电子发烧友App
硬声App
电子发烧友网>光电显示>显示光电>Cypress CY8CLED04D0x PowerPSoC
收藏
查看更多
CY3250-LED04QFN
ICE POD DEBUG CY8CLED04
2023-03-30 12:08:19
CY8C4247_LQI-483的SCB SPI的数据写入问题
CY8C4247LQ-43上,我观察到CyPress SPI模块的不同行为。我使用主模式和子模式摩托罗拉,SCLK模式CPHA=0,CPOL=0,过采样=8,RX/TX数据位=8,MSB第一,SS
2018-11-23 16:31:26
CY8C5588AXI-060 UNASSIGNED:所选的调试目标与项目选定的设备不兼容
'CY8C5588AXI-060 ES1'. (Programming of the cypress demo board works flawless, although it's exactly the same
2019-04-02 14:17:24
CY8CMBR3116芯片初始化
0000); //FSS_ENEEWrite_Cy8cmbr3116(0x1d,0x000c); //BOTTON_HYSEEWrite_Cy8cmbr3116(0x1f,0x0032); //BOTTON_LBREEWrite_Cy8
2015-09-16 11:13:39
CY8CPLC20在CY3273上没有写入ISSP
你好,首先对不起我的英语,抱歉如果这是在一个错误的地方。我尝试我的开发工具包CY3255(HTTP://www. CyPress)COM/?RID=38059)与CY3173板(HTTP
2019-02-21 07:54:12
CY8C6247BZI-D54设备和CY8CKIT-062-WiFi-BT板设计文件
1)CY8C6247BZI-D54—当这部分将处于生产释放阶段?2)用于CY8CKIT-062-WiFi-BT的PCB设计文件(ALTIN)是否可用于开发商业产品?以上来自于百度翻译 以下为原文1
2018-08-18 03:53:08
CY8CLED04
CY8CLED04 - EZ-Color HB LED Controller Visual embedded design Binning compensation - Cypress Semiconductor
2022-11-04 17:22:44
CY8CLED04D01
CY8CLED04D01 - PowerPSoC Intelligent LED Driver - Cypress Semiconductor
2022-11-04 17:22:44
CY8CLED04D01-56LTXI
CY8CLED04D01-56LTXI - PowerPSoC Intelligent LED Driver - Cypress Semiconductor
2022-11-04 17:22:44
CY8CLED04D01_11
CY8CLED04D01_11 - PowerPSoC® Intelligent LED Driver - Cypress Semiconductor
2022-11-04 17:22:44
CY8CLED04D01_1105
CY8CLED04D01_1105 - PowerPSoC Intelligent LED Driver floating load buck-boost, and boost - Cypress Semiconductor
2022-11-04 17:22:44
CY8CLED04D02
CY8CLED04D02 - PowerPSoC® Intelligent LED Driver - Cypress Semiconductor
2022-11-04 17:22:44
CY8CLED04D02-56LTXI
CY8CLED04D02-56LTXI - PowerPSoC Intelligent LED Driver - Cypress Semiconductor
2022-11-04 17:22:44
CY8CLED04DOCD1-56LTXI
CY8CLED04DOCD1-56LTXI - PowerPSoC Intelligent LED Driver - Cypress Semiconductor
2022-11-04 17:22:44
CY8CLED04G01
CY8CLED04G01 - PowerPSoC Intelligent LED Driver - Cypress Semiconductor
2022-11-04 17:22:44
CY8CLED04G01-56LTXI
CY8CLED04G01-56LTXI - PowerPSoC Intelligent LED Driver - Cypress Semiconductor
2022-11-04 17:22:44
CY8CLED01D01
CY8CLED01D01 - PowerPSoC® Intelligent LED Driver - Cypress Semiconductor
2022-11-04 17:22:44
CY8CLED01D01-56LTXI
CY8CLED01D01-56LTXI - PowerPSoC Intelligent LED Driver - Cypress Semiconductor
2022-11-04 17:22:44
CY8CLED01D01-56LTXQ
CY8CLED01D01-56LTXQ - PowerPSoC® Intelligent LED Driver - Cypress Semiconductor
2022-11-04 17:22:44
CY8CLED02
CY8CLED02 - EZ-Color™ HB LED Controller Binning compensation - Cypress Semiconductor
2022-11-04 17:22:44
CY8CLED02D01
