GCC程序编译的静态链接和动态链接
Linux爱好者 来源:Mr_Bluyee 作者:Mr_Bluyee 2020-11-12 15:50 次阅读
在链接阶段中,所有对应于源文件的 .o 文件、"-l" 选项指定的库文件、无法识别的文件名(包括指定的.o目标文件和.a库文件)按命令行中的顺序传递给链接器。
下面看一下,链接的过程是怎样的:
gcc -v -o helloworld helloworld.o Usingbuilt-inspecs.COLLECT_GCC=gccCOLLECT_LTO_WRAPPER=d:/software/mingw/bin/../libexec/gcc/mingw32/6.3.0/lto-wrapper.exeTarget: mingw32Configured with: ../src/gcc-6.3.0/configure --build=x86_64-pc-linux-gnu --host=mingw32 --target=mingw32 --with-gmp=/mingw --with-mpfr --with-mpc=/mingw --with-isl=/mingw --prefix=/mingw --disable-win32-registry --with-arch=i586 --with-tune=generic --enable-languages=c,c++,objc,obj-c++,fortran,ada --with-pkgversion='MinGW.org GCC-6.3.0-1' --enable-static --enable-shared --enable-threads --with-dwarf2 --disable-sjlj-exceptions --enable-version-specific-runtime-libs --with-libiconv-prefix=/mingw --with-libintl-prefix=/mingw --enable-libstdcxx-debug --enable-libgomp --disable-libvtv --enable-nlsThread model: win32gcc version 6.3.0 (MinGW.org GCC-6.3.0-1) COMPILER_PATH=d:/software/mingw/bin/../libexec/gcc/mingw32/6.3.0/;d:/software/mingw/bin/../libexec/gcc/;d:/software/mingw/bin/../lib/gcc/mingw32/6.3.0/../../../../mingw32/bin/LIBRARY_PATH=d:/software/mingw/bin/../lib/gcc/mingw32/6.3.0/;d:/software/mingw/bin/../lib/gcc/;d:/software/mingw/bin/../lib/gcc/mingw32/6.3.0/../../../../mingw32/lib/;d:/software/mingw/bin/../lib/gcc/mingw32/6.3.0/../../../COLLECT_GCC_OPTIONS='-v' '-o' 'helloworld.exe' '-mtune=generic' '-march=i586' d:/software/mingw/bin/../libexec/gcc/mingw32/6.3.0/collect2.exe -plugin d:/software/mingw/bin/../libexec/gcc/mingw32/6.3.0/liblto_plugin-0.dll -plugin-opt=d:/software/mingw/bin/../libexec/gcc/mingw32/6.3.0/lto-wrapper.exe -plugin-opt=-fresolution=C:UsersMrBluAppDataLocalTempcceFgn0y.res -plugin-opt=-pass-through=-lmingw32 -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lgcc_eh -plugin-opt=-pass-through=-lmoldname -plugin-opt=-pass-through=-lmingwex -plugin-opt=-pass-through=-lmsvcrt -plugin-opt=-pass-through=-ladvapi32 -plugin-opt=-pass-through=-lshell32 -plugin-opt=-pass-through=-luser32 -plugin-opt=-pass-through=-lkernel32 -plugin-opt=-pass-through=-lmingw32 -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lgcc_eh -plugin-opt=-pass-through=-lmoldname -plugin-opt=-pass-through=-lmingwex -plugin-opt=-pass-through=-lmsvcrt -Bdynamic -o helloworld.exe d:/software/mingw/bin/../lib/gcc/mingw32/6.3.0/../../../crt2.o d:/software/mingw/bin/../lib/gcc/mingw32/6.3.0/crtbegin.o -Ld:/software/mingw/bin/../lib/gcc/mingw32/6.3.0 -Ld:/software/mingw/bin/../lib/gcc -Ld:/software/mingw/bin/../lib/gcc/mingw32/6.3.0/../../../../mingw32/lib -Ld:/software/mingw/bin/../lib/gcc/mingw32/6.3.0/../../.. helloworld.o -lmingw32 -lgcc -lgcc_eh -lmoldname -lmingwex -lmsvcrt -ladvapi32 -lshell32 -luser32 -lkernel32 -lmingw32 -lgcc -lgcc_eh -lmoldname -lmingwex -lmsvcrt d:/software/mingw/bin/../lib/gcc/mingw32/6.3.0/crtend.oCOLLECT_GCC_OPTIONS='-v' '-o' 'helloworld.exe' '-mtune=generic' '-march=i586'
