--- 产品参数 ---
- 制程 3nm
--- 产品详情 ---
ONFI PHY
M31 ONFI multi-PHY is a versatile solution that accommodates ONFI4.0 to ONFI6.0 NAND flash interfaces, offering impressive speeds of up to 4800Mbps. This advanced technology seamlessly integrates support for CTT (Command Transfer Time), LTT (Address Transfer Time), and PI-LTT (Program and Input Transfer Time) signals. The robust ONFI multi-PHY not only ensures high-speed data transfers but also provides comprehensive support for various NAND flash interface versions, enhancing overall performance and adaptability.
Key Benefits
PISI Support for Package Design
Advanced equalization to improve large loading signal eye
Features
- Multi-interface support: ONFI6.0 up to 4800Mbps
- Multi-data-interface support: CTT (NVDDR3), LTT (NVLPDDR4) and PI-LTT
- Optimized for high performance and integration flexibility. The harden IP included 8-bit data blocks, up to 8 CE/channel, clock blocks, PLL, and DLL.
- High-resolution read/write delay adjust
- Per bit deskew on read/write data path
- Low power mode
- Dynamic frequency scaling
- Testability support: DFT, boundary scan, and BIST with loopback tests
- Advanced equalization, including TX FFE and RX DFE
- PI/SI design guidelines to ensure high data rate performance
- Advance clock structure to minimize jitter and automated interface timing margins with less power
为你推荐
M31 UniPro 1.6 device2024-11-25 16:59
产品型号:UFS/UNIPRO Controller UniPro :1.6 device -
M31 UniPro 1.6 host2024-11-25 16:52
产品型号:UFS/UNIPRO Controller UniPro :1.6 host -
M31 UniPro 1.8 device2024-11-25 16:46
产品型号:UFS/UNIPRO Controller UniPro:1.8 device -
UniPro 1.8 host2024-11-25 16:39
产品型号:UFS/UNIPRO Controller UniPro :1.8 host -
UniPro 2.0 device2024-11-25 16:23
产品型号:UFS/UNIPRO Controller UniPro :2.0 device -
M31 UniPro 2.0 host2024-11-25 16:21
产品型号:UFS/UNIPRO Controller UniPro:2.0 host -
M31 UFSHCI 3.02024-11-25 16:18
产品型号:UFS/UNIPRO Controller UFSHCI :3.0 -
M31 UFSHCI 4.02024-11-25 16:12
产品型号:UFS/UNIPRO Controller UFSHCI :4.0 -
M31 DisplayPort TX2024-07-10 14:44
产品型号:DisplayPort TX 制程:6, 7, 12, 28nm 台积电硅验证:6, 7, 12, 28nm -
M31 ONFI PHY2024-07-10 14:38
产品型号:ONFI PHY 制程:3nm
M31全系列车用硅智财解决方案亮相ICCAD 点亮未来車用芯片发展2024-12-27 14:26
M31推出台积电5奈米制程的USB4 IP,助力新一代高效能高速数据传输2024-11-12 18:40
M31円星科技连续七年获颁「台积电OIP硅智财伙伴奖」,並發表ONFI5.1 I/O IP于台积电5奈米制程成功完成硅验证2024-10-09 10:29
M31与高塔半导体合作,成功开发65奈米的SRAM和ROM 先进内存解决方案2024-08-06 17:05
M31亮相北美设计自动化会议 展示先进制程IP解决方案2024-06-28 14:40
M31宣布推出先进LPDDR内存IP,助力HPC高效能运算应用2024-06-24 11:24
M31携手台积电5奈米先进制程 成功发表MIPI C/D PHY Combo IP2024-04-26 18:33
M31成功验证5奈米硅智财解决方案 助力全球AI应用2024-04-19 17:27
M31在首届Intel Foundry Direct Connect 展示先进SoC开发与创新2024-02-23 11:37
M31推出PCI-SIG的官方认证PCIe5.0 PHY IP 携手SSD存储芯片公司InnoGrit推进PCIe5.0新世代2024-02-20 18:06
