如何合理高效地使用状态机呢?
OpenFPGA 来源:OpenFPGA 2023-02-12 10:21 次阅读
今天还是更新状态机,状态机基本是整个HDL中的核心,合理、高效地使用状态机,是数字电路中的重要技能。
题目说明
图片来自HDLBits
模块端口声明
moduletop_module(
inputclk,
inputreset,
input[3:1]s,
outputfr3,
outputfr2,
outputfr1,
outputdfr
题目解析
moduletop_module(
inputlogicclk,
inputlogicreset,
inputlogic[3:1]s,
outputlogicfr3,
outputlogicfr2,
outputlogicfr1,
outputlogicdfr
//definestate
typedefenumlogic[1:0]{empty=2'd0,level_1=2'd1,level_2=2'd2,level_3=2'd3}state_def;
state_defcur_state,next_state;
//describestatesequencerusesequentiallogic
always_ff@(posedgeclk)begin
if(reset)cur_state<= empty ;
        else       cur_state <= next_state ;
    end
   //describe next state decoder use conbinational logic
   always_comb begin
       unique case (s)
           3'b000: next_state = empty ;
           3'd001: next_state = level_1 ;
           3'b011: next_state = level_2 ;
           3'b111: next_state = level_3 ;
       endcase
   end
   //describe output decoder use conbinational and sequential logic
   // decoder output fr1~fr3
   assign fr3 = (cur_state == empty) ;
   assign fr2 = (cur_state == empty) || (cur_state == level_1) ;
   assign fr1 = (cur_state == empty) || (cur_state == level_1) || (cur_state == level_2) ;
   // decoder output dfr
   var logic set_dfr , reset_dfr ;
   assign set_dfr =   ((next_state == empty) && (cur_state != empty)) ||
                      ((next_state == level_1) && (cur_state != level_1) && (cur_state != empty)) ||
                      ((next_state == level_2) && (cur_state == level_3)) ;
   assign reset_dfr = ((next_state == level_3) && (cur_state != level_3)) ||
                      ((next_state == level_2) && (cur_state != level_2) && (cur_state != level_3)) ||
                      ((next_state == level_1) && (cur_state == empty)) ;
   always_ff @( posedge clk ) begin
         if (reset) begin
             dfr <= 1'd1 ;
         end
         else if (set_dfr) begin
             dfr <= 1'd1 ;
         end
         else if (reset_dfr) begin
             dfr <= 1'd0 ;
         end
         else begin
             dfr <= dfr ;
         end
   end
endmodule
点击Submit,等待一会就能看到下图结果:
注意图中的Ref是参考波形,Yours是你的代码生成的波形,网站会对比这两个波形,一旦这两者不匹配,仿真结果会变红。
这一题就结束了。
Problem 127-Lemmings1
题目说明
旅鼠(Lemmings)游戏涉及相当简单的小动物。所以我们将使用有限状态机对其进行建模。
在 Lemmings 的 2D 世界中,Lemmings 可以处于两种状态之一:向左行走或向右行走。如果遇到障碍物,它会改变方向。
特别是,如果旅鼠在左边被撞到,它就会向右走。
如果它被撞到右边,它就会向左走。
如果它的两侧同时受到碰撞,它仍然会切换方向。
实现具有两个状态、两个输入和一个输出的 Moore 状态机来模拟此行为。
图片来自HDLBits
模块端口声明
moduletop_module(
inputclk,
inputareset,//FreshlybrainwashedLemmingswalkleft.
inputbump_left,
inputbump_right,
outputwalk_left,
outputwalk_right);
题目解析
我们首先需要找出状态转移规则。具体如下图所示:
找到转移关系后,后续的解答就和之前题目相同。
moduletop_module(
inputlogicclk,
inputlogicareset,//FreshlybrainwashedLemmingswalkleft.