crt2.o 、crtbegin.o、crtend.o是gcc加入的系统标准启动文件,对于一般应用程序,这些启动是必须的。
-Ldir:在库文件的搜索路径列表中添加dir目录。
-lname:添加链接库文件。
静态链接与动态链接
库有两种:静态库(.a、.lib)和动态库(.so、.dll)。
window上对应的是 .lib、.dll。
linux上对应的是 .a、.so
如果函数库的一份拷贝是可执行文件的物理组成部分,称之为静态链接。
静态链接当链接程序时,需要使用的每个库函数的一份拷贝被加入到可执行文件中。
静态链接使用静态库进行链接,生成的程序包含程序运行所需要的全部库,可以直接运行,不过静态链接生成的程序体积较大(即使是在静态链接中,整个库文件也并没有全部装入到可执行文件中,所装入的只是需要的函数)。
如果可执行文件只是包含了文件名,让载入器在运行时能够寻找程序所需要的函数库,称之为动态链接。
动态链接允许系统提供一个庞大的函数库集合,可以提供许多有用的服务,程序在运行时寻找它们。
动态链接使用动态链接库进行链接,生成的程序在执行的时候需要加载所需的动态库才能运行。动态链接生成的程序体积较小,但是必须依赖所需的动态库,否则无法执行。
收集模块准备执行的三个阶段的规范名称是链接-编辑(link-editing)、载入(loading)和运行时链接(runtime linking)。静态链接的模块被链接编辑时载入,以便运行。动态链接的模块被链接编辑后载入,并在运行时进行链接以便运行。
程序执行时,在main函数被调用之前,运行时载入器把共享的数据对象载入到进程的地址空间。外部函数被真正调用之前,运行时载入器并不解析它们。所以动态链接即使链接了函数库,如果没有实际调用,也不会带来额外开销。
gcc编译器默认使用动态链接:
gcc -o helloworld_shared helloworld.o
gcc编译器使用静态链接:
gcc -static -o helloworld_static helloworld.o
在windows平台上使用mingw编译发现这两种方式生成的exe文件的大小都一样,为40kb,怀疑mingw的编译的库是静态库。
下面看一下linux平台上使用gcc两种编译方式的文件大小区别:
可以看到helloworld_shared的大小为8344,而helloworld_static的大小达到844792。
-nostartfiles:
不链接系统标准启动文件,而标准库文件仍然正常使用。
gcc -v -nostartfiles -o helloworld helloworld.oUsing built-in specs.COLLECT_GCC=gccCOLLECT_LTO_WRAPPER=d:/software/mingw/bin/../libexec/gcc/mingw32/6.3.0/lto-wrapper.exeTarget: mingw32Configured with: ../src/gcc-6.3.0/configure --build=x86_64-pc-linux-gnu --host=mingw32 --target=mingw32 --with-gmp=/mingw --with-mpfr --with-mpc=/mingw --with-isl=/mingw --prefix=/mingw --disable-win32-registry --with-arch=i586 --with-tune=generic --enable-languages=c,c++,objc,obj-c++,fortran,ada --with-pkgversion='MinGW.org GCC-6.3.0-1' --enable-static --enable-shared --enable-threads --with-dwarf2 --disable-sjlj-exceptions --enable-version-specific-runtime-libs --with-libiconv-prefix=/mingw --with-libintl-prefix=/mingw --enable-libstdcxx-debug --enable-libgomp --disable-libvtv --enable-nlsThread model: win32gcc version 6.3.0 (MinGW.org GCC-6.3.0-1) COMPILER_PATH=d:/software/mingw/bin/../libexec/gcc/mingw32/6.3.0/;d:/software/mingw/bin/../libexec/gcc/;d:/software/mingw/bin/../lib/gcc/mingw32/6.3.0/../../../../mingw32/bin/LIBRARY_PATH=d:/software/mingw/bin/../lib/gcc/mingw32/6.3.0/;d:/software/mingw/bin/../lib/gcc/;d:/software/mingw/bin/../lib/gcc/mingw32/6.3.0/../../../../mingw32/lib/;d:/software/mingw/bin/../lib/gcc/mingw32/6.3.0/../../../COLLECT_GCC_OPTIONS='-v' '-nostartfiles' '-o' 'helloworld.exe' '-mtune=generic' '-march=i586' d:/software/mingw/bin/../libexec/gcc/mingw32/6.3.0/collect2.exe -plugin d:/software/mingw/bin/../libexec/gcc/mingw32/6.3.0/liblto_plugin-0.dll -plugin-opt=d:/software/mingw/bin/../libexec/gcc/mingw32/6.3.0/lto-wrapper.exe -plugin-opt=-fresolution=C:UsersMrBluAppDataLocalTempccZxAfxD.res -plugin-opt=-pass-through=-lmingw32 -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lgcc_eh -plugin-opt=-pass-through=-lmoldname -plugin-opt=-pass-through=-lmingwex -plugin-opt=-pass-through=-lmsvcrt -plugin-opt=-pass-through=-ladvapi32 -plugin-opt=-pass-through=-lshell32 -plugin-opt=-pass-through=-luser32 -plugin-opt=-pass-through=-lkernel32 -plugin-opt=-pass-through=-lmingw32 -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lgcc_eh -plugin-opt=-pass-through=-lmoldname -plugin-opt=-pass-through=-lmingwex -plugin-opt=-pass-through=-lmsvcrt -Bdynamic -o helloworld.exe -Ld:/software/mingw/bin/../lib/gcc/mingw32/6.3.0 -Ld:/software/mingw/bin/../lib/gcc -Ld:/software/mingw/bin/../lib/gcc/mingw32/6.3.0/../../../../mingw32/lib -Ld:/software/mingw/bin/../lib/gcc/mingw32/6.3.0/../../.. helloworld.o -lmingw32 -lgcc -lgcc_eh -lmoldname -lmingwex -lmsvcrt -ladvapi32 -lshell32 -luser32 -lkernel32 -lmingw32 -lgcc -lgcc_eh -lmoldname -lmingwex -lmsvcrtertr000001.o:(.rdata+0x0): undefined reference to `_pei386_runtime_relocator'collect2.exe: error: ld returned 1 exit status
-nostdlib
不链接系统标准启动文件和标准库文件,会提示因为没有链接系统标准启动文件和标准库文件,而链接失败。
该选项常用于裸机/bootloader、linux内核等程序,因为它们不需要启动文件、标准库文件。
gcc -v -nostdlib -o helloworld helloworld.oUsing built-in specs.COLLECT_GCC=gccCOLLECT_LTO_WRAPPER=d:/software/mingw/bin/../libexec/gcc/mingw32/6.3.0/lto-wrapper.exeTarget: mingw32Configured with: ../src/gcc-6.3.0/configure --build=x86_64-pc-linux-gnu --host=mingw32 --target=mingw32 --with-gmp=/mingw --with-mpfr --with-mpc=/mingw --with-isl=/mingw --prefix=/mingw --disable-win32-registry --with-arch=i586 --with-tune=generic --enable-languages=c,c++,objc,obj-c++,fortran,ada --with-pkgversion='MinGW.org GCC-6.3.0-1' --enable-static --enable-shared --enable-threads --with-dwarf2 --disable-sjlj-exceptions --enable-version-specific-runtime-libs --with-libiconv-prefix=/mingw --with-libintl-prefix=/mingw --enable-libstdcxx-debug --enable-libgomp --disable-libvtv --enable-nlsThread model: win32gcc version 6.3.0 (MinGW.org GCC-6.3.0-1) COMPILER_PATH=d:/software/mingw/bin/../libexec/gcc/mingw32/6.3.0/;d:/software/mingw/bin/../libexec/gcc/;d:/software/mingw/bin/../lib/gcc/mingw32/6.3.0/../../../../mingw32/bin/LIBRARY_PATH=d:/software/mingw/bin/../lib/gcc/mingw32/6.3.0/;d:/software/mingw/bin/../lib/gcc/;d:/software/mingw/bin/../lib/gcc/mingw32/6.3.0/../../../../mingw32/lib/;d:/software/mingw/bin/../lib/gcc/mingw32/6.3.0/../../../COLLECT_GCC_OPTIONS='-v' '-nostdlib' '-o' 'helloworld.exe' '-mtune=generic' '-march=i586' d:/software/mingw/bin/../libexec/gcc/mingw32/6.3.0/collect2.exe -plugin