--- 产品参数 ---
- 主芯片 Amlogic S905X3 四核Cortex-A55 (2
- GPU Mali-G31 GPU图形处理器
- 内存 4GB LPDDR4内存
- 板载存储 16GB eMMC 板载存储.
- 网口 1 GbE 千兆网口
--- 产品详情 ---
Banana Pi BPI-M5是新一代单板计算机设计,采用Amlogic S905X3四核Cortex-A55 (2.0xxGHz)处理器。MP2 GPU(650Mhz)。支持4GB LPDDR4和16G eMMC板载存储。它有4个USB 3.0端口,1个千兆网口。 905X3是晶晨半导体旗下最新的8K智能家庭影音芯片,采用四颗64位ARM A55架构 CPU芯片,集成G31图形处理器,支持4K视频解码和4K视频输出,运行开放的安卓9.0系统和Linux系统。
硬件接口示意图:
硬件规格:
香蕉派BPI-M5 硬件规格表 | |||
CPU | Amlogic S905X3 Quad-Core Cortex-A55 (2.0xxGHz) | ||
GPU | Mali-G31 MP2 GPU with 4 x Execution Engines (650Mhz) | ||
Memory | 4 GB LPDDR4 | ||
Storage | MicroSD slot with support for up to 256GB expansion and 16G eMMC flash with support for up to 64GB | ||
Network | 10/100/1000 Mbit/s Ethernet | ||
Video Output(s) | 1 x HDMI 2.0 (up to 4K@60Hz with HDR, CEC, EDID) | ||
Audio Output(s) | 3.5mm jack and 1 x HDMI digital output | ||
USB ports | USB 3.0 PORT (x4) | ||
GPIO | 40 Pin Header : GPIO (x28) and Power (+5V, +3.3V and GND). GPIO pins can be used for UART, I2C, SPI or PWM | ||
Switches | Reset, Power and U-boot | ||
LED | Power Status and Activity status | ||
Power Source | 5 volt @3A via Micro USB (TYPE C) | ||
Size & Weight | 92x60mm, 48g | ||
OS | Android and Linux |
BPI-M2 Pro ,BPI-M5 , Odroid C4 , 树莓派4 规格比较表
BPI-M2 Pro VS BPI-M5 VS Odroid C4 VS RPI 4 | |||||
香蕉派 BPI-M2 Pro | 香蕉派 BPI-M5 | Odroid C4 | 树莓派 4 | ||
Processor | Amlogic S905X3 Quad-Core Cortex-A55 ARMv8.2-A 64-bit 1.5GHz | Amlogic S905X3 Quad-Core Cortex-A55 ARMv8.2-A 64-bit 1.5GHz | Amlogic S905X3 Quad-Core Cortex-A55 ARMv8.2-A 64-bit 1.5GHz | Broadcom BCM2711, Quad core Cortex-A72 (ARM v8) 64-bit SoC @ 1.5GHz | |
GPU | Mali-G31 MP2 GPU | Mali-G31 MP2 GPU | Mali-G31 MP2 GPU | Broadcom VideoCore VI | |
RAM | 2GB LPDDR4 | 4GB LPDDR4 | DDR4 4GiB with 32-bit bus width | 2GB, 4GB or 8GB LPDDR4-3200 SDRAM | |
Storage | micro SD card slot & 16GB eMMC flash on board | micro SD card slot & 16GB eMMC flash on board | micro SD card slot , eMMC connector for option | micro SD card slot, non EMMC | |
Network | 1 GbE ,WiFi&BT5.0 onbard | GbE ,Optional WiFi USB dongle | GbE | GbE, 2.4 GHz and 5.0 GHz IEEE 802.11ac wireless, Bluetooth 5.0, BLE | |
Video Output | 1 x HDMI 2.1 (up to 4K@60Hz with HDR, CEC, EDID) | 1 x HDMI 2.1 (up to 4K@60Hz with HDR, CEC, EDID) | 1 x HDMI 2.1 (up to 4K@60Hz with HDR, CEC, EDID) | 2 × micro-HDMI 2.0 | |
Audio Output | 1 x HDMI digital output | 3.5mm jack and 1 x HDMI digital output | Optional SPDIF optical output | 3.5 mm analogue audio-video jack | |
DSI | N/A | N/A | N/A | 2-lane MIPI DSI display port | |
CSI | N/A | N/A | N/A | 2-lane MIPI CSI camera port | |
USB | USB 3.0 x 2 1 Micro USB 2.0 | USB 3.0 x 4 TYPE C | USB 3.0 x 4, 1 x Micro USB 2.0 port (OTG) | 2 USB 3.0 ports; 2 USB 2.0 ports; | |
Power | 5 volt @3A via DC power | 5 volt @3A via Micro USB (TYPE C) | 1 x DC power jack (Outer diameter : 5.5mm, inner diameter : 2.1mm) | 5V DC via USB-C connector (minimum 3A*) | |
IR | Yes | Yes | Yes | N/A | |