inputlogicbump_left,
inputlogicbump_right,
outputlogicwalk_left,
outputlogicwalk_right);
//definestate
typedefenumlogic{left=1'b0,right=1'b1}state_def;
state_defstate,next_state;
//Statetransitionlogic
always_combbegin
case(state)
left:begin
if(bump_left)next_state=right;
elsenext_state=left;
end
right:begin
if(bump_right)next_state=left;
elsenext_state=right;
end
endcase
end
//Stateflip-flopswithasynchronousreset
always@(posedgeclk,posedgeareset)begin
if(areset)state<= left ;
        else          state <= next_state ;
    end
    // Output logic
    assign walk_left = (state == left );
    assign walk_right = (state == right );
endmodule
这一题就结束了。
Problem 128-Lemmings2
题目说明
在上一题基础上,除了左右行走之外,如果地面在它们下方消失,旅鼠还会掉落(并且大概会发出“啊啊!”)。
除了左右行走和碰撞时改变方向外,当ground=0时,旅鼠会倒下并说“啊啊!”。当地面重新出现 ( ground=1 ) 时,旅鼠将继续沿与坠落前相同的方向行走。跌倒时被撞不影响行走方向,与地面消失(但尚未跌落)同周期被撞,或跌倒时地面再次出现,也不影响行走方向。
构建一个模拟此行为的有限状态机。
图片来自HDLBits
模块端口声明
moduletop_module(
inputclk,
inputload,
input[255:0]data,
output[255:0]q);
endmodule
题目解析
还是优先画出状态转移图:
moduletop_module(
inputlogicclk,
inputlogicground,
outputlogicwalk_right,
outputlogicaaah);
//definestate
typedefenumlogic[1:0]{left=2'd0,right=2'd1,fall_left=2'd2,fall_right=2'd3}state_def;
//describestatetransitionuseconbinationallogic
always_combbegin
case(cur_state)
left:begin
if(!ground)begin
next_state=fall_left;
end
elseif(bump_left)begin
next_state=right;
end
elsebegin
next_state=left;
end
end
right:begin
if(!ground)begin
next_state=fall_right;
end
elseif(bump_right)begin
next_state=left;
end
elsebegin
next_state=right;
end
end
fall_left:begin
if(ground)begin
next_state=left;
end
elsebegin
end
end
fall_right:begin
if(ground)begin
next_state=right;
end
elsebegin
end
end
endcase
end
always_ff@(posedgeclkorposedgeareset)begin
if(areset)begin
cur_state<= left ;
        end
        else begin
        end
    end
    //describe output decoder use conbinational logic
    assign walk_left = (cur_state == left)  ;
    assign walk_right = (cur_state == right);
    assign aaah = (cur_state == fall_left) || (cur_state == fall_right) ;
endmodule
这一题就结束了。
Problem 129-Lemmings3
题目说明
在Lemmings1和Lemmings2基础上。
除了行走和坠落之外,旅鼠有时会被告知做一些有用的事情,比如挖掘(它在dig=1时开始挖掘)。如果旅鼠当前正在地面上行走(ground=1且未掉落),则它可以挖掘,并且会继续挖掘直到到达另一侧(ground=0)。到那时,由于没有地面,它会掉落(啊啊!),然后在它再次着地后继续沿原来的方向行走。与掉落一样,在挖掘时被碰撞没有任何效果,而在掉落或没有地面时被告知挖掘将被忽略。
