--- 产品参数 ---
- 品牌 Agilent安捷伦
- 型号 34972A
- 数量 15
- 发货地 深圳市
--- 产品详情 ---
Agilent 34972A agilent 34972A agilent 34972A agilent 34972A agilent 34972A agilent 34972A
Key Features & Specifications
3-slot LXI data acquisition unit with 6 ½-digit DMM (22-bit) and 8 plug-in modules to choose from
Measures 11 different input signals including temperature with thermocouples, RTDs and thermistors; DC/AC volts or current; 2- or 4-wire resistance; frequency and period
Ac c epts all 34970A switch and control plug-in modules, and is backward c o mpatible with the 34970A SCPI c o mmand set
1Gbit LAN and USB 2.0 for easy connectivity to the PC
USB memory port for data storage or transfer
Graphical Web interface for easy set up and control
Free BenchLink data logger soft w are to create tests without programming
Description
The Keysight 34972A Data Acquisition / Data Logger Switch Unit consists of a 3-slot mainframe with a built-in 6 ½ digit DMM and 8 different switch & control modules. This product features built-in LAN and USB interfaces so you can easily connect to a PC or laptop without needing to purchase additional IO cards or converter interfaces. The intuitive graphical Web interface offers easy remote control over the n e t w ork with per channel measurement configuration, data logging and data monitoring. With the 34972A, there is no c o mputer required for field applications. Use a USB flash drive to upload data logging configurations from BenchLink Data Logger into the 34972A and to transfer large data sets back to the c o mputer. Simply connect the USB stick to your PC when you return and easily import into a spreadsheet or other applications for data analysis.
The 34972A can ac c ept any of the 34970A plug-in modules. With a simple address change the 34972A is easily integrated into an existing test with no wiring or hardware changes. The plug-in modules also feature0n-board screw terminals and relay closure count so you can create a c o mpact data logger, full-featured data acquisition system or low-cost switching unit that is easy to connect, configure and use0n the bench,0n a n e t w ork or in field applications.
为你推荐
FSQ26罗德与施瓦茨的 26.5 GHz 信号分析仪2024-10-16 16:18
产品型号:FSQ26 品牌:罗德与施瓦茨 型号:FSQ26 用途范围:信号分析仪 发货地:深圳市 数量:10 -
Agilent安捷伦U2021XA功率计探头2024-10-16 16:15
产品型号:U2021XA 品牌:Agilent安捷伦 型号:U2021XA 用途范围:功率计探头 发货地:深圳市 数量:10 -
美国安捷伦E4440A频谱分析仪/信号分析仪2024-10-16 16:10
产品型号:E4440A 品牌:安捷伦 型号:E4440A 用途范围:信号分析仪 发货地:深圳市 数量:10 -
安捷伦Agilent E8358A矢量网络分析仪2024-10-16 16:06
产品型号:E8358A 品牌:安捷伦Agilent 型号:E8358A 用途范围:矢量网络分析仪 发货地:深圳市 数量:12 -
罗德与施瓦茨SMIQ06L射频发生器2024-10-16 15:59
产品型号:SMIQ06L 品牌:罗德与施瓦茨 型号:SMIQ06L 用途范围:射频发生器 发货地:深圳市 数量:10 -
Agilent安捷伦N8481A功率传感器2024-10-16 14:10
产品型号:N8481A 品牌: Agilent安捷伦 型号:N8481A 用途范围:功率传感器 发货地:深圳市 数量:10 -
FLUKE福禄克5820A示波器校准仪2024-10-16 14:07
产品型号:5820A 品牌:FLUKE福禄克 型号:5820A 用途范围:示波器校准仪 数量:10 发货地:深圳市 -
安捷伦Agilent MSO9404A示波器2024-10-16 14:04
产品型号:MSO9404A 品牌:安捷伦Agilent 型号:MSO9404A 用途范围:示波器 发货地:深圳市 数量:10 -
Agilent 安捷伦34908A数据采集卡2024-10-16 14:02
产品型号:34908A 品牌:Agilent 安捷伦 型号:34908A 用途范围:数据采集卡 数量:10 发货地:深圳市 -
34970A Agilent安捷伦数据采集仪2024-10-16 13:59
产品型号:34970A 品牌:Agilent安捷伦 型号:34970A 用途范围:数据采集仪 发货地:深圳市 数量:10