d:/software/mingw/bin/../libexec/gcc/mingw32/6.3.0/liblto_plugin-0.dll -plugin-opt=d:/software/mingw/bin/../libexec/gcc/mingw32/6.3.0/lto-wrapper.exe -plugin-opt=-fresolution=C:UsersMrBluAppDataLocalTempccRAu2K4.res -Bdynamic -o helloworld.exe -Ld:/software/mingw/bin/../lib/gcc/mingw32/6.3.0 -Ld:/software/mingw/bin/../lib/gcc -Ld:/software/mingw/bin/../lib/gcc/mingw32/6.3.0/../../../../mingw32/lib -Ld:/software/mingw/bin/../lib/gcc/mingw32/6.3.0/../../.. helloworld.ohelloworld.o(.text+0xa): undefined reference to `__main'helloworld.o(.text+0x25): undefined reference to `puts'helloworld.o(.text+0x3b): undefined reference to `printf'helloworld.o(.text+0x47): undefined reference to `puts'collect2.exe: error: ld returned 1 exit status
动态链接的优点
动态链接的优点是可执行文件的体积可以非常小。虽然运行速度稍慢一些,但动态链接能够更加有效的利用磁盘空间,而且链接-编辑阶段的时间也会缩短(因为链接器的有些工作被推迟到载入时)。
动态链接的主要目的是把程序与它们使用的特定的函数库版本中分离开来。取而代之的是,我们约定由系统向程序提供一个接口,该接口保持稳定,不随时间和操作系统的后续版本发生变化。
程序可以调用接口所承诺的服务,而不必担心这些功能是怎样提供的或者它们的底层实现是否改变。由于它是介于应用程序和函数库二进制可执行文件所提供的服务之间的接口,所以称它为应用程序二进制接口(Application Binary Interface,ABI)。
尽管单个可执行文件的启动速度稍受影响,但动态链接可以从两个方面提高性能:
1.动态链接可执行文件比功能相同的静态链接可执行文件的体积小。它能够节省磁盘空间和虚拟内存,因为函数库只有在需要时才被映射到进程中。
2.所有动态链接到某个特定函数库的可执行文件在运行时共享该函数库的一个单独拷贝。操作系统内核保证映射到内存中的函数库可以被所有使用它们的进程共享。这就提供了更好的I/O和交换空间利用率,节省了物理内存,从而提高了系统的整体性能。如果可执行文件是静态链接的,每个文件都将拥有一份函数库的拷贝,显然极为浪费。
动态链接使得函数库的版本升级更为容易。新的函数库可以随时发布,只要安装到系统中,旧的程序就能够自动获得新版本函数库的优点而无需重新链接。动态链接允许用户在运行时选择需要执行的函数库。这就使为了提高速度或提高内存使用效率或包含额外的调试信息而创建新版本的函数库是完全可能的,用户可以根据自己的喜好,在程序执行时用一个库文件取代另一个库文件。
动态链接是一种“just-in-time(JIT)”链接,这意味着程序在运行时必须能够找到它们所需要的函数库。链接器通过把库文件名或路径名植入可执行文件中来做到这一点。这意味着,函数库的路径不能随意移动。如果把程序链接到/usr/lib/libthread.so库,那么就不能把该函数库移动到其他目录,除非在链接器中进行特别说明。否则,当程序调用该函数库的函数时,就会在运行时导致失败。当在一台机器上编译完程序后,把它拿到另一台不同的机器上运行时,也可能出现这种情况。执行程序的机器必须具有该程序需要链接的函数库,而且这些函数库必须位于在链接器中所说明的目录。对于标准系统函数库而言,这并不成问题。
任何人都可以创建静态或动态的函数库。只需简单的编译一些不包含main函数的代码,并把编译所生的.o用正确的工具进行处理。
使用gcc程序编译的过程中的示例代码在Ubuntu下使用gcc创建静态和动态库:
1.首先将helloworld代码拆分开来:
分别为“helloworld.c”、“helloworld.h”、“main.c”,
helloworld.c内容如下:
#include #define TRUE 1#define FALSE 0 #define DEBUG_ENABLE void helloworld(void){ int i = 0; if(i == TRUE){ printf("hello "); }else{#ifdef DEBUG_ENABLE printf("i = %d ",i);#endif printf("hello world "); }}
helloworld.h内容如下:
#ifndef HELLO_WORLD_H #define HELLO_WORLD_H void helloworld(void);#endif
main.c内容如下:
#include "helloworld.h"int main(){ helloworld(); return 0; }
2.将helloworld.c生成动态链接库:
gcc -fPIC -shared helloworld.c -o libhelloworld.so
-fPIC:表示编译为位置独立的代码,不用此选项的话编译后的代码是位置相关的所以动态载入时是通过代码拷贝的方式来满足不同进程的需要,而不能达到真正代码段共享的目的。与位置无关的代码表示用这种方法产生的代码保证对于任何全局数据的访问都是通过额外的间接方法完成的。这使它很容易对数据进行重新定位,只要简单的修改全局偏移量表的其中一个值就可以了。类似的,每个函数调用的产生就像是通过过程链接表的某个间接地址所产生的一样。这样,文本可以很容易的重新定位到任何地方,只要修改一下偏移量表就可以了。所以当代码在运行时被映射进来时,运行时链接器可以直接把它们放在任何空闲的地方,而代码本身并不需要修改。