(换句话说,行走的旅鼠可以掉落、挖掘或转换方向。如果满足其中一个以上条件,则掉落的优先级高于挖掘,而挖掘的优先级高于转换方向。)
扩展您的有限状态机来模拟这种行为。
图片来自HDLBits
模块端口声明
moduletop_module(
inputclk,
inputbump_left,
inputbump_right,
inputground,
inputdig,
outputwalk_left,
outputwalk_right,
outputaaah,
outputdigging);
题目解析
状态转移图:
moduletop_module(
inputlogicclk,
inputlogicground,
inputlogicdig,
outputlogicaaah,
outputlogicdigging);
//definestate
typedefenumlogic[2:0]{left=3'd0,right=3'd1,
fall_left=3'd2,fall_right=3'd3,
dig_left=3'd4,dig_right=3'd5}state_def;
//describenextstatetransitionusecombinationallogic
always_combbegin
case(cur_state)
left:begin
if(!ground)begin
end
elseif(dig)begin
next_state=dig_left;
end
next_state=right;
end
elsebegin
next_state=left;
end
end
right:begin
if(!ground)begin
end
elseif(dig)begin
next_state=dig_right;
end
next_state=left;
end
elsebegin
next_state=right;
end
end
fall_left:begin
if(ground)begin
next_state=left;
end
elsebegin
end
end
fall_right:begin
if(ground)begin
next_state=right;
end
elsebegin
end
end
dig_left:begin
if(!ground)begin
end
elsebegin
end
end
dig_right:begin
if(!ground)begin
end
elsebegin
end
end
endcase
end
if(areset)begin
cur_state<= left ;
        end
        else begin
        end
    end
    //describe ouput decoder use combinational logic
    assign walk_right = (cur_state == right) ;
    assign digging = (cur_state == dig_left) || (cur_state == dig_right) ;
endmodule
这一题就结束了。
Problem 130-Lemmings4
题目说明
在Lemmings1、Lemmings2和Lemmings3基础上:
尽管旅鼠可以行走、跌倒和挖掘,但旅鼠并非无懈可击。如果旅鼠掉落的时间太长然后撞到地面,它可能会死亡。特别是,如果旅鼠掉落超过 20 个时钟周期然后撞到地面,它将永远停止行走、掉落或挖掘(所有 4 个输出变为 0)(或直到 FSM 复位)。旅鼠在撞到地面之前可以跌落多远没有上限。旅鼠只会在撞到地面时死亡;它们不会死亡到半空中。
扩展之前的有限状态机来模拟这种行为。
跌倒 20 个周期是可以生存的:
图片来自HDLBits
下降 21 个周期会导致死亡:
图片来自HDLBits
模块端口声明
moduletop_module(
inputclk,
inputbump_left,
inputbump_right,
inputground,
inputdig,
outputwalk_left,
outputwalk_right,
outputaaah,
outputdigging);
题目解析
状态转移图:
moduletop_module(
inputlogicclk,
inputlogicground,
inputlogicdig,
outputlogicaaah,
//definestate
dig_left=3'd4,dig_right=3'd5,
splatter=3'd6,aaah_reset=3'd7
}state_def;
varlogic[4:0]cycle_cout;
always_combbegin
case(cur_state)
left:begin
if(!ground)begin
end
elseif(dig)begin
end
next_state=right;
end
elsebegin
next_state=left;
end
end
right:begin
if(!ground)begin
