PowerInt SID1183K单路1700V IGBT和MOSFET驱动方案
电子工程师 作者:工程师陈翠 2018-07-22 07:09 6160次阅读
PowerInt公司的SID1183K是采用eSOP封装的单路1700V IGBTMOSFET驱动器,栅极峰值驱动电流高达8A,集成的FluxLink™在初级和次级间提供电隔离,高达75kHz开关频率,传输时延260ns,传输时延抖动±5 ns,工作温度-40℃ 到125℃,主要用在通用和伺服驱动,UPS,太阳能,焊接逆变器和电能源。本文介绍了SID1183K产品亮点,功能框图,应用电路以及采用scaLE™- iDriver SID1183K通用基板参考设计RDHP-1702主要特性,电路图,材料清单和PCB设计图。
The SID1183K is a single channel IGBT and MOSFET driver in an eSOP package. Galvanic isolation is provided by Power Integrations’ innovative solid insulator FluxLink technology. The up to 8 A peak output drive current enables the product to drive devices up to 600 A without requiring any additional active components. For gate drive requirements that exceed the stand-alone capability of the SID1183K, an external booster may be added. Stable positive and negative voltages for gate control are provided by one unipolar isolated voltage source.
Additional features are short-circuit protection (DESAT) with Advanced Soft Shut Down (ASSD), undervoltage lock-out (UVLO) for primary-side and secondary-side and rail-to-rail output with temperature and process compensated output impedance guarantee safe operation even in harsh conditions.
Controller (PWM and fault) signals are compatible with 5 V CMOS logic, which may also be adjusted to 15 V levels by using external resistor divider.
SID1183K产品亮点:
Highly Integrated, Compact Footprint
Split outputs providing up to 8 A peak drive current
Integrated FluxLink™ technology providing galvanic isolation between primary-side and secondary-side
Rail-to-rail stabilized output voltage
Unipolar supply voltage for secondary-side
Suitable for 1700 V IGBT and MOSFET switches
Up to 75 kHz switching frequency
Low propagation delay time 260 ns
Propagation delay jitter ±5 ns
-40℃ to 125℃ operating ambient temperature
High common-mode transient immunity
eSOP package with 9.5 mm creepage and clearance distances
Advanced Protection / Safety Features
Undervoltage lock-out protection for primary and secondary-side (UVLO) and fault feedback
Short-circuit protection using VCE SAT monitoring and fault feedback
Full Safety and Regulatory Compliance
100% production partial discharge test
100% production HIPOT compliance testing at 6 kV RMS 1 s
Basic insulation meets VDE 0884-10
Green Package
Halogen free and RoHS compliant
SID1183K应用:
General purpose and servo drives
UPS, solar, welding inverters and power supplies
图1.SID1183K功能框图
图2.SID1183K典型应用电路图
图3.SID1183K应用电路图:采用电阻网络去饱和检测
图4.SID1183K应用电路图:采用二极管去饱和检测
采用SCALE™- iDriver SID1183K通用基板参考设计RDHP-1702
This application proposal provides a circuit design for a general purpose base board for driving various IGBTpower modules.
