--- 产品参数 ---
- 主芯片 瑞芯微(Rockchip RK3568 Quad-core
- GPU Mali-G52 1-Core-2EE
- 内存 2G LPDDR4 内存(可选 4G)
- 存储 16G eMMC 存储( 可选16/32/64G)
- CPIe M.2接口 Mini PCIE 接口 & M.2 key-e 接口
- 硬盘接口 1 SATA 硬盘接口
- SD卡 MicroSD 接口,最多256G SD卡
- 显示屏接口 2 MIPI 显示屏接口 HDMI
- 摄像头接口 1 CSI camera 摄像头接口
- 有线网口 5 10/100/1000 Mb 千兆网口
--- 产品详情 ---
Banana Pi BPI-R2 Pro 开源路由器采用Rockchip RK3568芯片方案设计, 板载2GB LPDDR4内存和16GB eMMC存储,支持2个USB 3.0接口,5千兆网口。M.2 Key-e和mini PCIe接口,2 mipi DSI接口(可通过软件切换LVDS), 1个CSI摄像头接口,1个HDMI输出.支持Android,Linux,OpenWRT系统
BPI-R2 Pro 尺寸接口与
Banana Pi BPI-R2
,可以使用 BPI-R2 外壳.
BPI-R2 Pro 硬件接口示意图:
硬件规格:
Banana Pi R2 Pro | |
CPU | Rockchip RK3568 Quad-core ARM Cortex-A55 CPU 2GHz |
GPU | Mali-G52 1-Core-2EE OpenGL ES3.2 Vu1kn 1.1 OpenCL 2.0 |
Memory | 2G DDR3 SDRAM (option 4G) |
Storage | Onboard 16GB eMMC Flash, Micro SD-Card slot, SATA 2.0 Port,SPI flash |
Network | 5 x 10/100/1000 Mbit/s Ethernet |
Display(s) | 1 HDMI port, 2 DSI interface(1 DSI can change to LVDS by software) |
Camera | 1 CSI camera interfact |
Video decoder(s) | H.265 HEVC/MVC Main10 Profile yuv420@L5.1 up to 4096x2304@60fps,H.264 AVC/MVC Main10 Profile yuv400/yuv420/yuv422/@L5.1 up to 4096x2304@60fps |
Video encoder(s) | H.264/AVC BP/MP/HP@level4.2,up to 1920x1080@100fps, H.265/HEVC MP@level4.1, up to 1920x1080@100fps (4096x4096@10fps with TILE) |
Audio Output(s) | HDMI & I2S & Speaker & Headphone |
USB port | USB 3.0 PORT (x2), micro USB OTG (x1) |
mini PCIE | 1 mini pcie interface & 1 M.2 key-e interface |
Remote | IR Receiver (x1) |
GPIO | 40 Pin Header : GPIO (x28) and Power (+5V, +3.3V and GND). Some of I/O Pin can be used for specific functions as UART, I2C, SPI or PWM |
Switches | Reset button, Power button, U-boot button |
LED | Power Status and 8P8C |
Power Source | 12 volt @2A via DC Power and/or Micro USB (OTG) |
Size & Weight | 148 mm × 100.5mm 100g |
OS | OpenWRT, Linux and others OS |
Online wiki development documents:https://wiki.banana-pi.org/Banana_Pi_BPI-R2_Pro
为你推荐
Banana Pi BPI-M5 Pro Rockchip RK3576 开源硬件开发板2024-07-11 18:49
产品型号:BPI-M5 Pro 主芯片:RK3576 内存:4G-32G -
香蕉派BPI-F3是一款工业级 8核RISC-V开源硬件开发板,它采用进迭时空(SpacemiT) K1 8核RISC-V芯片设计2024-07-11 18:45
产品型号:BPI-F3 主芯片:进迭时空(SpacemiT) K1 内存:2-16G eMMC:32 -