end
elseif(dig)begin
end
next_state=left;
end
elsebegin
next_state=right;
end
end
fall_left:begin
if(ground)begin
next_state=left;
end
elsebegin
if(cycle_cout==5'd20)begin
next_state=splatter;
end
elsebegin
end
end
end
fall_right:begin
if(ground)begin
next_state=right;
end
elsebegin
end
elsebegin
end
end
end
dig_left:begin
if(!ground)begin
end
elsebegin
end
end
dig_right:begin
if(!ground)begin
end
elsebegin
end
end
splatter:begin
if(ground)begin
next_state=aaah_reset;
end
elsebegin
end
end
aaah_reset:begin
end
endcase
end
if(areset)begin
cur_state<= left ;
            cycle_cout <= 5'd0  ;
        end
        else begin
        if ((next_state == fall_left) || (next_state == fall_right)) begin
            cycle_cout <= cycle_cout + 5'd1 ;
        end
        else begin
            if(next_state == splatter)begin
            end
            else begin
            end
        end
        end
    end
    assign walk_left = (cur_state == left) && (cur_state != splatter) ;
    assign walk_right = (cur_state == right) && (cur_state != splatter) ;
    assign aaah = (cur_state == fall_left) || (cur_state == fall_right) || (cur_state == splatter) ;
    assign digging = (cur_state == dig_left) || (cur_state == dig_right) && (cur_state != splatter) ;
endmodule
这一题就结束了。
Problem 131-Fsm_onehot
题目说明
给定以下具有 1 个输入和 2 个输出的状态机:
图片来自HDLBits
假设这个状态机使用 one-hot 编码,其中state[0]到state[9]分别对应于状态 S0 到 S9。除非另有说明,否则输出为零。
实现状态机的状态转换逻辑和输出逻辑部分(但不是状态触发器)。在state[9:0]中获得了当前状态,并且必须生成next_state[9:0]和两个输出。
假设使用one-hot编码,通过检查推导出逻辑方程。(测试平台将使用非热输入进行测试,以确保你不会尝试做更复杂的事情)。
模块端口声明
moduletop_module(
inputin,
input[9:0]state,
output[9:0]next_state,
outputout1,
outputout2);
题目解析
可以通过查看状态转换图的转移的路径来导出独热码状态转换逻辑的逻辑方程式。
仔细观察发现在当前状态state为正常独热码(0x100, 0x1, 0x80)的时候,输出的波形是正确的,但是输入不是独热码(0x900, 0x180)的时候,输出就不正常了,这就是这道题所考察的地方,写错的同学自行翻看前一个独热码状态机的题目(Problem 125 fsm3onehot)再看正确答案。
//One-hotFSM??????IthinktheProblemhavesomeunreasonable
moduletop_module(
inputlogicin,
inputlogic[9:0]state,
outputlogic[9:0]next_state,
outputlogicout1,
outputlogicout2);
//definestatebitposition
parameterlogic[3:0]S0=0,
S1=1,
S2=2,
S3=3,
S4=4,
S5=5,
S6=6,
S7=7,
S8=8,
S9=9;
//describestatetransitionusecombinationallogic
assignnext_state[S0]=~in&(state[S0]|state[S1]|state[S2]|state[S3]|state[S4]|state[S7]|state[S8]|state[S9]);