The design is proposed for the following application conditions:
 General purpose applications and IGBT power modules
 Adaptations such as adjustment of gate resistors can easily be done
 Up to 8 A peak gate current
 Up to 1 W per channel
通用基板参考设计RDHP-1702主要特性:
 Suitable for IGBT power modules in various housings such as 17 mm dual, 17 mm six-pack,
 62 mm, PrimePACK™, etc. with a maximum blocking voltage of 1700 V
 Short-circuit detection with Advanced Soft Shut Down (ASSD)
 Electrical command inputs and status outputs
 0 V / 5 V command input logic
 0 V / 5 V status output logic
 Minimum pulse suppression
 Interlock of command inputs
 5 V supply voltage
 Single PCB solution with soldered-in gate driver IC
Summary and Features
 Up to 1200 V DC-link voltage
 Electrical interfaces
 Basic Active Clamping
图5.通用基板参考设计RDHP-1702外形图
图6.通用基板参考设计RDHP-1702电路形图
通用基板参考设计RDHP-1702材料清单:
图7.通用基板参考设计RDHP-1702PCB设计图(顶层)
图8.通用基板参考设计RDHP-1702PCB设计图(装配图)
图9.通用基板参考设计RDHP-1702PCB设计图(元件装配图)
  • MOSFET驱动器
    热点推荐
    Microchip推出业界耐固性最强的碳化硅功率解决方案取代硅IGBT,现已提供1700V版本
    1700V MOSFET裸片、分立器件和功率模块器件等碳化硅产品阵容扩大了设计人员对效率和功率密度的选择范围
    发表于 07-28 14:47 1701次阅读
    Microchip推出业界耐固性最强的碳化硅功率解决<b class='flag-5'>方案</b>取代硅<b class='flag-5'>IGBT</b>,现已提供<b class='flag-5'>1700V</b>版本
    IGBT模块的选择
    电压(600V、1200V1700V)均对应于常用电网的电压等级。考虑到过载,电网波动,开关过程引起的电压尖峰等因素,通常电力电子设备选择IGBT器件耐压都是直流母线电压的一倍。如果
    发表于 05-10 10:06
    浅谈硅IGBT与碳化硅MOSFET驱动的区别
    MOSFET 的单通道驱动核,可以驱动目前市面上大部分 1700V 以内的管碳化硅 MOSFET
    发表于 02-27 16:03
    驱动1700V IGBT的几种高性能IC选型设计
    驱动1700V IGBT的几种高性能IC 选型设计:通过对几种常用的1700V IGBT 驱动
    发表于 06-19 20:29 39次下载
    驱动1700V_IGBT的几种高性能IC选型设计
    通过对几种常用的1700V IGBT驱动专用集成电路进行详细的分析,对M579系列和CONCEPT公司的2SD系列进行深入的讨论,给出了电气特性参数和内部功能框图,设计了典型应用电路,讨
    发表于 08-11 16:12 76次下载
    华润上华成功开发600V1700V IGBT工艺平台
    华润微电子有限公司旗下的华润上华科技有限公司(后简称“华润上华”)宣布已开发完成600V1700V Planar NPT IGBT(平面非穿通型绝缘栅双极晶体管)以及600V Tre
    发表于 05-29 08:47 2377次阅读
    Littelfuse公司推出首款1700V SiC器件
    Littelfuse公司近期推出了首款1700V SiC 器件,使其在碳化硅(SiC)MOSFET上的产品更加丰富。
    的头像 发表于 09-26 11:32 4083次阅读
    Littelfuse宣布推出1700V、1 Ohm碳化硅MOSFET
    支持电动和混合动力汽车、数据中心和辅助电源等高频、高效电源控制应用 Littelfuse公司,今日宣布推出其首款1700V碳化硅MOSFET LSIC1MO170E1000,扩充了其碳化硅MOSFET器件组合。
    的头像 发表于 11-03 11:02 5187次阅读
    采用1700V SIC MOSFET反激式电源参考设计板介绍
    。 该板有三个输出:+15V、-15V和+24V,输出功率高达62.5W。 该板使用TO-263 7L表面贴装器件(SMD)封装的1700V CoolSiC
    的头像 发表于 09-07 14:11 3284次阅读
    采用<b class='flag-5'>1700V</b> SIC <b class='flag-5'>MOSFET</b>反激式电源参考设计板介绍
    东芝新推出的1200V1700V碳化硅MOSFET模块
    ​东芝电子元件及存储装置株式会社(“东芝”)已推出两款碳化硅(SiC) MOSFET双模块:额定电压为1200V、额定漏极电流为600A的“MG600Q2YMS3”;额定电压为1700V、额定漏极
    的头像 发表于 02-01 20:22 5257次阅读
    瑞能最新推出1700V SiC MOSFET提升效率和输出功率的目的
