--- 产品参数 ---
- 主芯片 全志A83T Octa-core 1.8GHz Powerf
- 内存 2 GB LPDDR3 内存
- 存储 8 GB eMMC 存储.
- wifi&BT 板载WiFi & Bluetooth 蓝牙
- HDMI HDMI 高清视频输出
--- 产品详情 ---
Banana PI BPI-M3 是一款8核高性能单板计算机,Banana PI BPI-M3是一款比树莓派更强悍的8核Android 5.1产品。Banana PI BPI-M3 兼容性强大,可以跑android系统,Debian linux,Ubuntu linux, Raspberry Pi系统 和 cubieboard 系统.
Banana PI BPI-M3硬件:1Ghz ARM7 8核处理器,2GB LPDDR3内存,千兆以太网口,2 USB 接口 流畅运行Android5.1。Banana PI BPI-M3体积如信用卡大小,与BPI-M1+尺寸一样,但接口有不同,轻松运行《雷神之锤三:竞技场》这样的游戏,支持2K高清视频输出,GPIO兼容Raspberry PiB+并能运行其ROM Image。
BPI-M3在八核处理器上,采用了全志科技的A83T处理器。全志A83T采用台积电最新的28nm HPC工艺,基于8个ARMCortex-A7 CPU内核,最高频率可达2.0GHz,8核心可同时全速运行;在图像处理方面,A83T沿用A31/A31s的PowerVR SGX544 GPU,运行频率最高可达700MHz左右,图像处理性能十分强劲,确保了极致的游戏体验及UI流畅度。内存方面,DDR工作频率可达800MHz左右,能够流畅完美带动1920×1200高清分辨率屏幕。
硬件接口示意图:
硬件规格:
Banana Pi BPI-M3 硬件规格 | |
CPU | Allwinner A83T ARM Cortex-A7 Octa-Core 1.8 GHz, 512KB L1 cache and 1MB L2 cache |
GPU | PowerVR SGX544MP1 Comply with OpenGL ES 2.0 OpenCL 1x, DX9_3 |
Memory | 2 GB LPDDR3 (shared with GPU) |
Storage | On Board 8GB eMMC Flash, Micro SD-Card slot, SATA 2.0 Port (USB-to-SATA bridge) |
Network | 10/100/1000 Mbit/s Ethernet (Realtek RTL8211E/D) + Wi-Fi 802.11 b/g/n (AP6212) + Bluetooth BT4.0 |
Video Input(s) | A CSI input connector allows for the connection of a designed camera module |
Video Output(s) | HDMI 1.4 (Type A Full), MIPI Display Serial Interface (DSI) for raw LCD Panel |
Audio Input(s) | On board microphone |
Audio Output(s) | 3.5mm jack and HDMI |
USB ports | USB 2.0 PORT (x2), USB OTG (x1) |
Remote | IR Receiver (x1) |
GPIO | 40 Pin Header : GPIO (x28) and Power (+5V, +3.3V and GND). Some of I/O Pin can be used for specific functions as UART, I2C, SPI or PWM |
Switches | Reset, Power and U-boot |
LED | Power Status and 8P8C |
Power Source | 5 volt @2A via DC Power and/or Micro USB (OTG) |
Size & Weight | 92x60mm, 48g |
OS | Android and Linux |
Online development documents: https://wiki.banana-pi.org/Banana_Pi_BPI-M3
为你推荐
Banana Pi BPI-M5 Pro Rockchip RK3576 开源硬件开发板2024-07-11 18:49
产品型号:BPI-M5 Pro 主芯片:RK3576 内存:4G-32G -
香蕉派BPI-F3是一款工业级 8核RISC-V开源硬件开发板,它采用进迭时空(SpacemiT) K1 8核RISC-V芯片设计2024-07-11 18:45
产品型号:BPI-F3 主芯片:进迭时空(SpacemiT) K1 内存:2-16G eMMC:32 -