assignnext_state[S1]=in&(state[S0]|state[S8]|state[S9]);
assignnext_state[S2]=in&state[S1];
assignnext_state[S3]=in&state[S2];
assignnext_state[S4]=in&state[S3];
assignnext_state[S5]=in&state[S4];
assignnext_state[S6]=in&state[S5];
assignnext_state[S7]=in&(state[S6]|state[S7]);
assignnext_state[S8]=~in&state[S5];
assignnext_state[S9]=~in&state[S6];
//describeoutputdecoderusecombinationallogic
assignout1=state[S8]||state[S9];
assignout2=state[S7]||state[S9];
endmodule
这一题就结束了。
Problem 132-Fsm_ps2
题目说明
PS/2 鼠标协议发送三个字节长的消息。但是,在连续的字节流中,消息的开始和结束位置并不明显。唯一的迹象是每个三字节消息的第一个字节始终具有bit[3]=1(但其他两个字节的 bit[3] 可能为 1 或 0,具体取决于数据)。
我们想要一个有限状态机,它会在给定输入字节流时搜索消息边界。我们将使用的算法是丢弃字节,直到我们看到一个带有bit[3]=1的字节。然后我们假设这是消息的第 1 个字节,并在接收到所有 3 个字节(完成)后发出消息接收信号
FSM 应在成功接收到每条消息的第三个字节后立即在周期内发出完成信号。
一些时序图来解释所需的行为
在没有错误的情况下,每三个字节组成一条消息:
图片来自HDLBits
发生错误时,搜索字节 1:
请注意,这与1xx序列识别器不同。此处不允许重叠序列:
图片来自HDLBits
模块端口声明
moduletop_module(
inputclk,
input[7:0]in,
inputreset,//Synchronousreset
outputdone);
题目解析
尽管in[7:0]是一个字节,但状态机使用一个输入in[3]就够了。
该状态机可能有4个状态,但其中的三种状态没有输出是为了最后一个状态输出done桌准备。而对于接收到的某个消息,仅需一个时钟周期即可判断完成。
状态图。。。
moduletop_module(
inputlogicclk,
inputlogic[7:0]in,
inputlogicreset,//Synchronousreset
outputlogicdone);
typedefenumlogic[1:0]{S0=2'd0,S1=2'd1,S2=2'd2,Done=2'd3}state_def;
//Statetransitionlogic(combinational)
always_combbegin
case(cur_state)
S0:begin
next_state=S1;
end
S1:begin
next_state=S2;
end
S2:begin
next_state=in[3]?S0:Done;
end
Done:begin
end
default:begin
next_state=Done;
end
endcase
end
//Stateflip-flops(sequential)
if(reset)begin
cur_state<= Done ;
        end
        else begin
        end
    end
    // Output logic
    assign done = (cur_state == S2) ;
endmodule
注意图中无波形。
这一题就结束了。
Problem 133-Fsm_ps2data
题目说明
现在,已经写了一个PS/2接口的状态机,该状态机可以标识PS/2字节流中的三字节消息。请在这个状态机中添加一条数据路径,该数据路径可以在接收数据包的同时输出24bits(3字节)的消息(out_bytes[23:16]为第一字节,out_bytes[15:8]为第二字节,以此类推)。
当发出接收完成信号done时,out_bytes必须是有效的,其他时候可以输出任何的内容(即不在乎输出什么。)
小提示:使用前一题Problem 134 PS/2 packet parser / Fsm ps2 中的状态机,并添加用于捕捉输入字节的数据路径即可。
图片来自HDLBits
模块端口声明
moduletop_module(
inputclk,
input[7:0]in,
output[23:0]out_bytes,
outputdone);
题目解析
本题在前一题的三个没有输出动作的状态上添加out_bytes等于输入即可完成。值得注意的是状态4可以跳转为状态2,所以状态4也需要对out_bytes赋值。
moduletop_module(
inputlogicclk,
inputlogic[7:0]in,
outputlogicdone);
