--- 产品参数 ---
- 27M晶振 7V27000050
- 25M晶振 7V25000027
- 16.667M晶振 7V16600004
- 32M晶振 7V32000035
- 20M晶振 AV20070001
- 14.318M晶振 7V14300001
- 16M晶振 7V16000005
- 20M晶振 7V20000011
- 26M晶振 7V26006001
- 24M晶振 7V24000005
- 24M晶振 7V24000016
- 12M晶振 7V12000018
- 27M晶振 7V27000012
- 24M晶振 7V24000020
- 13M晶振 AV13000001
- 24M晶振 7V24070002
- 38.4M晶振 7V38400001
- 24M晶振 7V24000017
- 12M晶振 7V12006002
- 27M晶振 AV27000003
--- 产品详情 ---
7V26000033 晶振来自台湾晶技的一款外形尺寸仅有3.2*2.5mm的四脚无源晶振,TXC晶振完整型号一共由十个数字字母组成,不同数字代表不同的参数,一个完整的型号包含的参数有晶振的封装尺寸大小,中心频率,晶振电容,频率偏差,工作温度。广瑞泰更多7V系列的晶振型号
7V26000033 | TXC 7V26000033 8PF 10PPM无源贴片晶振四脚封装3.2*2.5 | |
7V27000050 | 无源晶体谐振器7V27000050 27M 10PF 10PPM贴片晶振TXC | |
7V25000027 | TXC 7V25000027 25M 3225无源贴片晶振 | |
7V16600004 | 16.67M 8PF 30PPM 7V16600004无源贴片晶振TXC工厂 | |
7V32000035 | TXC CRYSTAL贴片晶振四脚封装3225 7V32000035 12PF | |
AV20070001 | AV20070001车规贴片晶振20MHZ SMD3225 8PF 20PPM TXC晶振 | |
7V14300001 | 7V14300001 TXC贴片晶振14.318M 3.2*2.5mm 四脚无源晶振 | |
7V16000005 | 16M无源贴片晶振7V16000005 3225 18PF 30PPM TXC晶振 | |
7V20000011 | 7V20000011 20M 8PF 30PPM无源贴片晶振TXC原装 | |
7V26006001 | 26M无源贴片晶振7V26006001 TXC 26M 12pf 10ppm | |
7V24000005 | 7V24000005 24M 9PF 10PPM贴片晶振TXC原装 | |
7V24000016 | TXC 7V24000016 20PF 30PPM 24M贴片晶振无源封装3225 | |
7V12000018 | TXC晶振代理7V12000018 20PF 30PPM 12M无源贴片晶振CRYSTAL | |
7V27000012 | 7V27000012 27M影像贴片晶振SMD3.2*2.5mm 12PF 30PPM TXC无源 | |
7V24000020 | TXC 24MHZ SMD3225 12PF 20PPM无源贴片晶振7V24000020 | |
AV13000001 | TXC石英晶振13M AV13000001 12PF 20PPM无源贴片晶振 | |
7V24070002 | 7V24070002 10PF 10PPM 24M TXC无源贴片晶振CRYSTAL | |
7V38400001 | TXC 7V38400001 38.4M石英贴片晶振四脚封装3.2*2.5mm尺寸 | |
7V24000017 | TXC 7V24000017 24MHZ SMD3225四脚贴片晶振3.2*2.5mm尺寸 | |
7V12006002 | 12MHZ 3225 TXC四脚贴片晶振黑色外观7V12006002 | |
AV27000003 | AV27000003 27MHZ 20PF 20PPM TXC车规贴片晶振耐高温 |
为你推荐
NDK汽车级贴片晶振NX3225GB-20MHZ-EXS00A-CG009412023-12-07 11:48
产品型号:NX3225GB-20MHZ-EXS00A-CG00941 品牌:NDK 中文:日本电波 系列:NX3225GB 封装:SMD3225 长度:3.2mm -
两脚车规级晶振NX3225GD-8.192M-STD-CRA-3耐高温NDK原装2023-12-07 11:00
产品型号:NX3225GD-8.192M-STD-CRA- 品牌:NDK 中文名称:日本电波 系列:NX3225GD 中心频率:8.192MHZ 封装:SMD3225 -
NX1610SA 32.768K EXS00A-MU00658无源贴片晶振日本NDK 6PF XTAL2023-12-06 15:41
产品型号:NX1610SA 32.768K EXS00A-MU0065 规格:SMD1610 长度:1.6mm 宽度:1.0mm 包装方式:编带盘装 包装数量:3K/盘 -
NDK无源晶振NX2016SA-16MHZ-EXS00A-CS07826 8PF原装进口2023-12-06 15:31
产品型号:NX2016SA-16MHZ-EXS00A-CS07826 规格:SMD2016 长度:2.0mm 宽度:1.6mm 频率:16MHZ 负载电容:8PF -
TXC无源贴片晶振8.000MHZ xtal SMD3225车规级A3080000032023-08-21 11:09
产品型号:A308000003 品牌:晶技TXC 频率:8MHZ 封装:SMD3225 系列:A3 包装:K/R -
32.768K石英晶振citizen西铁城无源晶体CMR200T32768DZFT2023-05-25 11:50
产品型号:CMR200T32768DZFT 品牌:CITIZEN 中文:西铁城 系列:CMR200T 频率 :32.768KHZ 负载电容:12.5PF -
京瓷贴片晶振代理商cx3225ga25000h0gss01 25MHZ无源晶体谐振器2023-05-25 11:46
产品型号:cx3225ga25000h0gss01 品牌:kyocera 中文名字:京瓷 系列:CX3225GA 中心频率:25MHZ 负载电容:12PF -
京瓷晶振现货CX2016DB48000D0DZZA1 48M 8PF无源晶体谐振器2023-05-25 11:44
产品型号:CX2016DB48000D0DZZA1 品牌:kyocera 中文:京瓷 系列:CX2016DB 封装:SMD2016 中心频率:48MHZ -
1.6*1.0mm小尺寸无源贴片晶振阿布雷肯ABRACON ABS05-32.768KHZ-6-T2023-05-25 11:34
产品型号:ABS05-32.768KHZ-6-T 品牌:ABRACON 中文名称:阿布雷肯 系列:ABS05 封装:SMD1610 中心频率:32.768K -
鸿星贴片晶振SMD3225 OSC 3.3V D3SX40E00000EE石英振荡器2023-05-25 11:30
产品型号:D3SX40E00000EE 品牌:hosonic 中文名称:鸿星 系列:D3SX 中心频率:40MHZ 精度:25PPM
石英晶振最不能忽视的一项参数指标,你千万别轻视了2023-08-21 10:46
只需一个步骤,普通有源贴片晶振秒变“车规级晶振”2023-07-21 10:59
TXC晶振为何会成为行业黑马,与EPSON并列第一2023-07-13 17:32
汽车电子都应用哪些频点的贴片晶振2023-05-04 15:44
这些晶振品牌你一定听过,看看有你不认识的吗2023-04-12 10:46
ABRACON晶振型号怎么看参数,一图看明白2023-04-12 10:44
(NDK晶振)STD-CSR-3和STD-CSR-6的差异2023-02-08 16:00
一张趣图明白车规级晶振的无可替代性2023-02-02 15:00
为甚么高清的视频画质需要高精度的有源晶振2023-02-01 11:01
24M贴片晶振不工作的四个原因2022-12-21 16:28
