--- 产品参数 ---
- 制程 6, 7, 12, 16, 22nm
- 台积电硅验证 6, 7, 12, 16, 22nm
--- 产品详情 ---
Digital PLL
M31 Digital PLL is a core-power only programmable phase-locked loop (PLL) for frequency synthesis. It supports multiple modes of operation for several application conditions, such as Phase-locked loop (PLL) /Fractional-N phase-locked loop (FNPLL) /Spread spectrum clocking (SSC)/ Oscillator (OSC). M31 Digital PLL has excellent immunity to power supply noise, making it ideally suited for use in noisy ASIC/SoC environments and is available as a single macro for easy integration into any ASIC/SoC.
Typical Phase Noise=-81.7dBc@1MHz
Period Jitter=1.3ps (std)
Block Diagram
Features
- Pure core voltage design
- Compact IP size (< 0.013mm²) and low power consumption (1.1mW @ 3GHz)
- Compatible with commonly used crystal oscillator frequencies
- Good power noise immunity for period jitter (< ±15%/V)
- Supports 24-bit fractional accuracy
- Supports down spread-spectrum clocking (SSC) technology
- Supports retention OSC operation
- Embedded lock-detect flag
- Embedded scan chain for mass production
- Full deliverables to ease ASIC/SoC integration
为你推荐
M31 DisplayPort TX2024-07-10 14:44
产品型号:DisplayPort TX 制程:6, 7, 12, 28nm 台积电硅验证:6, 7, 12, 28nm -
M31 ONFI PHY2024-07-10 14:38
产品型号:ONFI PHY 制程:3nm -
M31 ONFI I/O2024-07-10 14:33
产品型号:ONFI I/O 制程:55-3nm 台积电硅验证:55-3nm -
M31 LPDDR4/4X2024-07-10 14:29
产品型号:LPDDR4/4X 制程:12nm 台积电硅验证:12nm -
M31 ADC / Temperature Sensor2024-07-10 14:20
产品型号:ADC / Temperature Sensor 制程:12, 14, 22nm 台积电硅验证:12, 14, 22nm -
M31 Analog-PLL2024-07-10 14:08
产品型号:Analog-PLL 制程:12, 22, 28, 40nm 台积电硅验证:12, 22, 28, 40nm -
M31 Digital PLL2024-07-10 13:58
产品型号:Digital PLL 制程:6, 7, 12, 16, 22nm 台积电硅验证:6, 7, 12, 16, 22nm -
M31 High ESD I/O2024-07-10 11:51
产品型号:High ESD I/O 制程:180-12nm 台积电硅验证:180-12nm -
M31 General-Purpose I/O2024-07-10 11:47
产品型号:General-Purpose I/O 制程:180-12nm 台积电硅验证:180-12nm -
M31 Memory Compiler2024-07-04 14:44
产品型号:Memory Compiler 制程:180-12nm 台积电硅验证:180-12nm
M31与高塔半导体合作,成功开发65奈米的SRAM和ROM 先进内存解决方案2024-08-06 17:05
M31亮相北美设计自动化会议 展示先进制程IP解决方案2024-06-28 14:40
M31宣布推出先进LPDDR内存IP,助力HPC高效能运算应用2024-06-24 11:24
M31携手台积电5奈米先进制程 成功发表MIPI C/D PHY Combo IP2024-04-26 18:33
M31成功验证5奈米硅智财解决方案 助力全球AI应用2024-04-19 17:27
M31在首届Intel Foundry Direct Connect 展示先进SoC开发与创新2024-02-23 11:37
M31推出PCI-SIG的官方认证PCIe5.0 PHY IP 携手SSD存储芯片公司InnoGrit推进PCIe5.0新世代2024-02-20 18:06
M31成功验证12奈米USB4 PHY IP 助力新世代高速数据传输2024-01-05 11:44
M31谈MIPI在车用电子的需求与挑战2023-12-18 10:07
低电压标准组件库操作设计方案2023-09-08 11:04
