--- 产品参数 ---
- Frequency FTE-6000 C 192 - 196 THz (1529
- Accuracy 1.5 GHz
- Line Width 1 MHz
--- 产品详情 ---
FTE6000 可调激光光源光纤测试光源TLS
The Terahertz Technologies FTE-6000 C Band Hand Held Tunable Laser Source (TLS) is manufactured
in a rugged splash proof housing with a highly protective boot. Our TLS displays in wavelength, frequency or ITU channel. The Tunable Laser Source is a great match with our FTE-8000 (Optical Spectrum Analyzer) for installation, commissioning and trouble shooting of DWDM networks. The FTE-6000 offers a fast start up with minimal warm up required and provides very stable wavelength and power outputs. As with all of our advanced tests equipment series, the FTE-6000 is affordable, easy to use and rugged. Ask about our kit offerings, such as the FTE-8600 Combo Kit.
Features
► Selectable Step Size Down to 50 GHz
► Selectable Start & Stop Channels
► Settable in Wavelength or Frequency
► Settable Dwell Time
► Rugged Case with Impact Resistant Boot
► USB PC Interface with Remote operation Capability
► Battery Operated or International Line Voltage
► Simple Operation with On-Line Help Mode
► Lowest Cost Hand Held Tunable Laser Source
► Interchangeable Fiber Optic Connectors
► Up to 88 Channels on the ITU Grid
► Fast Turn-On
Ordering Information | |
FTE-6000C | C-Band Tunable Laser Source |
FTE-SCASE-LG | Soft Case for FTE-7500, FTE-6000 and FTE-8000 Series |
FTE-6000 Specifications | |
Frequency Range | FTE-6000 C 192 - 196 THz (1529-1563nm) |
Accuracy | 1.5 GHz |
Line Width | 1 MHz |
Side Mode Suppression Ration | 45 dB |
Output Power | >12 dBm |
Attenuation Range | 0 - 5 dB |
Power Setting Resolution | 0.01 dB |
Power Variation over Wavelength Range | ± 0.5 dB |
Minimum Channel Spacing | 50 GHz (0.4nm) |
Fiber Type | 9/125 μm (Non-PM) |
Relative Intensity Noise | -140 dB/Hz |
Graphical Display | 4 in Color TFT |
Power Supply / Charger | Universal 100-240V witn Interchangeable Mains |
Battery | Battery Rechargeable NiMH - 4hr |
Storage Temperature | -20 to 60 C |
Operating Temperature Range | -10 to +40 C |
Dimensions (w/out rubber boot ) | 7.75” L x 4.5” W x 2.25” H (197mm L x 114mm W x 57mm H) |
Weight | 2 lbs |
Connector Styles | FC SC Interchangeable |
Accessories Provided | Universal Power Adapter w/US, UK, Continental Europe, and Australian Plugs, Interchangeable FC/ST and SC Adapters, Certsoft VI Software, Rubber Boot and Manual on CD |
上海屹持光电技术有限公司
为你推荐
K2-1000-mini高功率GHz低噪声飞秒激光器2025-02-10 10:02
产品型号:K2-1000-mini -
ROC单次自相关仪2025-01-03 11:01
产品型号:ROC -
梳状多波长皮秒激光器CombLas UV,CombLas VIS2024-10-24 11:44
产品型号:CombLas UV,CombLas VIS 型号:CombLas UV,CombLas VIS -
1微米皮秒光纤激光器AP-1030P2024-10-22 13:41
产品型号:AP-1030P -
Helios飞秒瞬态吸收光谱仪2024-09-25 09:50
产品型号:Helios -
单包层掺镱光纤Yb-Doped Single-Clad Fiber2024-09-19 16:53
产品型号:YB-401 型号:YB-401 -
MWIR中红外线栅偏振片2024-09-14 13:29
产品型号:MWIR 型号:MWIR -
1550nm光纤飞秒激光器SOPRANO-15 mini2024-09-14 13:26
产品型号:SOPRANO-15 mini 型号:SOPRANO-15 mini -
Terasense可调谐太赫兹源 频率扩展器2024-09-06 16:31
产品型号:Terasense 型号:Terasense -
K2-ASOPS高功率单腔双光梳激光器2024-09-05 15:01
产品型号:K2-ASOPS 型号:K2-ASOPS
SSFS飞秒激光孤子自频移波长调谐技术2024-07-02 09:17
1.5μ超紧凑型单次自相关仪正式上市2024-06-17 16:08
近距离了解中红外可调谐光纤飞秒激光器 Femtum Ultratune 3400性能2024-06-17 14:26
可输出不同偏振太赫兹波的光电导天线2024-05-14 11:21