    相比于硅基高压器件,碳化硅开关器件拥有更小的导通电阻和开关损耗。电力电子系统需要辅助电源部分用来驱动功率器件,为控制系统及散热系统等提供电源。额定电压1700V的SiC MOSFET为高压辅助电源提供了设计更简单,成本更低的解决
    的头像 发表于 08-01 14:18 4022次阅读
    IFX 1700V SiC 62W辅源设计资料
    Infineon,最新1700V的SiC MOSFET产品。62W辅助电源参考设计
    发表于 08-28 11:17 9次下载
    1700V以下大功率IGBT智能驱动模块使用手册
    1700V以下大功率IGBT智能驱动模块使用手册 (采用100%国产化元器件设计) 云南拓普科技出品的系列大功率IGBT智能驱动模块是特别为
    发表于 02-16 15:01 14次下载
    <b class='flag-5'>1700V</b>以下大功率<b class='flag-5'>IGBT</b>智能<b class='flag-5'>驱动</b>模块使用手册
    瞻芯电子推出1700V SiC MOSFET助力高效辅助电源
    11月27日,瞻芯电子开发的首款1700V碳化硅(SiC)MOSFET产品(IV2Q171R0D7Z)通过了车规级可靠性认证(AEC-Q101), 导通电阻标称1Ω,
    的头像 发表于 11-30 09:39 2139次阅读
    瞻芯电子推出<b class='flag-5'>1700V</b> SiC <b class='flag-5'>MOSFET</b>助力高效辅助电源
    SemiQ发布1700V SiC MOSFET新品
    近日,全球碳化硅(SiC)功率半导体领域的知名制造商SemiQ,正式推出了一款专为中压大功率转换应用而设计的1700V SiC MOSFET系列新品。此次发布的QSiC™ 1700V高速平面
    的头像 发表于 01-23 15:46 399次阅读
    【H桥电机驱动电路原理】-学习笔记
    工作原理电路分析这是一个由晶体管构成的H桥电机驱动电路,以下是对其各部分的介绍:核心器件晶体管:电路中使用了PNP型的SS8550(Q5、Q6)和NPN型的SS8050(Q9、Q10、Q13、Q14)。通过不同晶体管的导通与截止组合,实现电机两端电压极性的切换,进而控制电机正反转。比如,当Q5和Q10导通,Q6和Q9截止时,电流从MotorL+流入电机,从M
    张飞实战电子官方
    16小时前
    92
    ATA-2041高压放大器在CFRP板分层缺陷的空耦超声原位测量中的应用
    前言空气耦合超声波技术,作为一种高效且无损的检测方法,近年来在工业领域受到了广泛关注。其独特之处在于利用空气作为耦合介质,无需与被测物体直接接触,即可实现高精度的检测与成像。它能够检测在用CFRP板中的缺陷确保其应用安全,但传统的空气耦合超声方法通常依赖于线性缺陷指数在表征小尺寸缺陷方面无效。此外扫描步长完全限制了它们的成像空间分辨率,导致成像空间分辨率与检
    Aigtek安泰电子
    17小时前
    118
    TwinCAT3 EtherCAT抓包 | 技术集结
    在使用TwinCAT测试EtherCATEOE功能时,我们会发现正常是无法使用Wireshark去进行网络抓包抓取EtherCAT报文的,今天这篇文章就带大家来上手EtherCAT抓包方式。准备环境硬件环境:EtherKit开发板网线一根Type-CUSB线一根软件环境TwinCAT3RT-ThreadstudiowiresharkEtherCATEOE工程
    RT-Thread官方账号
    18小时前
    388
    EtherCAT科普系列(8):EtherCAT技术在机器视觉领域的应用
    机器视觉是基于软件与硬件的组合,通过光学装置和非接触式的传感器自动地接受一个真实物体的图像,并利用软件算法处理图像以获得所需信息或用于控制机器人运动的装置。机器视觉可以赋予机器人及自动化设备获取外界信息并认知处理的能力。机器视觉系统内包含光学成像系统,可以作为自动化设备的视觉器官实现信息的输入,并借助视觉控制器代替人脑实现信息的处理与输出。从而实现赋予自动化
    码灵半导体
    19小时前
    206
    新品 | 26+6TOPS强悍算力!飞凌嵌入式FCU3501嵌入式控制单元发布
    飞凌嵌入式FCU3501嵌入式控制单元基于瑞芯微RK3588处理器开发设计,4xCortex-A76+4xCortex-A55架构,A76主频高达2.4GHz,A55核主频高达1.8GHz,支持8K编解码,NPU算力6TOPS,支持算力卡拓展,可以插装Hailo-8 26TOPS M.2算力卡。
    飞凌嵌入式
    1天前
    351
    接口核心板必选 | 视美泰AIoT-3568SC 、 AIoT-3576SC:小身材大能量,轻松应对多场景设备扩展需求!
    在智能硬件领域,「适配」是绕不开的关键词。无论是小屏设备的”寸土寸金”,还是模具开发的巨额成本,亦或是多产品线兼容的复杂需求,开发者总在寻找一款能「以不变应万变」的核心解决方案。视美泰旗下的AIoT-3568SC与AIoT-3576SC接口核心板系列,可以说是专为高灵活适配场景而生!无需为设备尺寸、模具限制或产品线差异妥协,一块核心板,即可释放无限可能。为什
    视美泰
    1天前
    393
    3核A7+单核M0多核异构,米尔全新低功耗RK3506核心板发布
    近日,米尔电子发布MYC-YR3506核心板和开发板,基于国产新一代入门级工业处理器瑞芯微RK3506,这款芯片采用三核Cortex-A7+单核Cortex-M0多核异构设计,不仅拥有丰富的工业接口、低功耗设计,还具备低延时和高实时性的特点。核心板提供RK3506B/RK3506J、商业级/工业级、512MB/256MBLPDDR3L、8GBeMMC/256
    米尔电子
    1天前
    381
    搭建树莓派网络监控系统:顶级工具与技术终极指南!
