--- 产品参数 ---
- 制程 12nm
- 台积电硅验证 12nm
--- 产品详情 ---
LPDDR4/4X
M31 LPDDR4X multi-PHY supports both LPDDR4 and LPDDR4X memory interfaces at speed up to 4267Mbps, making it an ideal solution for ASICS, ASSPs, SOC and POP that require high performance memory interfaces. The multi-interface PHY can be used in a variety of applications, including automotive (autonomous driving), mobile (smart phones) and enterprise (laptops and desktops).
Key Benefits
Flexible Floorplan
PI/SI Support for Package Design
Features
- Multi-interface support: LPDDR4 up to 4267Mbps, LPDDR4X up to 4267Mpbs
- Supports LPDDR4X 0.6V VDDQ
- Optimized for high performance and integration flexibility. The harden IP included 8-bit data blocks, 6-bit C/A blocks, clock blocks, PLL and DLL. IP pin-out can be configured to optimize for LPDDR4/4X.
- High resolution read/write timing control
- Per bit deskew on read/write data path
- Multiple PHY independent training mode, including periodic background training
- Low power mode
- Dynamic frequency scaling
- Testability support: Scan, ATPG with OPCG, BIST with loopback test
- Advanced equalization, including TX FFE and RX DFE
- PI/SI design guidelines to ensure high data rate performance
- Advance clock structure to minimize jitter and automated interface timing margins
为你推荐
M31 DisplayPort TX2024-07-10 14:44
产品型号:DisplayPort TX 制程:6, 7, 12, 28nm 台积电硅验证:6, 7, 12, 28nm -
M31 ONFI PHY2024-07-10 14:38
产品型号:ONFI PHY 制程:3nm -
M31 ONFI I/O2024-07-10 14:33
产品型号:ONFI I/O 制程:55-3nm 台积电硅验证:55-3nm -
M31 LPDDR4/4X2024-07-10 14:29
产品型号:LPDDR4/4X 制程:12nm 台积电硅验证:12nm -
M31 ADC / Temperature Sensor2024-07-10 14:20
产品型号:ADC / Temperature Sensor 制程:12, 14, 22nm 台积电硅验证:12, 14, 22nm -
M31 Analog-PLL2024-07-10 14:08
产品型号:Analog-PLL 制程:12, 22, 28, 40nm 台积电硅验证:12, 22, 28, 40nm -
M31 Digital PLL2024-07-10 13:58
产品型号:Digital PLL 制程:6, 7, 12, 16, 22nm 台积电硅验证:6, 7, 12, 16, 22nm -
M31 High ESD I/O2024-07-10 11:51
产品型号:High ESD I/O 制程:180-12nm 台积电硅验证:180-12nm -
M31 General-Purpose I/O2024-07-10 11:47
产品型号:General-Purpose I/O 制程:180-12nm 台积电硅验证:180-12nm -
M31 Memory Compiler2024-07-04 14:44
产品型号:Memory Compiler 制程:180-12nm 台积电硅验证:180-12nm
M31与高塔半导体合作,成功开发65奈米的SRAM和ROM 先进内存解决方案2024-08-06 17:05
M31亮相北美设计自动化会议 展示先进制程IP解决方案2024-06-28 14:40
M31宣布推出先进LPDDR内存IP,助力HPC高效能运算应用2024-06-24 11:24
M31携手台积电5奈米先进制程 成功发表MIPI C/D PHY Combo IP2024-04-26 18:33
M31成功验证5奈米硅智财解决方案 助力全球AI应用2024-04-19 17:27
M31在首届Intel Foundry Direct Connect 展示先进SoC开发与创新2024-02-23 11:37
M31推出PCI-SIG的官方认证PCIe5.0 PHY IP 携手SSD存储芯片公司InnoGrit推进PCIe5.0新世代2024-02-20 18:06
M31成功验证12奈米USB4 PHY IP 助力新世代高速数据传输2024-01-05 11:44
M31谈MIPI在车用电子的需求与挑战2023-12-18 10:07
低电压标准组件库操作设计方案2023-09-08 11:04
