企业号介绍
全部
  • 全部
  • 产品
  • 方案
  • 文章
  • 资料
  • 企业
M31 Technology
M31円星科技-营运总部位于台湾新竹,為专业的全球硅智財开发商,拥有顶尖的研发与服务团队,客户涵盖世界一流的晶圆代工厂及IC设计公司。
58 内容数 3w 浏览量 11 粉丝
M31 Analog-PLL
型号: Analog-PLL
--- 产品参数 ---
  • 制程 12, 22, 28, 40nm
  • 台积电硅验证 12, 22, 28, 40nm
--- 产品详情 ---
Analog-PLL
Low Power Fractional PLL is a general purpose frequency synthesizer with an input reference frequency range from 10 to 240 MHz and 3:1 output frequency range. The PLL core is a typical Type-II PLL and the fractional portion of the output frequency is achieved by using a programmable 3rd-ord sigma delta modulator. The PLL core operates on IO supply voltage for excellent supply rejection in noisy SoC applications. It is designed for easy usage and simple integration, eliminating the need for complex configurations.
Features
  • Supports wide input frequency range: 10MHz to 240MHz
  • Supports 3:1 output frequency range allows optimization for power and jitter performance
  • 24-bit fractional accuracy
  • Supports Spread Spectrum Clocking
  • Lock Detect Signal indicates when frequency lock is achieved
  • Embedded frequency meter circuit for mass production testing
  • Embedded continuous monitoring watchdog circuit for automotive applications
  • Output mux for bypass mode
  • PLL Core Area less than 100µm x 100µm @22nm
  • Low Power Consumption, less than 1.0mA from IO voltage domain at lowest output frequency operation
为你推荐
  • M31 UniPro 1.6 device2024-11-25 16:59
    产品型号:UFS/UNIPRO Controller UniPro :1.6 device
  • M31 UniPro 1.6 host2024-11-25 16:52
    产品型号:UFS/UNIPRO Controller UniPro :1.6 host
  • M31 UniPro 1.8 device2024-11-25 16:46
    产品型号:UFS/UNIPRO Controller UniPro:1.8 device
  • UniPro 1.8 host2024-11-25 16:39
    产品型号:UFS/UNIPRO Controller UniPro :1.8 host
  • UniPro 2.0 device2024-11-25 16:23
    产品型号:UFS/UNIPRO Controller UniPro :2.0 device
  • M31 UniPro 2.0 host2024-11-25 16:21
    产品型号:UFS/UNIPRO Controller UniPro:2.0 host
  • M31 UFSHCI 3.02024-11-25 16:18
    产品型号:UFS/UNIPRO Controller UFSHCI :3.0
  • M31 UFSHCI 4.02024-11-25 16:12
    产品型号:UFS/UNIPRO Controller UFSHCI :4.0
  • M31 DisplayPort TX2024-07-10 14:44
    产品型号:DisplayPort TX 制程:6, 7, 12, 28nm 台积电硅验证:6, 7, 12, 28nm
  • M31 ONFI PHY2024-07-10 14:38
    产品型号:ONFI PHY 制程:3nm