    树莓派网络监控系统是一种经济高效且功能多样的解决方案,可用于监控网络性能、流量及整体运行状况。借助树莓派,我们可以搭建一个网络监控系统,实时洞察网络活动,从而帮助识别问题、优化性能并确保网络安全。安装树莓派网络监控系统有诸多益处。树莓派具备以太网接口,还内置了Wi-Fi功能,拥有足够的计算能力和内存,能够在Linux或Windows系统上运行。因此,那些为L
    上海晶珩电子科技有限公司
    1天前
    385
    STM32驱动SD NAND(贴片式SD卡)全测试:GSR手环生物数据存储的擦写寿命与速度实测
    在智能皮电手环及数据存储技术不断迭代的当下,主控 MCU STM32H750 与存储 SD NAND MKDV4GIL-AST 的强强联合,正引领行业进入全新发展阶段。二者凭借低功耗、高速读写与卓越稳定性的深度融合,以及高容量低成本的突出优势,成为大规模生产场景下极具竞争力的数据存储解决方案。
    MK米客方德
    1天前
    439
    芯对话 | CBM16AD125Q这款ADC如何让我的性能翻倍?
    综述在当今数字化时代,模数转换器(ADC)作为连接模拟世界与数字系统的关键桥梁,其技术发展对众多行业有着深远影响。从通信领域追求更高的数据传输速率与质量,到医疗影像领域渴望更精准的疾病诊断,再到工业控制领域需要适应复杂恶劣环境的稳定信号处理,ADC的性能提升成为推动这些行业进步的重要因素。行业现状分析在通信行业,5G乃至未来6G的发展,对基站信号处理提出了极
    芯佰微电子
    2天前
    520
    史上最全面解析:开关电源各功能电路
    01开关电源的电路组成开关电源的主要电路是由输入电磁干扰滤波器(EMI)、整流滤波电路、功率变换电路、PWM控制器电路、输出整流滤波电路组成。辅助电路有输入过欠压保护电路、输出过欠压保护电路、输出过流保护电路、输出短路保护电路等。开关电源的电路组成方框图如下:02输入电路的原理及常见电路1AC输入整流滤波电路原理①防雷电路:当有雷击,产生高压经电网导入电源时
    张飞实战电子官方
    2天前
    462
    有几种电平转换电路,适用于不同的场景
    一.起因一般在消费电路的元器件之间,不同的器件IO的电压是不同的,常规的有5V,3.3V,1.8V等。当器件的IO电压一样的时候,比如都是5V,都是3.3V,那么其之间可以直接通讯,比如拉中断,I2Cdata/clk脚双方直接通讯等。当器件的IO电压不一样的时候,就需要进行电平转换,不然无法实现高低电平的变化。二.电平转换电路常见的有几种电平转换电路,适用于
    张飞实战电子官方
    05-12 19:33
    364
    瑞萨RA8系列教程 | 基于 RASC 生成 Keil 工程
    对于不习惯用 e2 studio 进行开发的同学,可以借助 RASC 生成 Keil 工程,然后在 Keil 环境下愉快的完成开发任务。
    RA生态工作室
    05-01 10:00
    631
    共赴之约 | 第二十七届中国北京国际科技产业博览会圆满落幕
    作为第二十七届北京科博会的参展方,芯佰微有幸与800余家全球科技同仁共赴「科技引领创享未来」之约!文章来源:北京贸促5月11日下午,第二十七届中国北京国际科技产业博览会圆满落幕。本届北京科博会主题为“科技引领创享未来”,由北京市人民政府主办,北京市贸促会,北京市科委、中关村管委会,北京市经济和信息化局,北京市知识产权局和北辰集团共同承办。5万平方米的展览云集
    芯佰微电子
    05-12 13:36
    1.1k
    道生物联与巍泰技术联合发布 RTK 无线定位系统:TurMass™ 技术与厘米级高精度定位的深度融合
    道生物联与巍泰技术联合推出全新一代 RTK 无线定位系统——WTS-100(V3.0 RTK)。该系统以巍泰技术自主研发的 RTK(实时动态载波相位差分)高精度定位技术为核心,深度融合道生物联国产新兴窄带高并发 TurMass™ 无线通信技术,为室外大规模定位场景提供厘米级高精度、广覆盖、高并发、低功耗、低成本的一站式解决方案,助力行业智能化升级。
    道生物联
    05-12 13:40
    840