always_combbegin
case(cur_state)
S0:begin
next_state=S1;
end
S1:begin
next_state=S2;
end
S2:begin
end
Done:begin
end
default:begin
next_state=Done;
end
endcase
end
if(reset)begin
cur_state<= Done ;
        end
        else begin
        end
    end
    // Output logic
    assign out_bytes = done ? out_bytes_temp : 24'd24 ;
    var logic [23:0] out_bytes_temp ;
        if (next_state == S0) begin
            out_bytes_temp[23:16] <= in ;
        end
        else if (next_state == S1) begin
            out_bytes_temp[15:8]  <= in ;
        end
        else if (next_state == S2) begin
            out_bytes_temp[7:0]   <= in ;
        end
    end
endmodule
注意图中无波形。
这一题就结束了。
总结
今天的几道题就结束了,对于状态机的理解还是有益处的,三段式状态机是题目一直推崇的,类似状态机的公示,可以“套”进去。
审核编辑:刘清
  • HDL
    HDL
  • 状态机
  • fsm
    fsm
  • Verilog语言
原文标题:HDLBits: 在线学习 SystemVerilog(十九)-Problem 126-133(状态机二)
文章出处:【微信号:Open_FPGA,微信公众号:OpenFPGA】欢迎添加关注!文章转载请注明出处。
    热点推荐
    Spring状态机的实现原理和使用方法
    说起 Spring 状态机,大家很容易联想到这个状态机和设计模式中状态模式的区别是啥?没错,Spring 状态机就是
    的头像 发表于 12-26 09:39 2469次阅读
    Spring<b class='flag-5'>状态机</b>的实现原理和使用方法
    Verilog状态机+设计实例
    在verilog中状态机的一种很常用的逻辑结构,学习和理解状态机的运行规律能够帮助我们更好地书写代码,同时作为一种思想方法,在别的代码设计中也会有所帮助。 一、简介 在使用过程中我们常说
    的头像 发表于 02-12 19:07 5010次阅读
    Verilog<b class='flag-5'>状态机</b>+设计实例
    玩转Spring状态机
    说起Spring状态机,大家很容易联想到这个状态机和设计模式中状态模式的区别是啥?没错,Spring状态机就是
    的头像 发表于 06-25 14:21 1225次阅读
    玩转Spring<b class='flag-5'>状态机</b>
    状态机高效写法
    状态机高效写法
    发表于 01-21 06:41
    如何写好状态机
    如何写好状态机:状态机是逻辑设计的重要内容,状态机的设计水平直接反应工程师的逻辑功底,所以许多公司的硬件和逻辑工程师面试中,状态机设计几乎是必选题目。本章在引入
    发表于 06-14 19:24 97次下载
    状态机举例
    状态机举例 你可以指定状态寄存器和状态机状态。以下是一个有四种状态的普通状态机。 // Th
    发表于 03-28 15:18 1064次阅读
    状态机代码生成工具
    状态机代码生成工具状态机代码生成工具状态机代码生成工具状态机代码生成工具
    发表于 11-19 15:12 9次下载
    状态机原理及用法
    状态机原理及用法状态机原理及用法状态机原理及用法
    发表于 03-15 15:25 0次下载
    状态机概述 如何理解状态机
    本篇文章包括状态机的基本概述以及通过简单的实例理解状态机
    的头像 发表于 01-02 18:03 1.1w次阅读
    <b class='flag-5'>状态机</b>概述  如何理解<b class='flag-5'>状态机</b>
    浅谈状态机的要素、分类
    说到单片编程,不得不说到状态机状态机做为软件编程的主要架构已经在各种语言中应用,当然包括C语言,在一个思路清晰而且高效的程序中,必然有状态机
    的头像 发表于 10-20 17:27 5292次阅读
    FPGA:状态机简述
    本文目录 前言 状态机简介 状态机分类 Mealy 型状态机 Moore 型状态机 状态机描述 一段式
    的头像 发表于 11-05 17:58 7850次阅读
    FPGA:<b class='flag-5'>状态机</b>简述
    什么是状态机状态机5要素