CY8CLED02D01 - PowerPSoC Intelligent LED Driver - Cypress Semiconductor
2022-11-04 17:22:44
CY8CLED02D01-56LTXI
CY8CLED02D01-56LTXI - PowerPSoC Intelligent LED Driver - Cypress Semiconductor
2022-11-04 17:22:44
CY8CLED03D01
CY8CLED03D01 - PowerPSoC Intelligent LED Driver - Cypress Semiconductor
2022-11-04 17:22:44
CY8CLED03D01-56LTXI
CY8CLED03D01-56LTXI - PowerPSoC® Intelligent LED Driver - Cypress Semiconductor
2022-11-04 17:22:44
CY8CLED03D02
CY8CLED03D02 - PowerPSoC Intelligent LED Driver - Cypress Semiconductor
2022-11-04 17:22:44
CY8CLED03D02-56LTXI
CY8CLED03D02-56LTXI - PowerPSoC® Intelligent LED Driver - Cypress Semiconductor
2022-11-04 17:22:44
CY8CLED03G01
CY8CLED03G01 - PowerPSoC Intelligent LED Driver - Cypress Semiconductor
2022-11-04 17:22:44
CY8CLED03G01-56LTXI
CY8CLED03G01-56LTXI - PowerPSoC Intelligent LED Driver - Cypress Semiconductor
2022-11-04 17:22:44
CY8CLED08
CY8CLED08 - EZ-Color™ HB LED Controller - Cypress Semiconductor
2022-11-04 17:22:44
CY8CLED08_10
CY8CLED08_10 - EZ-Color™ HB LED Controller - Cypress Semiconductor
2022-11-04 17:22:44
CY8CLED08_11
CY8CLED08_11 - EZ-Color™ HB LED Controller Binning compensation - Cypress Semiconductor
2022-11-04 17:22:44
CY8CLED16
CY8CLED16 - EZ-Color™ HB-LED Controller - Cypress Semiconductor
2022-11-04 17:22:44
CY8CLED16P01
CY8CLED16P01 - Powerline Communication Solution Integrated Powerline Modem PHY - Cypress Semiconductor
2022-11-04 17:22:44
CY8CLED16P01-OCD
CY8CLED16P01-OCD - Powerline Communication Solution Integrated Powerline Modem PHY - Cypress Semiconductor
2022-11-04 17:22:44
CY8CLED16_1106
CY8CLED16_1106 - EZ-Color HB LED Controller Visual embedded design Binning compensation - Cypress Semiconductor
2022-11-04 17:22:44
CY3686开发板帮助
尊敬的先生/女士,我最近购买了NX2LP Flex开发板(它附带了一个单独的CY364板与FX2LP芯片的开发目的),并有问题的开始。我在英特尔i7电脑上运行Windows 7 x64。我开始按照
2019-04-23 11:14:18
CY7C68013A ISO实时传输失败
2是否支持ISO OUT 传输? CY7C68013A 端点2 ISO OUT 应该如果去配置?谢谢!以下为修改后的参数:配置如下:EP1OUTCFG = 0xA0;EP1INCFG = 0xA0
2017-02-22 14:00:08
CYPRESS MCU CY8C5888FNI-LP214是否支持温度与供电电压监控?
CYPRESS MCU CY8C5888FNI-LP214是否支持温度与供电电压监控?如果支持,如何实现?谢谢。
2024-02-21 07:57:13
CYPRESS公司的CY4623开发板的全套设计材料
CYPRESS公司的CY4623开发板的全套设计材料,是学习CY系列的好资料。该板子的功能为实现与PC的USB通讯
2012-11-22 16:58:29
Cypress蓝牙 BLE 4.1 开发套件 CY8KIT-042-BLE免费试用(名单公布)
,并在 Cypress技术论坛(https://bbs.elecfans.com/zhuti_cypress_1.html)发帖记录 CY8CKIT-042-BLE开发套件的试用过程、分享试用
2015-03-05 10:37:47
PowerPSoC LED智能驱动方案 LED照明应用框图 RGBA混色驱动
interconnects, providing access to eight digital blocks and six analog blocks.The CY8CLED04D0X is the first
2009-10-23 09:53:19
cypress cy8c5868AXI-LP032怎么取系统时间?
我在用cypress cy8c5868AXI-LP032做项目,想记录系统时间,但是不知道怎么取系统时间,您能告诉我该怎么做么?