在缺省情况下,编译器并不产生与位置无关的代码,因为额外的指针解除引用操作将使程序在运行时稍慢。然而,如果不使用与位置无关的代码,所产生的代码就会被对应到固定的地址,这对于可执行文件来说确实很好,但对于共享库,速度却要慢一点,因为现在每个全局引用就不得不在运行时通过修改页面安排到固定的位置,这使得页面无法共享。
运行时链接器总能够安排对页面的引用。但是,使用位置无关代码,任务被极大的简化了。当然需要权衡一下,位置无关代码与由运行时链接器安排代码相比,速度是快了还是慢了。根据经验,对于函数库应该始终使用与位置无关代码。对于共享库,与位置无关的代码显得格外有用,因为每个使用共享库的进程一般都会把它映射到不同的虚拟地址(尽管共享库同一份物理拷贝)。
一个相关的术语是“纯代码(pure code)”。纯可执行文件是只包含代码(无静态或初始化过的数据)的文件。它之所以称为“纯”是因为它不必进行修改就能被其他特定的进程执行。它从堆栈或者其他(非纯)段引用数据。纯代码可以被共享。如果生成与位置无关代码(意味着共享),你通常也希望它是纯代码。
3.编译main时加入libhelloworld.so:
gcc helloworld.h main.c -L. -lhelloworld -o main
-L. : 标记告诉gcc函数库可能位于当前目录。
-l :后面加上动态链接库,动态链接库的名字前的lib不用加上去。传给C编译器的命令行参数里并没有提到函数库的完整路径名。它甚至没有提到在函数库目录中该文件的完整名字。实际上,编译器被告知根据选项-lname链接到相应的函数库,函数库的名字是libname.so——换句话说,“lib”部分和文件扩展名被省略掉了,但在前面加了一个“l”。
4.运行main,出错:
./main: error while loading shared libraries: libhelloworld.so: cannot open shared object file: No such file or directory
程序在运行时,会查找需要的动态库文件,若找到,则载入动态库,否则将提示类似上述错误而终止程序运行。有多种方法可以解决:
a.将文件 libhelloworld.so复制到目录/usr/lib中,再执行则没有问题:
mrbluyee@mrbluyee:~/mypro/C$ sudo mv libhelloworld.so /usr/libmrbluyee@mrbluyee:~/mypro/C$ ./maini = 0hello world
b.既然连接器会搜寻LD_LIBRARY_PATH所指定的目录,那么我们可以将这个环境变量设置成当前目录:
mrbluyee@mrbluyee:~/mypro/C$ export LD_LIBRARY_PATH=$(pwd)mrbluyee@mrbluyee:~/mypro/C$ ./maini = 0helloworld
c. ldconfig命令
mrbluyee@mrbluyee:~/mypro/C$ sudo ldconfig ~/mypro/Cmrbluyee@mrbluyee:~/mypro/C$ ./maini = 0hello world
当用户在某个目录下面创建或拷贝了一个动态链接库,若想使其被系统共享,可以执行一下”ldconfig 目录名”这个命令。此命令的功能在于让ldconfig将指定目录下的动态链接库被系统共享起来,意即:在缓存文件/etc/ld.so.cache中追加进指定目录下的共享库。上述指令让系统共享了~/mypro/C目录下的动态链接库。
可以查看程序执行时调用动态库的过程:
mrbluyee@mrbluyee:~/mypro/C$ ldd main linux-vdso.so.1 (0x00007ffd56fa4000) libhelloworld.so => /home/mrbluyee/mypro/C/libhelloworld.so (0x00007fcec730f000) libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fcec6f1e000) /lib64/ld-linux-x86-64.so.2 (0x00007fcec7713000)
5.将helloworld.c生成静态链接库:
a. 先将helloworld.c编译生成.o文件:
gcc -c -o helloworld.o helloworld.c
b.通过ar工具将目标文件打包成.a静态库文件:
ar -rc libhelloworld.a helloworld.o
注意:静态库与汇编生成的目标文件一起链接为可执行文件,那么静态库必定跟.o文件格式相似。其实一个静态库可以简单看成是一组目标文件(.o/.obj文件)的集合,即很多目标文件经过压缩打包后形成的一个文件。故ar工具里打包的一定是.o的文件,否则当运行连接了该静态库的可执行程序会报错。
6.编译main时加入libhelloworld.a:
gcc helloworld.h main.c -static -L. -lhelloworld -o main_static
可以看到,使用动态链接库生成的mian与静态链接库生成的main_static的大小区别:
动态链接库生成的mian大小为8288,而静态链接库生成的main_static的大小为844856。
7.删除libhelloworld.a后运行main_static:
mrbluyee@mrbluyee:~/mypro/C$ rm libhelloworld.amrbluyee@mrbluyee:~/mypro/C$ ./main_static i = 0hello world
程序照常运行,静态库中的helloworld函数已经链接到main_static文件中了。
8.多个文件生成动态/静态库的用法:
动态库:
1.gcc -fPIC -shared xxx1.c xxx2.c xxx3.c -o libxxx.so 2.gcc -fPIC -shared xxx1.o xxx2.o xxx3.o -o libxxx.so
静态库:
ar -rc libxxx.a xxx1.o xxx2.o xxx3.o
责任编辑:lq
  • 模块
  • 编译器
  • 函数库
原文标题:GCC 程序编译的静态链接和动态链接
文章出处:【微信号:LinuxHub,微信公众号:Linux爱好者】欢迎添加关注!文章转载请注明出处。
    热点推荐
    请问如何链接动态库?