香蕉派 BPI-CM5计算机模组,采用Amlogic A311D2芯片方案,兼容树莓派 CM4模组底板2023-11-30 17:07
产品型号:BPI-CM5计算机模组 主控:Amlogic A311D2 内存:4g eMMC:8-128G -
香蕉派 BPI-CM4计算机模组,采用Amlogic A311D芯片方案,兼容树莓派 CM4模组2023-11-30 17:05
产品型号:BPI-CM4计算机模组 主控:Amlogic A311D 内存:4 gb LPDDR4 eMMC:16G eMMC flash(最大128G) -
Banana Pi BPI-CM2计算机模组,采用瑞芯微RK3568方案,兼容树莓派 CM4模组底板2023-11-30 17:02
产品型号:BPI-CM2计算机模组 主控:RK3568 内存:2-8G eMMC :8-128G -
Banana Pi BPI-R3 Mini 开源路由器开发板采用 联发科MT7986(Filogic 830)芯片设计,支持Wi-Fi 6,2个2.5GbE网口2023-11-30 16:06
产品型号:BPI-R3 Mini 主控:联发科MT7986(Filogic 830) 内存:2G eMMC:8G -
香蕉派 BPI-R4 Wifi 7开源路由器开发板采用联发科 MT7988A 芯片设计,板载4G内存和8G eMMC2023-11-30 16:01
产品型号:BPI-R4开源路由器 主控:联发科MT7988A 内存:4G eMMC:8G -
香蕉派 BPI-Wifi6 路由器采用创耀科技TR6560 + TR5220 wifi 方案设计2023-11-30 15:57
产品型号:BPI-Wifi6 主控:TR6560 + TR5220 网口:5 无线:wifi6 -
香蕉派 BPI-P2 Pro物联网开发板采用瑞芯微RK3308芯片设计2023-11-30 15:52
产品型号:BPI-P2 Pro 主控:RK3308 内存:512 eMMC:8G PoE:PoE网络供电 -
Banana Pi BPI-M4 Zero单板计算机采用全志H618芯片方案设计,板载1GB DDR3 RAM内存2023-11-30 15:46
产品型号:BPI-M4 Zero 主控:全志H618 内存:2G eMMC:8G
Banana Pi BPI-M4 Berry采用全志H618芯片方案设计2024-11-20 01:05
Banan Pi BPI-M4 Berry 全志科技H618开发板烧录镜像教程2024-07-11 18:56
Banana Pi BPI-M4 Berry创建热点和设置静态IP2024-07-11 18:41
Banana Pi 推出基于 RISC-V 芯片构建的八核边缘 AI 开发板:BPI-F32024-07-11 18:36
Banana Pi BPI-M7 RK3588开发板在 Linux 上检查 Rockchip NPU 使用情况2024-07-11 18:28
快速上手Banana Pi BPI-M4 Zero 全志科技H618开源硬件开发开发板2023-11-30 14:42
Banana Pi最新的路由器板BPI-R4上市销售,基于MediaTek MT7988A2023-11-30 14:40
Banana Pi [BPi-R3-Mini] 产品和主线 ImmortalWrt 固件支持2023-11-30 14:38
Banana Pi BPI-M4 Berry 全志H618开源开发板低温环境测试启动和运行2023-11-30 14:36
Banana Pi BPI-M6(Raspberry Pi 5 替代品)初始设置及固件烧录2023-11-09 09:24
Banana Pi推出基于龙芯2K1000LA处理器的信创工业控制开发平台2023-09-04 09:40
BananaPi BPI-6202工业控制板全志科技A40i、24V DC输入、RS485接口2023-09-04 09:38
Banana Pi BPI-R4采用Filogic 880芯片,Wifi7路由器 旨在成为家庭网络项目的核心2023-09-04 09:36
基于瑞芯微Rockchip RK3568/RK3588的全国产化替换方案2022-11-30 14:15
比派电器高速吹风机(高速风筒)直流无刷电机整体解决方案2022-09-01 15:29
峰岹科技高速直流无刷电机控制整体解决方案2022-09-01 15:26
香蕉派 BPI-M2+ 物联网开发板采用全志H3芯片设计,1GB DDR3 RAM ,8GB eMMC2022-09-01 14:07
香蕉派 BPI-M4 单板计算机采用 Realtek RT1395芯片方案设计,1G/2G RAM ,8GB eMMC2022-09-01 14:01
香蕉派 BPI-P2 Zero物联网全志H3(可选H2+/H5)芯片设计,PoE网络供电,512M RAM ,8GB eMMC2022-09-01 12:18