2024-02-21 06:14:51
M24C04确认0x50到0x57而不是0x50/0x51
嗨,我正在使用带有5-UFDFPN封装的M24C04 EEPROM。我可以毫无问题地读/写它,但我发现EEPROM不仅确认0x50和0x51,而且实际上确认0x50到0x57。根据数据表
2019-02-12 13:18:29
PSOC1和PowerPSoC有什么不同?
在浏览收费管理员的文件时,我偶然发现了PowerPSoC。谁能告诉我PSOC1和PowerPSoC有什么不同?他们都有相同的核心? 以上来自于百度翻译 以下为原文While going
2019-01-30 12:41:40
PSoC6-CY8CKIT-062S2-43012开发板简介
150MHz,Cortex-M0主频 100MHz,2MB Flash 和 1MB SRAMMCU手册更多详细信息请参考文档 PSoC 6 MCU: CY8C62x8, CY8C62xA Datasheet
2022-10-14 11:08:40
PsoC CY8CKIT-002 MiniProg3支持对CY8C27X43的仿真和调试吗?
大家好! 请问一下:PsoC CY8CKIT-002 MiniProg3 支持对CY8C27X43(CY8C27443-24PVXI,CY8C27643-24PVXI)的仿真和调试吗?
2024-01-31 07:28:06
SWD Cypress control
目前正在写SWD去自行对Cypress CY8C4XX做操作,我使用官方提供的源代码/文件目前在Acquire Chip使用第二种方法,可以顺利执行到擦除,但在做再次验证时,我的Acquire
2019-11-19 17:29:58
SWD Erase Cypress Fail请问有解决办法吗?
2019-11-19 17:27:48
Technical_Reference_Manual_CY8C24x33
Technical_Reference_Manual_CY8C24x33英文版的英文不好的 可要悠着点
2012-11-19 14:48:40
【蓝牙4.1】CY8CKIT042 BLE开机测试与资料熟悉
官网的打开真的很慢,下载资料很慢 ,或者到以下连接下载光盘不能发连接,有需要联系我Cypress蓝牙 BLE 4.1 开发套件 CY8KIT-042-BLE免费试用光盘上包含四个东西
2015-05-02 22:58:08
【蓝牙4.1试用体验】Cypress蓝牙开发套件 CY8KIT-042-BLE免费试用
申请理由:Cypress蓝牙开发套件 CY8KIT-042-BLE免费试用项目描述:Cypress蓝牙开发套件 CY8KIT-042-BLE免费试用
2015-09-09 17:12:46
中文PSoC用户模块数据手册-计数器 系列
/21xxx, CYWUSB6953, CY7C64215, CY8CLED02/04/08/16, CY8CLED04D01/02/03/04, CY8CTxx110, CY8CNP102, CY8C28xxx, CY8CTxx300, CYCTMA301/301D, CY8C26/25x)
2012-11-21 16:10:52
串口接收,0x0a和0x0d表示的什么?
void USART1_IRQHandler(void){ u8 res; if(USART1->SR&(163)USART_RX_STA=0;//接收数据错误,重新开始接收 }}} }} 串口接收,0x0a和0x0d,表示什么呢?在参考手册都没提到这两个量..
2020-08-19 03:09:51
使用0x04B4/0053的PMODE设置是什么?
在我们新开发的板中,FX3引导加载程序枚举为VID/PID=0x04B4/0BC。我们发现,我们的PMODE设置是111而不是F11(这是由于将PMODE(2)连接到一个具有在配置之前不能关闭的内部
2019-09-17 15:15:52
使用CY8C27143的ISSP编程验证ID阶段
我正在使用一个带有Atmel 2560的CY8C27 143上的ISSP编程。我很难让验证ID芯片工作。我使用串行AN我收到一个0x00和0x08。我应该收到0x00和0x09。我是否接近正确,我
2018-11-28 16:23:18
可以直接将外部晶体连接到管脚上吗?
脚上?如何?或者我需要做一个分离的水晶+驱动电路来驱动它吗?提前感谢伦斯 以上来自于百度翻译 以下为原文On PowerPSOC like CY8CLED04G01 an external
2019-04-17 08:55:10
CY8C6144AZI-S4F92 CYPRESS™编程器中使用cy8ckit_005-a报错的原因?
我试图在CY8C6144AZI-S4F92 CYPRESS™编程器中使用 cy8ckit_005-a 对我的 进行编程。 出现了故障,结果是: CYPRESS™ 程序员一直在轮询,所以我按下了设置
2024-01-19 07:03:00
太阳能控制器内置MPPT算法能移植到PSoC 1设备上吗?