    是否有可参考的工程? 链接成功后动态库应该放在哪里啊?SDK是RTOS_ONLY
    发表于 04-25 08:15
    深入探讨Linux系统中的动态链接库机制
    本文将深入探讨Linux系统中的动态链接库机制,这其中包括但不限于全局符号介入、延迟绑定以及地址无关代码等内容。 引言 在软件开发过程中,动态链接问题时常出现,这可能导致符号冲突,从
    的头像 发表于 12-18 10:06 473次阅读
    深入探讨Linux系统中的<b class='flag-5'>动态</b><b class='flag-5'>链接</b>库机制
    分享关于编译器的科普
    源代码分析工具和IDE集成。GCC被构建成一个单一的静态编译器,这使得它非常难以被作为API并集成到其他工具中。 GCC比Clang支
    的头像 发表于 12-09 09:49 427次阅读
    安卓动态链接库文件体积优化探索实践
    诸多方面影响,针对dex、资源文件、so文件都有不同的优化策略,在此不做一一展开,本文主要记录了在研发时针对动态链接库的文件体积裁剪优化方案。 我开发的链接库使用rust语言开发,通过安卓jni接口实现java层和native层
    的头像 发表于 11-21 14:07 349次阅读
    深入解析Tricore的Tasking链接文件
    目录 1.链接文件有什么用? 2.文件结构和语法解析 2.1 文件结构 2.2 语法解析 3.小结 玩惯了ld文件,突然让搞lsl文件,被其中花里胡哨的语法搞晕了,例如: memory
    的头像 发表于 11-12 16:31 1495次阅读
    深入解析Tricore的Tasking<b class='flag-5'>链接</b>文件
    三星贴片电容的引脚结构和链接方式
    三星贴片电容,作为一种广泛应用的电子元件,其引脚结构和链接方式对于电路的性能和稳定性具有至关重要的作用。下面,我们将详细介绍三星贴片电容的引脚结构和链接方式。
    的头像 发表于 10-29 17:47 545次阅读
    KeyStone I和IlDevices上的SERDES链接调试
    电子发烧友网站提供《KeyStone I和IlDevices上的SERDES链接调试.pdf》资料免费下载
    发表于 10-11 10:05 0次下载
    KeyStone I和IlDevices上的SERDES<b class='flag-5'>链接</b>调试
    先进的链接器技术,方便高效地使用内存
    电子发烧友网站提供《先进的链接器技术,方便高效地使用内存.pdf》资料免费下载
    发表于 09-06 15:02 0次下载
    先进的<b class='flag-5'>链接</b>器技术,方便高效地使用内存
    嵌入式学习-静态链接动态链接
    一、静态链接静态链接通过静态库进行链接,生成的目标程序
    发表于 08-28 09:33
    静态链接动态链接
    发表于 08-27 10:20
    嵌入式学习-常用编辑器之GCC编译
    ;汇编:将汇编语言翻译成二进制文件;链接:将汇编出来的多个二进制目标文件和库文件进行链接,生成可执行文件。我们可以通过一个简单的hello.c程序编译过程对
    发表于 08-27 10:17
    常用编辑器之GCC编译
    ,输出结果是一样的。elf@ubuntu:~/work/example/hello$ gcc hello.c4、GCC编译过程GCC编译器的
    发表于 08-24 11:05
    e² studio中链接脚本的修改指导
    一般而言,程序编译经历下图四个阶段,链接编译的最后一步,无论是在PC上编译代码,还是在PC上使用嵌入式
    的头像 发表于 06-13 10:49 848次阅读
    e² studio中<b class='flag-5'>链接</b>脚本的修改指导
    TouchGFX文件编译通过,但是无法链接成功,为什么?
