--- 产品参数 ---
- 主控芯片 Realtek RTD1395 ARM Cortex-A53
- GPU Mali 470 MP4 GPU OpenGL ES 1.1
- 内存 板载 1 GB DDR4 (2 GB可选)
- 存储 8G eMMC flash (最大64 GB)
- PoE 支持PoE供电
- 无线网络和蓝牙 Wi-Fi 802.11 b/g/n/AC + 蓝牙 4.2
--- 产品详情 ---
Banana Pi BPI-M4 4核64位开发板,采用RTD1395芯片设计 ,为banana pi 团队最新的Banana Pi BPI-M4具有与Raspberry Pi Model B 一样的尺寸,但搭载更强悍的Realtek RTD1395 SoC,并支援PoE网路线供电与M.2插槽等功能,使用上更具弹性。
关键特性:
1,Realtek RTD1395 ARM Cortex-A53 Quad-Core 64 Bit
2,Mali 470 MP4 GPU OpenGL ES 1.1/2.0 H.264 H.265,2K4K
3,Onboard1 GB DDR4 (option 2 GB)
4,8G eMMC flash (max 64 GB)
5,10/100 Mbit/s Ethernet and RTL8821 module support Wi-Fi 802.11 b/g/n/AC + Bluetooth 4.2
6,USB 2.0 TYPE C
7,M.2 Key E slot PCIE 2.0 and USB 2.0
8,PoE 网络供电功能支持
硬件接口:
硬件规格:
Banana pi BPI-M4 硬件规格列表 | |||
主控芯片 | Realtek RTD1395 ARM Cortex-A53 Quad-Core 64 Bit | ||
GPU图形 | Mali 470 MP4 GPU OpenGL ES 1.1/2.0 | ||
内存 | 1 GB DDR4 (option 2 GB) | ||
Storage | MicroSD slot with support for up to 256GB expansion and 8G eMMC flash with support for up to 64GB | ||
网络 | 10/100 Mbit/s Ethernet + Wi-Fi 802.11 b/g/n/AC + Bluetooth 4.2 | ||
Video Output(s) | HDMI port and multi-channel audio output support 1080P H.264 H.265 2K/4K | ||
Audio Output(s) | 3.5mm jack and HDMI | ||
PCIE | M.2 Key E slot PCIE 2.0 and USB 2.0 | ||
USB ports | USB 2.0 PORT (x4), USB 2.0 TYPE C(x1) | ||
GPIO | 40 Pin Header : GPIO (x28) and Power (+5V, +3.3V and GND). GPIO pins can be used for UART, I2C, SPI or PWM | ||
Switches | Reset, Power and U-boot | ||
LED | Power Status and Activity status | ||
Power Source | 5 volt @2A via Micro USB (TYPE C) or PoE support | ||
Size & Weight | 92x60mm, 48g | ||
OS | Android and Linux |
为你推荐
Banana Pi BPI-M5 Pro Rockchip RK3576 开源硬件开发板2024-07-11 18:49
产品型号:BPI-M5 Pro 主芯片:RK3576 内存:4G-32G -
香蕉派BPI-F3是一款工业级 8核RISC-V开源硬件开发板,它采用进迭时空(SpacemiT) K1 8核RISC-V芯片设计2024-07-11 18:45
产品型号:BPI-F3 主芯片:进迭时空(SpacemiT) K1 内存:2-16G eMMC:32 -
香蕉派 BPI-CM5计算机模组,采用Amlogic A311D2芯片方案,兼容树莓派 CM4模组底板2023-11-30 17:07
产品型号:BPI-CM5计算机模组 主控:Amlogic A311D2 内存:4g eMMC:8-128G -