。 以上来自于百度翻译 以下为原文The Cypress' charge controller based on CY8CLED04D01 has an in-built MPPT algorithmn.
2019-02-20 11:18:42
如何将十六进制代码融合到控制器和使用哪个软件
为原文[/td][td=3,1,25%] I will use cy8cled02d01 cypress controller for MPPT solar charge controller
2019-03-12 12:36:03
CY8CKIT-024调谐器的CY8CKIT-042套件不起作用
CY8CKIT-024 CAPSENSE接近盾。我使用以下CyPress产品页面的示例项目:HTTP://www. CyPress .COM/DICONTION/APPLION-NOTES/AN92249近距离
2018-11-16 14:57:07
怎么用CyScript 1.1测试CyPress控制器CY8CITK-042-BLE与CysPress软件狗?
大家好,我想用CyScript 1.1测试CyPress控制器CY8CITK-042-BLE与CysPress软件狗但是设备不能连接,有人知道吗?我附上了这张照片。谢谢没有连接到BeldEnle。PNG27 K
2019-09-29 12:13:33
手把手教你玩转Cypress蓝牙开发套件CY8CKIT-042-BLE开发
CY8CKIT-042-BLE开发板使用的教程,包含给力的开箱图;全面的开发环境配置说明;还有从基础到进阶开发教程;更有全面的开发手册分享;各种美味满足你!!`
2015-08-27 18:08:13
找不到cy8ckit-001的psoc1模块该怎么办?
你好,我和CY8CKIT-01一起工作。作为PSoC1部分,有一个CY8C28 000—24PVXI模块。但是我找不到这个模块上的细节/数据表。当使用CyPress站点的部分搜索选项时,结果结束为空。对此的任何建议都是有利的。泰纳克斯-安拉达
2019-10-11 07:29:35
求助 cy7c68013 slavefifo
;FIFORESET=0x00;SYNCDELAY;EP8FIFOCFG = 0x0D;// lets the EZ-USB auto commit IN packetSYNCDELAY
2013-03-03 10:34:16
求助,CY8CMBR3110读值的问题求解
本人第一次接触CYPRESS芯片,想做一个测试电容按键容值的设备。选用了CY8CMBR3110这款芯片。 我在读取CY8CMBR3110的(寄存器地址0xdb-0xe7)sensor值的时候,会出
2024-02-19 06:23:36
Cypress semiconductor CY7C63000 USB控制器设计低成本USB鼠标
本应用指南描述了如何用Cypress semiconductor 的单芯片CY7C63000 USB微控制器快速设计经济合算的USB光机械鼠标。
2014-09-23 10:12:22
用Labview和NI-VISA做Cypress cy7c68013A的驱动
用Labview和NI-VISA做Cypress cy7c68013A的驱动 在安完驱动后 cypress官方固件下载器就识别不到USB了~求大神帮忙
2013-03-13 20:29:08
请问我是否可以使用CY8C2623上的ReFMUX模块?
CYLD02/04/08/16、CY8CRED0XD、CY8CYLD0XG、CY8CTST120、CY8CTM120、CY8CTMA120、CY8CTMA300、CY8CTMAX300、CY8
2019-08-05 09:52:50
赛普拉斯CYPRESSCY8CKIT-042,有懂玩的吗?