香蕉派 BPI-CM5计算机模组,采用Amlogic A311D2芯片方案,兼容树莓派 CM4模组底板2023-11-30 17:07
产品型号:BPI-CM5计算机模组 主控:Amlogic A311D2 内存:4g eMMC:8-128G -
香蕉派 BPI-CM4计算机模组,采用Amlogic A311D芯片方案,兼容树莓派 CM4模组2023-11-30 17:05
产品型号:BPI-CM4计算机模组 主控:Amlogic A311D 内存:4 gb LPDDR4 eMMC:16G eMMC flash(最大128G) -
Banana Pi BPI-CM2计算机模组,采用瑞芯微RK3568方案,兼容树莓派 CM4模组底板2023-11-30 17:02
产品型号:BPI-CM2计算机模组 主控:RK3568 内存:2-8G eMMC :8-128G -
Banana Pi BPI-R3 Mini 开源路由器开发板采用 联发科MT7986(Filogic 830)芯片设计,支持Wi-Fi 6,2个2.5GbE网口2023-11-30 16:06
产品型号:BPI-R3 Mini 主控:联发科MT7986(Filogic 830) 内存:2G eMMC:8G -
香蕉派 BPI-R4 Wifi 7开源路由器开发板采用联发科 MT7988A 芯片设计,板载4G内存和8G eMMC2023-11-30 16:01
产品型号:BPI-R4开源路由器 主控:联发科MT7988A 内存:4G eMMC:8G -
香蕉派 BPI-Wifi6 路由器采用创耀科技TR6560 + TR5220 wifi 方案设计2023-11-30 15:57
产品型号:BPI-Wifi6 主控:TR6560 + TR5220 网口:5 无线:wifi6 -
香蕉派 BPI-P2 Pro物联网开发板采用瑞芯微RK3308芯片设计2023-11-30 15:52
产品型号:BPI-P2 Pro 主控:RK3308 内存:512 eMMC:8G PoE:PoE网络供电 -
Banana Pi BPI-M4 Zero单板计算机采用全志H618芯片方案设计,板载1GB DDR3 RAM内存2023-11-30 15:46
产品型号:BPI-M4 Zero 主控:全志H618 内存:2G eMMC:8G
Banana Pi BPI-M4 Berry采用全志H618芯片方案设计2024-11-20 01:05
Banan Pi BPI-M4 Berry 全志科技H618开发板烧录镜像教程2024-07-11 18:56
Banana Pi BPI-M4 Berry创建热点和设置静态IP2024-07-11 18:41
Banana Pi 推出基于 RISC-V 芯片构建的八核边缘 AI 开发板:BPI-F32024-07-11 18:36
Banana Pi BPI-M7 RK3588开发板在 Linux 上检查 Rockchip NPU 使用情况2024-07-11 18:28
快速上手Banana Pi BPI-M4 Zero 全志科技H618开源硬件开发开发板2023-11-30 14:42
Banana Pi最新的路由器板BPI-R4上市销售,基于MediaTek MT7988A2023-11-30 14:40
Banana Pi [BPi-R3-Mini] 产品和主线 ImmortalWrt 固件支持2023-11-30 14:38
Banana Pi BPI-M4 Berry 全志H618开源开发板低温环境测试启动和运行2023-11-30 14:36
Banana Pi BPI-M6(Raspberry Pi 5 替代品)初始设置及固件烧录2023-11-09 09:24
Banana Pi推出基于龙芯2K1000LA处理器的信创工业控制开发平台2023-09-04 09:40
BananaPi BPI-6202工业控制板全志科技A40i、24V DC输入、RS485接口2023-09-04 09:38
Banana Pi BPI-R4采用Filogic 880芯片,Wifi7路由器 旨在成为家庭网络项目的核心2023-09-04 09:36
基于瑞芯微Rockchip RK3568/RK3588的全国产化替换方案2022-11-30 14:15
比派电器高速吹风机(高速风筒)直流无刷电机整体解决方案2022-09-01 15:29
峰岹科技高速直流无刷电机控制整体解决方案2022-09-01 15:26
香蕉派 BPI-M2+ 物联网开发板采用全志H3芯片设计,1GB DDR3 RAM ,8GB eMMC2022-09-01 14:07
香蕉派 BPI-M4 单板计算机采用 Realtek RT1395芯片方案设计,1G/2G RAM ,8GB eMMC2022-09-01 14:01
香蕉派 BPI-P2 Zero物联网全志H3(可选H2+/H5)芯片设计,PoE网络供电,512M RAM ,8GB eMMC2022-09-01 12:18