香蕉派 BPI-CM4计算机模组,采用Amlogic A311D芯片方案,兼容树莓派 CM4模组2023-11-30 17:05
产品型号:BPI-CM4计算机模组 主控:Amlogic A311D 内存:4 gb LPDDR4 eMMC:16G eMMC flash(最大128G) -
Banana Pi BPI-CM2计算机模组,采用瑞芯微RK3568方案,兼容树莓派 CM4模组底板2023-11-30 17:02
产品型号:BPI-CM2计算机模组 主控:RK3568 内存:2-8G eMMC :8-128G -
Banana Pi BPI-R3 Mini 开源路由器开发板采用 联发科MT7986(Filogic 830)芯片设计,支持Wi-Fi 6,2个2.5GbE网口2023-11-30 16:06
产品型号:BPI-R3 Mini 主控:联发科MT7986(Filogic 830) 内存:2G eMMC:8G -
香蕉派 BPI-R4 Wifi 7开源路由器开发板采用联发科 MT7988A 芯片设计,板载4G内存和8G eMMC2023-11-30 16:01
产品型号:BPI-R4开源路由器 主控:联发科MT7988A 内存:4G eMMC:8G -
香蕉派 BPI-Wifi6 路由器采用创耀科技TR6560 + TR5220 wifi 方案设计2023-11-30 15:57
产品型号:BPI-Wifi6 主控:TR6560 + TR5220 网口:5 无线:wifi6 -
香蕉派 BPI-P2 Pro物联网开发板采用瑞芯微RK3308芯片设计2023-11-30 15:52
产品型号:BPI-P2 Pro 主控:RK3308 内存:512 eMMC:8G PoE:PoE网络供电 -
Banana Pi BPI-M4 Zero单板计算机采用全志H618芯片方案设计,板载1GB DDR3 RAM内存2023-11-30 15:46
产品型号:BPI-M4 Zero 主控:全志H618 内存:2G eMMC:8G
Banana Pi BPI-M4 Berry采用全志H618芯片方案设计2024-11-20 01:05
Banan Pi BPI-M4 Berry 全志科技H618开发板烧录镜像教程2024-07-11 18:56
Banana Pi BPI-M4 Berry创建热点和设置静态IP2024-07-11 18:41
Banana Pi 推出基于 RISC-V 芯片构建的八核边缘 AI 开发板:BPI-F32024-07-11 18:36
Banana Pi BPI-M7 RK3588开发板在 Linux 上检查 Rockchip NPU 使用情况2024-07-11 18:28
快速上手Banana Pi BPI-M4 Zero 全志科技H618开源硬件开发开发板2023-11-30 14:42
Banana Pi最新的路由器板BPI-R4上市销售,基于MediaTek MT7988A2023-11-30 14:40
Banana Pi [BPi-R3-Mini] 产品和主线 ImmortalWrt 固件支持2023-11-30 14:38
Banana Pi BPI-M4 Berry 全志H618开源开发板低温环境测试启动和运行2023-11-30 14:36
Banana Pi BPI-M6(Raspberry Pi 5 替代品)初始设置及固件烧录2023-11-09 09:24
Banana Pi推出基于龙芯2K1000LA处理器的信创工业控制开发平台2023-09-04 09:40
BananaPi BPI-6202工业控制板全志科技A40i、24V DC输入、RS485接口2023-09-04 09:38
Banana Pi BPI-R4采用Filogic 880芯片,Wifi7路由器 旨在成为家庭网络项目的核心2023-09-04 09:36
基于瑞芯微Rockchip RK3568/RK3588的全国产化替换方案2022-11-30 14:15
比派电器高速吹风机(高速风筒)直流无刷电机整体解决方案2022-09-01 15:29
峰岹科技高速直流无刷电机控制整体解决方案2022-09-01 15:26
香蕉派 BPI-M2+ 物联网开发板采用全志H3芯片设计,1GB DDR3 RAM ,8GB eMMC2022-09-01 14:07
香蕉派 BPI-M4 单板计算机采用 Realtek RT1395芯片方案设计,1G/2G RAM ,8GB eMMC2022-09-01 14:01
香蕉派 BPI-P2 Zero物联网全志H3(可选H2+/H5)芯片设计,PoE网络供电,512M RAM ,8GB eMMC2022-09-01 12:18