    玩单片还可以,各个外设也都会驱动,但是如果让你完整的写一套代码时,却无逻辑与框架可言。这说明编程还处于比较低的水平,你需要学会一种好的编程框架或者一种编程思想!比如模块化编程、状态机编程、分层思想
    的头像 发表于 07-27 11:23 2.1w次阅读
    什么是<b class='flag-5'>状态机</b>?<b class='flag-5'>状态机</b>5要素
    状态模式(状态机)
    以前写状态机,比较常用的方式是用 if-else 或 switch-case,高级的一点是函数指针列表。最近,看了一文章《c语言设计模式–状态模式(状态机)》(来源:embed linux
    发表于 12-16 16:53 9次下载
    <b class='flag-5'>状态</b>模式(<b class='flag-5'>状态机</b>)
    labview状态机分享
    labview状态机
    发表于 10-31 15:50 18次下载
    什么是状态机状态机的种类与实现
    状态机,又称有限状态机(Finite State Machine,FSM)或米利状态机(Mealy Machine),是一种描述系统状态变化的模型。在芯片设计中,
    的头像 发表于 10-19 10:27 1.1w次阅读
    有几种电平转换电路,适用于不同的场景
    一.起因一般在消费电路的元器件之间,不同的器件IO的电压是不同的,常规的有5V,3.3V,1.8V等。当器件的IO电压一样的时候,比如都是5V,都是3.3V,那么其之间可以直接通讯,比如拉中断,I2Cdata/clk脚双方直接通讯等。当器件的IO电压不一样的时候,就需要进行电平转换,不然无法实现高低电平的变化。二.电平转换电路常见的有几种电平转换电路,适用于
    张飞实战电子官方
    21小时前
    194
    瑞萨RA8系列教程 | 基于 RASC 生成 Keil 工程
    对于不习惯用 e2 studio 进行开发的同学,可以借助 RASC 生成 Keil 工程,然后在 Keil 环境下愉快的完成开发任务。
    RA生态工作室
    05-01 10:00
    405
    共赴之约 | 第二十七届中国北京国际科技产业博览会圆满落幕
    作为第二十七届北京科博会的参展方,芯佰微有幸与800余家全球科技同仁共赴「科技引领创享未来」之约!文章来源:北京贸促5月11日下午,第二十七届中国北京国际科技产业博览会圆满落幕。本届北京科博会主题为“科技引领创享未来”,由北京市人民政府主办,北京市贸促会,北京市科委、中关村管委会,北京市经济和信息化局,北京市知识产权局和北辰集团共同承办。5万平方米的展览云集
    芯佰微电子
    1天前
    449
    道生物联与巍泰技术联合发布 RTK 无线定位系统:TurMass™ 技术与厘米级高精度定位的深度融合
    道生物联与巍泰技术联合推出全新一代 RTK 无线定位系统——WTS-100(V3.0 RTK)。该系统以巍泰技术自主研发的 RTK(实时动态载波相位差分)高精度定位技术为核心,深度融合道生物联国产新兴窄带高并发 TurMass™ 无线通信技术,为室外大规模定位场景提供厘米级高精度、广覆盖、高并发、低功耗、低成本的一站式解决方案,助力行业智能化升级。
    道生物联
    1天前
    390
    智能家居中的清凉“智”选,310V无刷吊扇驱动方案--其利天下
    炎炎夏日,如何营造出清凉、舒适且节能的室内环境成为了大众关注的焦点。吊扇作为一种经典的家用电器,以其大风量、长寿命、低能耗等优势,依然是众多家庭的首选。而随着智能控制技术与无刷电机技术的不断进步,吊扇正朝着智能化、高效化、低噪化的方向发展。那么接下来小编将结合目前市面上的指标,详细为大家讲解其利天下有限公司推出的无刷吊扇驱动方案。▲其利天下无刷吊扇驱动方案一
    其利天下技术
    05-10 16:29
    824
    电源入口处防反接电路-汽车电子硬件电路设计
    一、为什么要设计防反接电路电源入口处接线及线束制作一般人为操作,有正极和负极接反的可能性,可能会损坏电源和负载电路;汽车电子产品电性能测试标准ISO16750-2的4.7节包含了电压极性反接测试,汽车电子产品须通过该项测试。二、防反接电路设计1.基础版:二极管串联二极管是最简单的防反接电路,因为电源有电源路径(即正极)和返回路径(即负极,GND),那么用二极
    张飞实战电子官方
    05-09 19:34
    838
    半导体芯片需要做哪些测试
    首先我们需要了解芯片制造环节做⼀款芯片最基本的环节是设计->流片->封装->测试,芯片成本构成⼀般为人力成本20%,流片40%,封装35%,测试5%(对于先进工艺,流片成本可能超过60%)。测试其实是芯片各个环节中最“便宜”的一步,在这个每家公司都喊着“CostDown”的激烈市场中,人力成本逐年攀升,晶圆厂和封装厂都在乙方市场中“叱咤风云”,唯独只有测试显
    汉通达
    05-09 10:02
    782
    解决方案 | 芯佰微赋能示波器:高速ADC、USB控制器和RS232芯片——高性能示波器的秘密武器!
