--- 产品参数 ---
- 制程 12, 14, 22nm
- 台积电硅验证 12, 14, 22nm
--- 产品详情 ---
ADC / Temperature Sensor
The M31 SAR ADC provides a rich portfolio with a resolution from 10 to 12-bit, maximum speed up to 2.5MSPS, and supports input types of single-ended or differential that give users great flexibility in their ASIC/SoC integration.
With patented innovative circuit techniques, the ADC can perform conversion as fast as the clock rate that is not commonly seen in the conventional SAR ADCs which often require a clock rate (Bit+N) X faster than the conversion rate. This feature eases the design complexity of system clock arrangement (and also the PLL/OSC) and saves power because of a reduced clock rate used by the ADC.
The ADC is intentionally designed to consume as small as possible current from the supply by combining several circuit techniques such that the ADC features an ultra-low-power (ULP) consumption. The ADC best suits the applications demanding extremely low power consumption like battery-powered products and Internet-of-Things (IoT).
Block Diagram
ADC Features
- Ultra Low Power : 12nm ADC, <0.6mA at 2.5MSPS, 1.8V
- Compact Size : <150um x 150um (12nm, exclude pad, primary ESD clamp)
- Wide Operating Range Supply: 1.8V ±10%
- Temperature: -40°C to 125°C
- Excellent Performance : 12-Bit Resolution with No Missing Code (NMC)
- ±1-LSB (Max) DNL and ±2-LSB (Max) INL
- Input Type Flexibility
- Single-ended or differential
Temperature Sensor Features
- Capable of sensing voltage or current within one smart sensor
- Easy to drive with inherent filtering and programmable gain adjustment
- Ultra low power & compact area
为你推荐
M31 DisplayPort TX2024-07-10 14:44
产品型号:DisplayPort TX 制程:6, 7, 12, 28nm 台积电硅验证:6, 7, 12, 28nm -
M31 ONFI PHY2024-07-10 14:38
产品型号:ONFI PHY 制程:3nm -
M31 ONFI I/O2024-07-10 14:33
产品型号:ONFI I/O 制程:55-3nm 台积电硅验证:55-3nm -
M31 LPDDR4/4X2024-07-10 14:29
产品型号:LPDDR4/4X 制程:12nm 台积电硅验证:12nm -
M31 ADC / Temperature Sensor2024-07-10 14:20
产品型号:ADC / Temperature Sensor 制程:12, 14, 22nm 台积电硅验证:12, 14, 22nm -
M31 Analog-PLL2024-07-10 14:08
产品型号:Analog-PLL 制程:12, 22, 28, 40nm 台积电硅验证:12, 22, 28, 40nm -
M31 Digital PLL2024-07-10 13:58
产品型号:Digital PLL 制程:6, 7, 12, 16, 22nm 台积电硅验证:6, 7, 12, 16, 22nm -
M31 High ESD I/O2024-07-10 11:51
产品型号:High ESD I/O 制程:180-12nm 台积电硅验证:180-12nm -
M31 General-Purpose I/O2024-07-10 11:47
产品型号:General-Purpose I/O 制程:180-12nm 台积电硅验证:180-12nm -
M31 Memory Compiler2024-07-04 14:44
产品型号:Memory Compiler 制程:180-12nm 台积电硅验证:180-12nm
M31与高塔半导体合作,成功开发65奈米的SRAM和ROM 先进内存解决方案2024-08-06 17:05
M31亮相北美设计自动化会议 展示先进制程IP解决方案2024-06-28 14:40
M31宣布推出先进LPDDR内存IP,助力HPC高效能运算应用2024-06-24 11:24
M31携手台积电5奈米先进制程 成功发表MIPI C/D PHY Combo IP2024-04-26 18:33
M31成功验证5奈米硅智财解决方案 助力全球AI应用2024-04-19 17:27
M31在首届Intel Foundry Direct Connect 展示先进SoC开发与创新2024-02-23 11:37
M31推出PCI-SIG的官方认证PCIe5.0 PHY IP 携手SSD存储芯片公司InnoGrit推进PCIe5.0新世代2024-02-20 18:06
M31成功验证12奈米USB4 PHY IP 助力新世代高速数据传输2024-01-05 11:44
M31谈MIPI在车用电子的需求与挑战2023-12-18 10:07
低电压标准组件库操作设计方案2023-09-08 11:04
