--- 产品参数 ---
- 电压 2-24V
- 电流 2A
--- 产品详情 ---
FEATURES• Integrated 80mΩ Power MOSFET • 2V to 24V Input Voltage • 1.2MHz Fixed Switching Frequency • Internal 4A Switch Current Limit • Adjustable Output Voltage • Internal Compensation • Up to 28V Output Voltage • Automatic Pulse Frequency Modulation Mode at Light Loads • up to 97% Efficiency • Available in a 6-Pin SOT23-6 PackageAPPLICATIONS• Battery-Powered Equipment • Set-Top Boxed • LCD Bais Supply • DSL and Cable Modems and Routers • Networking cards powered from PCI or PCI express slotsTYPICAL APPLICATIONFigure 1. Basic Application CircuitThe AP6608 is a constant frequency, 6-pin SOT23 current mode step-up converter intended for small, low power applications. The AP6608 switches at 1.2MHz and allows the use of tiny, low cost capacitors and inductors 2mm or less in height. Internal soft-start results in small inrush current and extends battery life. The AP6608 features automatic shifting to pulse frequency modulation mode at light loads. The AP6608 includes under-voltage lockout, current limiting, and thermal overload protection to prevent damage in the event of an output overload. The AP6608 is available in a small 6-pin SOT-23 package.
为你推荐
世微AP9180 内置 MOS 管升压型恒流驱动芯片2024-03-05 15:28
产品型号:AP9180 电压:3.6-60V 效率:95% -
世微AP9235B 恒流输出 升压型DC/DC转换器 背光驱动芯片2024-03-05 15:06
产品型号:AP9235B 电压:2.5-6V 电流:1A -
AP8854 DC-DC降压恒压 12V 6A过EMI线路图 宽电压电源管理IC2024-03-04 16:12
产品型号:AP8854 电压:10-120V 电流:12A -
AP5193 降压恒流IC PWM 线性调光 5-100V 2.5A LED汽车灯驱动芯片2024-03-04 14:29
产品型号:AP5193 电压:5-100V 电流:2.5A -
世微 RD-624 热释电红外传感器 智能电器居家用品感应2024-03-02 17:00
产品型号:RD-624 型号:RD-624 -
世微AP8851H 降压恒压IC和协议芯片 USB PD快充2024-03-02 16:33
产品型号:AP8851H 电压:10-120V 电流:1.5A -
世微AP2122太阳能草坪灯驱动芯片 适用AA电池和镍氢电池2024-02-29 15:47
产品型号:AP2122 电压:1.8V-3V 电流:300ma -
世微AP5101C 高压线性恒流IC 9-19V 500ma LED电源驱动方案 过压保护 抗浪涌2024-02-29 15:19
产品型号:AP5101 电压:5-100V 电流:1A -
世微AP3465 DC-DC同步恒压源 电动车车充 适配器 GPS 2024-02-27 17:02
产品型号:AP3465 电压:4-30V 电流:3A 输出:可调 -
世微AP8P059 静态功耗小 太阳能人体红外线感应IC2024-02-23 14:47
产品型号:AP8P059 静态功耗:20UA 过充保护:2.19V
LED线性车灯 H1 H4 H7 AP5101B高压线性恒流芯片2023-06-21 17:20
LED汽车大灯BOM表+线路图 AP5125降压恒流IC应用2023-06-05 14:57
低压球泡灯 高压线性恒流方案 12-10V 出9W AP5101B2023-05-20 17:00
AP2813 DCDC降压恒流芯片 两路输出 一路恒流 一路瀑闪 电动摩托汽车灯方案2023-05-18 17:54
降压恒流电路图分享 AP5101高压线性 LED降压恒流芯片2023-05-16 15:34
AP5191 DC-DC降压恒流芯片 12-80V 输出9V6A LED车灯方案2023-04-28 17:45
LED车灯 手电筒 外置MOS降压恒流驱动IC 12-36V 9V 1A驱动2023-03-20 11:11
LED驱动方案AP2400 DC-DC无极12-60V-远近光-双高默认远光2023-03-14 15:29
首发:大功率60W的LED降压恒流外置MOS驱动方案2023-01-10 11:28
(首发)12-80V 2A 亮/半亮/爆闪 三功能LED车灯方案2023-01-07 14:34
