--- 产品参数 ---
- 耐压 12V
- BST电压 48V
- EN关断时间 35NS
- 上升沿时间 100ns
- 下降沿时间 30ns
--- 数据手册 ---
--- 产品详情 ---
Dual Bootstrapped 12V MOSFET DRIVER OC3001_V1.0 Typical applicaion schematic General Descirption The OC3001 is a single Phase 12V MOSFET gate drivers optimized to drive the gates of both high−side and low−side power MOSFETs in a synchronous buck converter. The high−side and low−side driver is capable of driving a 3nF load with a 25ns propagation delay and a 30ns transition time. With a wide operating voltage range, high or low side MOSFET gate drive voltage can be optimized for the best efficiency. The internal adaptive non-overlap circuit further reduces the switching losses by preventing simultaneous conduction of both MOSFETs. The floating top driver design can accommodate BST voltages as high as 40V, with transient voltages as high as 48V. Both gate outputs can be driven low by applying a low logic level to the OD pin. An UVLO function ensures that both driver outputs are low when the supply voltage is low, and a Thermal Shutdown function provides the IC with over-temperature protection. OC3001 is available in SOP8 and DFN8 package. Features All−In−One Synchronous Buck Driver Bootstrapped High−Side Drive One PWM Signal Generates Both Drives Anti-cross Conduction Protection Circuit These are Pb−Free Devices Applications Multiphase Desktop CPU Supplies Single−Supply Synchronous Buck Converters e-cigarette wireless charger
![](https://file.elecfans.com/web2/M00/9F/CC/pYYBAGQ6V1OAImA1AADiBy_DpLI446.png)
为你推荐
高端电流检测降压欣峰茂科技DC-DC降压恒流10A耐压60V大功率驱动IC2023-12-13 15:38
产品型号:OC5033 耐压:60V 电流:10A 效率:96% 频率:1MHZ 电流精度:3% -
PT4115ME89E欣峰茂科技PT4115M降压恒流 36V 1A 2023-12-13 15:22
产品型号: PT4115ME89E 耐压:36V 电流:1A 调光:PWM/模拟调光 恒流精度:3% 封装 :SOT89-5 -
线性恒流40V耐压电流3.6A OC7202/OC72012023-12-12 14:23
产品型号:OC7202/OC7201 耐压:40V 电流:3.6A 工作电压:2.5V-40V 效率:95% 封装:5054 -
TB99B 车灯IC 长条灯驱动IC 带PWM调光耐450V 可替HV9910B2023-12-02 13:07
产品型号:TB99B 耐压:450V 调光:PWM 应用:DC-DC/AC-DC 效率:90% 电流:6A -
高 PF 高效率无频闪线性 LED 驱动芯片PT4519CDEHSG 2023-12-01 10:39
产品型号:PT4519CDEHSG 封装:HSOP-7 耐压:500V 电流:40MA 效率:85% 保护:过温自动调节电流 -
55V/1A异步降压转换器LGS5145 2023-11-22 16:46
产品型号:LGS5145 耐压:55V 输入电压:4.5V-55V 频率:1.2MHZ 效率:90% 封装:SOT23-6 -
带使能脚DC-DC降压恒压OC58655B OC58658 OC58652 OC586502023-10-24 14:04
产品型号:OC58655B OC58658 OC58652 耐压:100V 带使能脚:EN脚 输入最低电压:8V 最大电流:6A 模式:降压恒压 -
同步整流降压恒压带使能 EN脚2.5A 50V2023-10-24 13:53
产品型号:XL9021/XL9022 耐压:50V 输入电压:5-50V 开关电流:2.5A 使能:EN脚 效率:95% -
RY9135 16V 3A 500KHz 同步降压调节器2023-05-26 15:14
产品型号:RY9135 输入电压:4.5V-16V 电流:3A 频率:500KHZ 同步整流:同步整流 封装:SOT23-6 -
30V 1.2A 降压恒流OC5211 OC52132023-05-22 15:20
产品型号:OC5211/OC5213 耐压:30V 电流:1.2A 效率:96% 输入电压:5.5V-30V 频率:1MHZ
深圳市欣峰茂科技有限公司介绍2023-04-08 11:56
