The PCM4220 is a high-performance, two-channel analog-to-digital (A/D) converter designed for use
2010-06-13 10:38:2422 The MAX98500 is a high-efficiency Class D audio amplifier that features an integrated boost
2010-06-15 08:48:5241 The MAX11102/MAX11103/MAX11105/MAX11106/MAX11110 MAX11111/MAX11115–MAX11117 are 12-/10-/8-bit
2010-07-05 08:22:4628 The MAX11102/MAX11103/MAX11105/MAX11106/MAX11110 MAX11111/MAX11115–MAX11117 are 12-/10-/8-bit
2010-07-05 08:23:3024 The MAX11102/MAX11103/MAX11105/MAX11106/MAX11110 MAX11111/MAX11115–MAX11117 are 12-/10-/8-bit
2010-07-05 08:25:2410 to 350mA toone or more strings of high-brightness LEDs (HB LEDs).The output current of the MAX16804 is set by using anexternal
2010-07-20 08:09:5131 The MAX11209/MAX11211 are ultra-low-power (< 300µA active current) high-resolution serial-output
2010-08-22 10:13:2719 The THS3091 and THS3095 are high-voltage, low-distortion, high-speed, current-feedback amplifiers
2010-09-11 23:20:4679 The THS3092 and THS3096 are dual high-voltage, low-distortion, high speed, current-feedback
2010-09-11 23:25:5427 MAX17108 10-Channel High-Voltage Scan Driver and VCOM Amplifier for TFT LCD Panels
Description
2009-02-02 16:03:131116 MAX1709 4A, Low-Noise, High-Frequency, Step-Up DC-DC Converter
MAX1709 Description
The MAX
2009-02-08 19:12:271149 MAX17103 集成PMIC,用于笔记本电脑LCD板
2009-02-25 19:49:46657
Pots, Pans, Logs, and Linear Digital Pots Create Arbitrary Voltage Curves
2009-04-16 16:07:401623 of the MAX5195 high-speed digital-to-analog converter (DAC) to design a reliab
2009-04-16 16:36:03742 of the MAX5195 high-speed digital-to-analog converter (DAC) to design a reliable resistor network for interface this LVPECL-based high-speed DAC to
2009-04-25 10:08:30824 of the MAX5195 high-speed digital-to-analog converter (DAC) to design a reliable resistor network for interface this LVPECL-based high-speed DAC to
2009-05-01 11:06:44527 of the MAX5195 high-speed digital-to-analog converter (DAC) to design a reliable resistor network for interface this LVPECL-based high-speed DAC to
2009-05-08 10:41:03701 MAX17094 内置开关的boost调节器,集成7通道驱动器、VCOM校准、运算放大器和LDO
The MAX17094 includes a high-performance step-up regulator, a 250mA low-dropout (LDO) linear regulat
2009-06-19 08:03:05752 MAX5965A, MAX5965B High-performance, monolithic quad PSE controller enables IEEE 802.3at (PoE+) applications
The MAX5965 meets IE
2009-08-11 11:56:411227 MAX16910 200mA、超低静态电流、汽车线性稳压器
概述
The MAX16910 ultra-low quiescent current, high-voltage linear regulator is ideal for use in automotive and ba
2009-08-21 09:53:40695 Reference Design for a High-Input-Voltage, High-Output-Current Buck Controller Using the MAX
2009-11-08 17:43:051130 MAX16839 High-input-voltage, linear 100mA HB LED driver provides fault output and multichip interoperability for automotive lighting
2009-12-10 12:46:53730 MAX16839 高压、高亮度LED线性驱动器,具有LED开路故障检测
概述
The MAX16839 programmable current regulator operates from a 5V to 40V input voltage range and fe
2009-12-10 12:48:05783 Maxim推出汽车级的高亮度LED驱动器
Maxim推出能够提供100mA电流的低成本、高输入电压、HB (高亮度) LED线性驱动器MAX16839。器件集成调整管和故障检测功能,极大地减少了
2009-12-28 08:39:31806 MAX15054 New high-side FET driver simplifies the design of buck and buck-boost HB LED drivers
2010-01-28 08:39:021324 Linear Technology Corporation推出同步降压型DC/DC控制器LT3845
加利福尼亚州米尔皮塔斯 (MILPITAS, CA) – 2010 年 2 月 2 日 – 凌力尔特公司 (Linear Technology Corporati
2010-02-03 10:11:33845 MAX16839可编程电流调节器工作在5V至40V输入电压范围,具有漏极开路、恒定吸电流输出,可提供100mA输出驱动。
2011-01-12 11:11:56594 The MAX14811 integrated circuit generates high-voltage, high-frequency unipolar or bipolar pulses
2011-02-06 10:36:4681 The MAX98307/MAX98308 fully differential mono Class DG multilevel power amplifiers with integrated
2011-09-02 10:22:3613 The MAX9643 is a high-speed 60V precision unidirectionalcurrent-sense amplifier ideal for a wide
2011-09-26 11:58:5912 In predominantly digital systems it is often necessaryto include linear circuit functions.