`前不久在赛普拉斯CYPRESS天猫旗舰店申请了CY8CKIT-042试用,有懂玩的吗?在此地向大神们请教请教。`
2019-03-01 17:31:10
超声波(HC-SR04)样品项目(CY8CKIT-044)
有人请求帮助cy8ckit-042,我决定离开我的cy8ckit-044版本在这里。这是有点实惠HC-SR04超声波传感器模块,看起来简单,但对模块的芯片做的很好的工作!首先,我设置定时器的时钟频率
2018-08-28 14:51:56
采用Cypress semiconductor的CY7C63413 USB微控制器设计USB键盘
本应用指南描述了如何用Cypress semiconductor 的单芯片CY7C63413 USB微控制器设计USB键盘。
2014-09-23 10:07:17
cy2dl814 pdf datasheet (1:4 Cl
The Cypress CY2 series of network circuits is produced usingadvanced 0.35-micron CMOS technology
2008-09-03 23:58:0617
CY25562 pdf datasheet (Spread
The Cypress CY25562 is a Spread Spectrum Clock Generator(SSCG) IC used for the purpose of reducing
2008-09-04 15:24:0913
CY25561 pdf datasheet (Spread
The Cypress CY25561 is a Spread Spectrum Clock Generator(SSCG) IC used for the purpose of reducing
2008-09-04 15:25:3216
cy25560 pdf datasheet (Spread
General DescriptionThe Cypress CY25560 is a Spread Spectrum Clock Generator(SSCG) IC used
2008-09-04 15:26:5025
cy25568 pdf datasheet
The Cypress CY25568 is a Spread Spectrum Clock Generator (SSCG) IC used for the purpose of reducing
2008-09-04 15:42:2711
CY2DL814 pdf datasheet (1:4 Cl
DescriptionThe Cypress CY2 series of network circuits is produced usingadvanced 0.35-micron CMOS
2008-10-13 10:54:2615
CY7B923用作ECL时钟源
This application note considers general interfacing issues betweenthe Cypress CY7B923/CY
2009-06-15 16:09:3514
介绍(HOTLink)CY7B933 RDY引脚在编码、旁路
2009-06-15 16:15:1735
连接CY7B923和CY7B933(HOTlink器件)至定
This application note describes the interfacing issues betweenthe Cypress CY7B923/CY
2009-06-16 10:01:1931
连接CY7B923和CY7B933(HOTlink器件)至宽
2009-06-16 10:03:2540
如何用CypressCY7B923 CY7B933替换Am
with the HOTLink™(CY7B923/CY7B933) devices from Cypress Semiconductor.It will aid in the migration of TAXI–275 designs to the
2009-06-16 10:07:1332
CY37032 CPLD中,用CY7B933 HOTLin
2009-06-16 11:28:0550
原装现货 CY8CKIT-059 全新原盒 PSoC5 LP CY8C5888LTI-LP097 CYPRESS赛普拉斯开发板
原厂Cypress Semiconductor制造商型号CY8CKIT-059数据手册 无铅RoHS符合类型嵌入式MCU/DSP交货周期1-5天SPQ1包装Bulk产品描述PSOC 5LP PROTOTYPING KIT更多其它批量、其它料号请咨询客服
2023-04-06 11:37:11
PowerPSoC 智能LED驱动器技术参考手册
Cypress 公司的PowerPSoC系列集成了可编程的SoC技术,功率电子控制器和开关器件,可以替代传统的MCU,系统IC以及其周围的数量众多的分立元件,使得PowerPSoC解决方案容易使用在照明应用上. P
2010-07-08 15:02:0726
基于Cypress CY3655开发工具的USB鼠标程序
本内容提供了基于Cypress CY3655开发工具的USB鼠标程序 MOV REG[XOSCTR], XOSC_XGM_JUST ; Set the external OSC XGM OR REG
2011-05-03 15:32:3651
贸泽电子即日起供货CypressCY8CKIT-143A PSoC 4蓝牙模块
贸泽电子发售的Cypress CY8CKIT-143A可编程片上系统(PSoC) 4 BLE 256K模块配备内置有256 KB闪存和32 KB SRAM的PSoC 4 BLE设备、24-MHz和32.768-kHz的晶振以及一根PCB天线和其他无源组件。
2016-09-01 13:40:351040
PowerPSoC固件设计指南
赛普拉斯PowerPSoC”提供了一种灵活的方式来实现广泛的HB LED控制器。本文对流程进行了详细的介绍。
2017-08-11 11:32:2220
Cypress的PSoC系列产品CY8C22x45_CY8C21345数据手册免费下载
2017-10-10 14:41:359
Cypress CY3268 PowerPSoC 智能LED照明解决方案
关键词:CY3268 , Cypress , LED照明 , PowerPSoC , 智能 Cypress公司的PowerPSoC 智能LED器采用可编程片上系统(PSoC)技术,具有最好比的功率
2019-02-27 15:22:01378
Cypress CY3269N照明解决方案
关键词:CY3269N , Cypress , 照明 Cypress 公司的CY3269N照明开发方案采用CY8CLED04 EZ-Color HB LED 控制器,用来开发智能的LED照明,用户
2019-03-02 16:15:01330
基于CY8CLED04D01通用发光二极管驱动器的参考设计
View the reference design for CY8CLED04D01. http://www.elecfans.com/soft/ has thousands of reference designs to help bring your project to life.
2021-06-30 08:36:519
PSoC 4:使用HCSR 04CY8CKIT 049 4200测量距离
电子发烧友网站提供《PSoC 4:使用HCSR 04CY8CKIT 049 4200测量距离.zip》资料免费下载
2022-12-27 09:15:120
已全部加载完成