GPIO | 40 Pin Header : GPIO (x28) and Power (+5V, +3.3V and GND). | 40 Pin Header : GPIO (x28) and Power (+5V, +3.3V and GND). | 40 x GPIO pins | 40-pin GPIO header, populated | |
Button | Reset, user and U-boot | Reset, user and U-boot | N/A | N/A | |
LED | Power Status and Activity status | Power Status and Activity status | Power Status and Activity status | Power Status and Activity status | |
Dimensions & weight | 65mm x 65mm,58g | 85mm x 56mm, 48g | 85mm x 56mm 59g | 88 mm × 58 mm, 46 g | |
System Support | Linux & Android | Linux & Android | Linux & Android | Linux & Android |
Online wiki development document: https://wiki.banana-pi.org/Banana_Pi_BPI-M5
为你推荐
Banana Pi BPI-M5 Pro Rockchip RK3576 开源硬件开发板2024-07-11 18:49
产品型号:BPI-M5 Pro 主芯片:RK3576 内存:4G-32G -
香蕉派BPI-F3是一款工业级 8核RISC-V开源硬件开发板,它采用进迭时空(SpacemiT) K1 8核RISC-V芯片设计2024-07-11 18:45
产品型号:BPI-F3 主芯片:进迭时空(SpacemiT) K1 内存:2-16G eMMC:32 -
香蕉派 BPI-CM5计算机模组,采用Amlogic A311D2芯片方案,兼容树莓派 CM4模组底板2023-11-30 17:07
产品型号:BPI-CM5计算机模组 主控:Amlogic A311D2 内存:4g eMMC:8-128G -
香蕉派 BPI-CM4计算机模组,采用Amlogic A311D芯片方案,兼容树莓派 CM4模组2023-11-30 17:05
产品型号:BPI-CM4计算机模组 主控:Amlogic A311D 内存:4 gb LPDDR4 eMMC:16G eMMC flash(最大128G) -
Banana Pi BPI-CM2计算机模组,采用瑞芯微RK3568方案,兼容树莓派 CM4模组底板2023-11-30 17:02
产品型号:BPI-CM2计算机模组 主控:RK3568 内存:2-8G eMMC :8-128G -
Banana Pi BPI-R3 Mini 开源路由器开发板采用 联发科MT7986(Filogic 830)芯片设计,支持Wi-Fi 6,2个2.5GbE网口2023-11-30 16:06
产品型号:BPI-R3 Mini 主控:联发科MT7986(Filogic 830) 内存:2G eMMC:8G -
香蕉派 BPI-R4 Wifi 7开源路由器开发板采用联发科 MT7988A 芯片设计,板载4G内存和8G eMMC2023-11-30 16:01
产品型号:BPI-R4开源路由器 主控:联发科MT7988A 内存:4G eMMC:8G -
香蕉派 BPI-Wifi6 路由器采用创耀科技TR6560 + TR5220 wifi 方案设计2023-11-30 15:57
产品型号:BPI-Wifi6 主控:TR6560 + TR5220 网口:5 无线:wifi6 -
香蕉派 BPI-P2 Pro物联网开发板采用瑞芯微RK3308芯片设计2023-11-30 15:52
产品型号:BPI-P2 Pro 主控:RK3308 内存:512 eMMC:8G PoE:PoE网络供电 -
Banana Pi BPI-M4 Zero单板计算机采用全志H618芯片方案设计,板载1GB DDR3 RAM内存2023-11-30 15:46
产品型号:BPI-M4 Zero 主控:全志H618 内存:2G eMMC:8G
Banana Pi BPI-M4 Berry采用全志H618芯片方案设计2024-11-20 01:05
Banan Pi BPI-M4 Berry 全志科技H618开发板烧录镜像教程2024-07-11 18:56
Banana Pi BPI-M4 Berry创建热点和设置静态IP2024-07-11 18:41
Banana Pi 推出基于 RISC-V 芯片构建的八核边缘 AI 开发板:BPI-F32024-07-11 18:36
Banana Pi BPI-M7 RK3588开发板在 Linux 上检查 Rockchip NPU 使用情况2024-07-11 18:28
快速上手Banana Pi BPI-M4 Zero 全志科技H618开源硬件开发开发板2023-11-30 14:42
Banana Pi最新的路由器板BPI-R4上市销售,基于MediaTek MT7988A2023-11-30 14:40
Banana Pi [BPi-R3-Mini] 产品和主线 ImmortalWrt 固件支持2023-11-30 14:38
Banana Pi BPI-M4 Berry 全志H618开源开发板低温环境测试启动和运行2023-11-30 14:36
Banana Pi BPI-M6(Raspberry Pi 5 替代品)初始设置及固件烧录2023-11-09 09:24
Banana Pi推出基于龙芯2K1000LA处理器的信创工业控制开发平台2023-09-04 09:40
BananaPi BPI-6202工业控制板全志科技A40i、24V DC输入、RS485接口2023-09-04 09:38
Banana Pi BPI-R4采用Filogic 880芯片,Wifi7路由器 旨在成为家庭网络项目的核心2023-09-04 09:36
基于瑞芯微Rockchip RK3568/RK3588的全国产化替换方案2022-11-30 14:15
比派电器高速吹风机(高速风筒)直流无刷电机整体解决方案2022-09-01 15:29
峰岹科技高速直流无刷电机控制整体解决方案2022-09-01 15:26
香蕉派 BPI-M2+ 物联网开发板采用全志H3芯片设计,1GB DDR3 RAM ,8GB eMMC2022-09-01 14:07
香蕉派 BPI-M4 单板计算机采用 Realtek RT1395芯片方案设计,1G/2G RAM ,8GB eMMC2022-09-01 14:01
香蕉派 BPI-P2 Zero物联网全志H3(可选H2+/H5)芯片设计,PoE网络供电,512M RAM ,8GB eMMC2022-09-01 12:18