2011-12-30 14:25:5923 The MAX15101 is a small, low-dropout linear regulatoroptimized for networking, datacom, and server
2012-01-17 16:59:2231 The MAX17601MAX17605 devices are high-speedMOSFET drivers capable of sinking /sourcing 4A
2012-01-31 10:29:5751 The MAX16948 is a dual high-voltage, current-sensing lowdropout linear regulator (LDO)/switch
2012-04-26 11:52:4134 with anauxiliary digital input and two linear regulators. High portcount IO-Link master applications are supported throughin-band SPI addressi
2012-06-08 14:45:2339 The MAX1963A/MAX1976A low-dropout linear regulatorsoperate from a +1.62V to +3.6V supply
2012-07-04 13:49:5815 The MAX11329MAX11332 are 12-/10-bit with externalreference and 500kHz, full-linear
2012-07-04 13:52:0430 The MAX11321MAX11328 are 12-/10-bit with externalreference and 500kHz, full-linear
2012-10-08 17:05:0028 The MAX11335MAX11340 are 12-/10-bit with externalreference and 500kHz, full-linear
2012-10-08 17:06:1726 SM2087 high power factor linear constant current LED driver ic.SM2087 is a high power factor linear
2015-12-15 11:50:389 , but are rather inconvenient in use due to the reverse reading scale which is also non-linear. This can
2016-07-12 15:14:020 LT3045 Demo Circuit - Low Noise, High PSRR RF Linear Regulator (3.8-20V to 3.3V @ 500mA)
2021-02-20 13:58:2617 电子发烧友网为你提供Maxim(Maxim)MAX16839EVKIT+相关产品参数、数据手册,更有MAX16839EVKIT+的引脚图、接线图、封装手册、中文资料、英文资料,MAX16839EVKIT+真值表,MAX16839EVKIT+管脚等资料,希望可以帮助到广大的电子工程师们。
2023-02-06 19:42:02
电子发烧友网为你提供ADI(ADI)MAX17525: High-Accuracy, Adjustable Power Limiter Data Sheet相关产品参数、数据手册,更有
2023-10-13 18:34:51
电子发烧友网为你提供ADI(ADI)MAX30009: Low-Power, High-Performance Bioimpedance Analog Front-End Data Sheet相关
2023-10-13 18:42:02
电子发烧友网为你提供ADI(ADI)MAX16895-MAX16899: Ultra-Small, High Accuracy, Adjustable Sequencing/Supervisory
2023-10-13 19:02:07
电子发烧友网为你提供ADI(ADI)MAX25210: Automotive Ultra Low Quiescent Current Linear Regulator Family Data
2023-10-13 19:06:02
电子发烧友网为你提供ADI(ADI)MAX17291B: High-Voltage Micropower Boost Converter Data Sheet相关产品参数、数据手册,更有
2023-10-13 19:16:05
电子发烧友网为你提供ADI(ADI)MAX16191: Ultra-High, 0.35% Accuracy Supervisory Circuit Data Sheet相关产品参数、数据手册,更有
2023-10-16 18:50:34
电子发烧友网为你提供ADI(ADI)MAX25608: Twelve Switch High Brightness LED Matrix Manager for Automotive Front
2023-10-16 18:52:53
电子发烧友网为你提供ADI(ADI)MAX49921: 0 to 70V, High-Precision Current-Sense Amplifier Data Sheet相关产品参数、数据手册
2023-10-16 18:57:04
电子发烧友网为你提供ADI(ADI)MAX20459: Automotive High-Current Step-Down Converter with USB-C Dedicated
2023-10-16 19:16:20
电子发烧友网为你提供ADI(ADI)MAX16143-MAX16149: High-Voltage Supervisors with Manual Reset Input Data Sheet相关
2023-10-16 19:17:18
电子发烧友网为你提供ADI(ADI)MAX22195: High-Speed, Octal, Industrial Digital Input with Parallel Output Data
2023-10-17 19:15:17
电子发烧友网为你提供ADI(ADI)MAX20429: Dual 6A High-Efficiency Low Voltage Buck Converter Data Sheet相关产品参数、数据
2023-10-17 19:19:34
查看更多
