--- 产品参数 ---
- UniPro 1.6 device
--- 产品详情 ---
UniPro 1.6 device
The Unified Protocol (UniPro) provides a layered protocol similar to the ISO OSI model. It is designed for high-speed, stable data transfer in mobile and automotive systems.
The UniPro 1.6 IP is compliant with MIPI UniPro 1.6 specification and is used for connecting applications and MIPI M-PHY links at HS-G3 speed (5.83 Gbps/Rate B).
The UniPro IP is fully compatible with M31’s M-PHY IP for use in UFS storage devices. When combined with UFS Host Controller IP, UniPro IP, and M-PHY IP, these IPs provide a comprehensive solution, enabling customers to easily integrate them into their applications and accelerate the time-to-market for SoC designs.
为你推荐
M31 UniPro 1.6 device2024-11-25 16:59
产品型号:UFS/UNIPRO Controller UniPro :1.6 device -
M31 UniPro 1.6 host2024-11-25 16:52
产品型号:UFS/UNIPRO Controller UniPro :1.6 host -
M31 UniPro 1.8 device2024-11-25 16:46
产品型号:UFS/UNIPRO Controller UniPro:1.8 device -
UniPro 1.8 host2024-11-25 16:39
产品型号:UFS/UNIPRO Controller UniPro :1.8 host -
UniPro 2.0 device2024-11-25 16:23
产品型号:UFS/UNIPRO Controller UniPro :2.0 device -
M31 UniPro 2.0 host2024-11-25 16:21
产品型号:UFS/UNIPRO Controller UniPro:2.0 host -
M31 UFSHCI 3.02024-11-25 16:18
产品型号:UFS/UNIPRO Controller UFSHCI :3.0 -
M31 UFSHCI 4.02024-11-25 16:12
产品型号:UFS/UNIPRO Controller UFSHCI :4.0 -
M31 DisplayPort TX2024-07-10 14:44
产品型号:DisplayPort TX 制程:6, 7, 12, 28nm 台积电硅验证:6, 7, 12, 28nm -
M31 ONFI PHY2024-07-10 14:38
产品型号:ONFI PHY 制程:3nm
M31全系列车用硅智财解决方案亮相ICCAD 点亮未来車用芯片发展2024-12-27 14:26
M31推出台积电5奈米制程的USB4 IP,助力新一代高效能高速数据传输2024-11-12 18:40
M31円星科技连续七年获颁「台积电OIP硅智财伙伴奖」,並發表ONFI5.1 I/O IP于台积电5奈米制程成功完成硅验证2024-10-09 10:29
M31与高塔半导体合作,成功开发65奈米的SRAM和ROM 先进内存解决方案2024-08-06 17:05
M31亮相北美设计自动化会议 展示先进制程IP解决方案2024-06-28 14:40
M31宣布推出先进LPDDR内存IP,助力HPC高效能运算应用2024-06-24 11:24
M31携手台积电5奈米先进制程 成功发表MIPI C/D PHY Combo IP2024-04-26 18:33
M31成功验证5奈米硅智财解决方案 助力全球AI应用2024-04-19 17:27
M31在首届Intel Foundry Direct Connect 展示先进SoC开发与创新2024-02-23 11:37
M31推出PCI-SIG的官方认证PCIe5.0 PHY IP 携手SSD存储芯片公司InnoGrit推进PCIe5.0新世代2024-02-20 18:06