    TouchGFX文件编译通过,但是无法链接成功,看网上说是格式不对
    发表于 06-03 09:07
    X-CUBE-CRYPTOLIB V4库文件无法添加,链接错误的原因?
    看官方介绍,V4版本的静态库是支持多个编译器的,芯片是stm32h743,我用的是arm-none-eabi-gcc,版本是gcc version 13.2.1 20231009 (
    发表于 05-31 07:54
    【H桥电机驱动电路原理】-学习笔记
    工作原理电路分析这是一个由晶体管构成的H桥电机驱动电路,以下是对其各部分的介绍:核心器件晶体管:电路中使用了PNP型的SS8550(Q5、Q6)和NPN型的SS8050(Q9、Q10、Q13、Q14)。通过不同晶体管的导通与截止组合,实现电机两端电压极性的切换,进而控制电机正反转。比如,当Q5和Q10导通,Q6和Q9截止时,电流从MotorL+流入电机,从M
    张飞实战电子官方
    16小时前
    92
    ATA-2041高压放大器在CFRP板分层缺陷的空耦超声原位测量中的应用
    前言空气耦合超声波技术,作为一种高效且无损的检测方法,近年来在工业领域受到了广泛关注。其独特之处在于利用空气作为耦合介质,无需与被测物体直接接触,即可实现高精度的检测与成像。它能够检测在用CFRP板中的缺陷确保其应用安全,但传统的空气耦合超声方法通常依赖于线性缺陷指数在表征小尺寸缺陷方面无效。此外扫描步长完全限制了它们的成像空间分辨率,导致成像空间分辨率与检
    Aigtek安泰电子
    17小时前
    118
    TwinCAT3 EtherCAT抓包 | 技术集结
    在使用TwinCAT测试EtherCATEOE功能时,我们会发现正常是无法使用Wireshark去进行网络抓包抓取EtherCAT报文的,今天这篇文章就带大家来上手EtherCAT抓包方式。准备环境硬件环境:EtherKit开发板网线一根Type-CUSB线一根软件环境TwinCAT3RT-ThreadstudiowiresharkEtherCATEOE工程
    RT-Thread官方账号
    18小时前
    388
    EtherCAT科普系列(8):EtherCAT技术在机器视觉领域的应用
    机器视觉是基于软件与硬件的组合,通过光学装置和非接触式的传感器自动地接受一个真实物体的图像,并利用软件算法处理图像以获得所需信息或用于控制机器人运动的装置。机器视觉可以赋予机器人及自动化设备获取外界信息并认知处理的能力。机器视觉系统内包含光学成像系统,可以作为自动化设备的视觉器官实现信息的输入,并借助视觉控制器代替人脑实现信息的处理与输出。从而实现赋予自动化
    码灵半导体
    19小时前
    206
    新品 | 26+6TOPS强悍算力!飞凌嵌入式FCU3501嵌入式控制单元发布
    飞凌嵌入式FCU3501嵌入式控制单元基于瑞芯微RK3588处理器开发设计,4xCortex-A76+4xCortex-A55架构,A76主频高达2.4GHz,A55核主频高达1.8GHz,支持8K编解码,NPU算力6TOPS,支持算力卡拓展,可以插装Hailo-8 26TOPS M.2算力卡。
    飞凌嵌入式
    1天前
    351
    接口核心板必选 | 视美泰AIoT-3568SC 、 AIoT-3576SC:小身材大能量,轻松应对多场景设备扩展需求!
    在智能硬件领域,「适配」是绕不开的关键词。无论是小屏设备的”寸土寸金”,还是模具开发的巨额成本,亦或是多产品线兼容的复杂需求,开发者总在寻找一款能「以不变应万变」的核心解决方案。视美泰旗下的AIoT-3568SC与AIoT-3576SC接口核心板系列,可以说是专为高灵活适配场景而生!无需为设备尺寸、模具限制或产品线差异妥协,一块核心板,即可释放无限可能。为什
    视美泰
    1天前
    393
    3核A7+单核M0多核异构,米尔全新低功耗RK3506核心板发布
    近日,米尔电子发布MYC-YR3506核心板和开发板,基于国产新一代入门级工业处理器瑞芯微RK3506,这款芯片采用三核Cortex-A7+单核Cortex-M0多核异构设计,不仅拥有丰富的工业接口、低功耗设计,还具备低延时和高实时性的特点。核心板提供RK3506B/RK3506J、商业级/工业级、512MB/256MBLPDDR3L、8GBeMMC/256
    米尔电子
    1天前
    381
    搭建树莓派网络监控系统:顶级工具与技术终极指南!