    示波器解决方案总述:示波器是电子技术领域中不可或缺的精密测量仪器,通过直观的波形显示,将电信号随时间的变化转化为可视化图形,使复杂的电子现象变得清晰易懂。无论是在科研探索、工业检测还是通信领域,示波器都发挥着不可替代的作用,帮助工程师和技术人员深入剖析电信号的细节,精准定位问题所在,为创新与发展提供坚实的技术支撑。一、技术瓶颈亟待突破性能指标受限:受模拟前端
    芯佰微电子
    05-09 10:36
    1.5k
    硬件设计基础----运算放大器
    1什么是运算放大器运算放大器(运放)用于调节和放大模拟信号,运放是一个内含多级放大电路的集成器件,如图所示:左图为同相位,Vn端接地或稳定的电平,Vp端电平上升,则输出端Vo电平上升,Vp端电平下降,则输出端Vo电平下降;右图为反相位,Vp端接地或稳定的电平,Vn端电平上升,则输出端Vo电平下降,Vn端电平下降,则输出端Vo电平上升2运算放大器的性质理想运算
    张飞实战电子官方
    05-08 19:34
    594
    ElfBoard技术贴|如何调整eMMC存储分区
    ELF 2开发板基于瑞芯微RK3588高性能处理器设计,拥有四核ARM Cortex-A76与四核ARM Cortex-A55的CPU架构,主频高达2.4GHz,内置6TOPS算力的NPU,这一设计让它能够轻松驾驭多种深度学习框架,高效处理各类复杂的AI任务。
    ElfBoard
    05-08 15:01
    1.1k
    米尔基于MYD-YG2LX系统启动时间优化应用笔记
    1.概述MYD-YG2LX采用瑞萨RZ/G2L作为核心处理器,该处理器搭载双核Cortex-A55@1.2GHz+Cortex-M33@200MHz处理器,其内部集成高性能3D加速引擎Mail-G31GPU(500MHz)和视频处理单元(支持H.264硬件编解码),16位的DDR4-1600/DDR3L-1333内存控制器、千兆以太网控制器、USB、CAN、
    米尔电子
    05-08 08:07
    395
    运放技术——基本电路分析
    虚短和虚断的概念由于运放的电压放大倍数很大,一般通用型运算放大器的开环电压放大倍数都在80dB以上。而运放的输出电压是有限的,一般在10V~14V。因此运放的差模输入电压不足1mV,两输入端近似等电位,相当于“短路”。开环电压放大倍数越大,两输入端的电位越接近相等。“虚短”是指在分析运算放大器处于线性状态时,可把两输入端视为等电位,这一特性称为虚假短路,简称
    张飞实战电子官方
    05-07 19:32
    547
    飞凌嵌入式携手中移物联,谱写全国产化方案新生态
    4月22日,飞凌嵌入式“2025嵌入式及边缘AI技术论坛”在深圳成功举办。中移物联网有限公司(以下简称“中移物联”)携OneOS操作系统与飞凌嵌入式共同推出的工业级核心板亮相会议展区,操作系统产品部高级专家严镭受邀作《OneOS工业操作系统——助力国产化智能制造》主题演讲。
    飞凌嵌入式
    05-07 11:26
    1.7k
    ATA-2022B高压放大器在螺栓松动检测中的应用
    实验名称:ATA-2022B高压放大器在螺栓松动检测中的应用实验方向:超声检测实验设备:ATA-2022B高压放大器、函数信号发生器,压电陶瓷片,数据采集卡,示波器,PC等实验内容:本研究基于振动声调制的螺栓松动检测方法,其中低频泵浦波采用单频信号,而高频探测波采用扫频信号,利用泵浦波和探测波在接触面的振动声调制响应对螺栓的松动程度进行检测。通过螺栓松动检测
    Aigtek安泰电子
    05-06 18:44
    1.1k
    MOS管驱动电路——电机干扰与防护处理
    此电路分主电路(完成功能)和保护功能电路。MOS管驱动相关知识:1、跟双极性晶体管相比,一般认为使MOS管导通不需要电流,只要GS电压(Vbe类似)高于一定的值,就可以了。MOS管和晶体管向比较c,b,e—–>d(漏),g(栅),s(源)。2、NMOS的特性,Vgs大于一定的值就会导通,适合用于源极接地时的情况(低端驱动),只要栅极电压达到4V或10V就可以
    张飞实战电子官方
    05-06 19:34
    574