    树莓派网络监控系统是一种经济高效且功能多样的解决方案,可用于监控网络性能、流量及整体运行状况。借助树莓派,我们可以搭建一个网络监控系统,实时洞察网络活动,从而帮助识别问题、优化性能并确保网络安全。安装树莓派网络监控系统有诸多益处。树莓派具备以太网接口,还内置了Wi-Fi功能,拥有足够的计算能力和内存,能够在Linux或Windows系统上运行。因此,那些为L
    上海晶珩电子科技有限公司
    1天前
    385
    STM32驱动SD NAND(贴片式SD卡)全测试:GSR手环生物数据存储的擦写寿命与速度实测
    在智能皮电手环及数据存储技术不断迭代的当下,主控 MCU STM32H750 与存储 SD NAND MKDV4GIL-AST 的强强联合,正引领行业进入全新发展阶段。二者凭借低功耗、高速读写与卓越稳定性的深度融合,以及高容量低成本的突出优势,成为大规模生产场景下极具竞争力的数据存储解决方案。
    MK米客方德
    1天前
    439
    芯对话 | CBM16AD125Q这款ADC如何让我的性能翻倍?
    综述在当今数字化时代,模数转换器(ADC)作为连接模拟世界与数字系统的关键桥梁,其技术发展对众多行业有着深远影响。从通信领域追求更高的数据传输速率与质量,到医疗影像领域渴望更精准的疾病诊断,再到工业控制领域需要适应复杂恶劣环境的稳定信号处理,ADC的性能提升成为推动这些行业进步的重要因素。行业现状分析在通信行业,5G乃至未来6G的发展,对基站信号处理提出了极
    芯佰微电子
    2天前
    520
    史上最全面解析:开关电源各功能电路
    01开关电源的电路组成开关电源的主要电路是由输入电磁干扰滤波器(EMI)、整流滤波电路、功率变换电路、PWM控制器电路、输出整流滤波电路组成。辅助电路有输入过欠压保护电路、输出过欠压保护电路、输出过流保护电路、输出短路保护电路等。开关电源的电路组成方框图如下:02输入电路的原理及常见电路1AC输入整流滤波电路原理①防雷电路:当有雷击,产生高压经电网导入电源时
    张飞实战电子官方
    2天前
    462
    有几种电平转换电路,适用于不同的场景
    一.起因一般在消费电路的元器件之间,不同的器件IO的电压是不同的,常规的有5V,3.3V,1.8V等。当器件的IO电压一样的时候,比如都是5V,都是3.3V,那么其之间可以直接通讯,比如拉中断,I2Cdata/clk脚双方直接通讯等。当器件的IO电压不一样的时候,就需要进行电平转换,不然无法实现高低电平的变化。二.电平转换电路常见的有几种电平转换电路,适用于
    张飞实战电子官方
    05-12 19:33
    364
    瑞萨RA8系列教程 | 基于 RASC 生成 Keil 工程
    对于不习惯用 e2 studio 进行开发的同学,可以借助 RASC 生成 Keil 工程,然后在 Keil 环境下愉快的完成开发任务。
    RA生态工作室
    05-01 10:00
    631
    共赴之约 | 第二十七届中国北京国际科技产业博览会圆满落幕
    作为第二十七届北京科博会的参展方,芯佰微有幸与800余家全球科技同仁共赴「科技引领创享未来」之约!文章来源:北京贸促5月11日下午,第二十七届中国北京国际科技产业博览会圆满落幕。本届北京科博会主题为“科技引领创享未来”,由北京市人民政府主办,北京市贸促会,北京市科委、中关村管委会,北京市经济和信息化局,北京市知识产权局和北辰集团共同承办。5万平方米的展览云集
    芯佰微电子
    05-12 13:36
    1.1k
    道生物联与巍泰技术联合发布 RTK 无线定位系统:TurMass™ 技术与厘米级高精度定位的深度融合
    道生物联与巍泰技术联合推出全新一代 RTK 无线定位系统——WTS-100(V3.0 RTK)。该系统以巍泰技术自主研发的 RTK(实时动态载波相位差分)高精度定位技术为核心,深度融合道生物联国产新兴窄带高并发 TurMass™ 无线通信技术,为室外大规模定位场景提供厘米级高精度、广覆盖、高并发、低功耗、低成本的一站式解决方案,助力行业智能化升级。
    道生物联
    05-12 13:40
    840
