--- 产品详情 ---
产品简介
屹持光电提供的台式光纤放大器具有独特的光纤技术,覆盖了通讯波段和其他非通讯波段。这些放大器可以方便的在前面板控制参数,适合研究开发应用,包括下一代光网络的研发。其他应用有光学测量、放大脉冲激光、以及科学实验等。
产品特点
— 覆盖波段宽(通讯和非通讯波段)
— 大多数信号默认带有RS232C / IEEE488.2(GP-IB)接口
— 可根据客户要求定制产品
— 适用于下一代网络通讯系统的研发
— 探测光学测量和光传感中的微弱信号
不同型号的规格参数
型号 | Band | 信号波长 (nm) | 最大输出功率(dBm) | 增益 (dB) | 噪声因子 (dB) | 尺寸 HxWxD (mm) |
通讯波段
AMP-FL8611-OB-20 | O | 1280-1320 | >+20 | >35 | <7 | 130x440x460 |
AMP-FL8611-OB-16 | >+16 | >20 | 88x336x352 | |||
AMP-FL8611-OB-13 | >+13 | >15 | 88x260x350 | |||
AMP-FL8211-SB-20 | S | 1460-1500 | >+20 | >25 | <7 | 88x260x350 |
AMP-FL8211-SB-16 | >+16 | >20 | ||||
AMP-FL8211-SB-13 | >+13 | >15 | ||||
AMP-FL8221-SB-19 | 1470-1520 | >+19 | >30 | 130x440x460 | ||
AMP-FL8221-SB-16 | >+16 | >25 | 88x260x350 | |||
AMP-FL8011-CB-22-W | C | 1530-1560 (DWDM) | >+22 | >35 | <6 | 88x260x350 |
AMP-FL8011-CB-22 | 1530-1560 | >+22 | >40 | |||
AMP-FL8011-CB-19 | >+19 | >35 | ||||
AMP-FL8011-CB-16 | >+16 | >30 | ||||
AMP-FL8013-CB-19-W | 1530-1560 (DWDM) | >+19 | >30 | <5 | ||
AMP-FL8013-CB-19 | 1530-1560 | >+19 | >35 | |||
AMP-FL8013-CB-16 | >+16 | >30 | ||||
AMP-FL8013-CB-13 | >+13 | >25 | ||||
AMP-FL8015-CB-37 | 1540-1560 (High Power) | >+37 | - | <6 | 130x440x460 | |
AMP-FL8015-CB-35 | >+35 | |||||
AMP-FL8015-CB-33 | >+33 | |||||
AMP-FL8015-CB-30 | >+30 | |||||
AMP-FL8015-CB-27 | >+27 | |||||
AMP-FL8001-LB-22 | L | 1560-1610 | >+22 | >35 | <6 | 88x260x350 |
AMP-FL8001-LB-19 | >+19 | >35 | ||||
AMP-FL8001-LB-16 | >+16 | >30 | ||||
AMP-FL8001-LB-13 | >+16 | >25 | ||||
AMP-FL8005-LB-33 | 1575-1600 (High Power) | >+33 | - | <7 | 130x440x460 | |
AMP-FL8005-LB-30 | >+30 | |||||
AMP-FL8005-LB-27 | >+27 | |||||
AMP-FL8021-CLB-22 | CL | 1530-1560 1570-1610 | >+22 | >35 | <7 | 130x440x460 |
AMP-FL8021-CLB-19 | >+19 | >35 | 88x260x350 | |||
AMP-FL8021-CLB-16 | >+16 | >30 | ||||
AMP-FL8021-CLB-13 | >+13 | >25 |
其他波段
AMP-FL8401 | 850nm | 853 +/- 3 | - | >20 | - | 88x260x350 |
AMP-FL8511 | 980nm | 978 +/ -3 | >+14 | >25 | - | 88x260x350 |
AMP-FL8521-XB-20 | X (1um) | 1020-1080 | >+20 | >30 | - | 88x260x350 |
上海屹持光电技术有限公司
为你推荐
ROC单次自相关仪2025-01-03 11:01
产品型号:ROC -
梳状多波长皮秒激光器CombLas UV,CombLas VIS2024-10-24 11:44
产品型号:CombLas UV,CombLas VIS 型号:CombLas UV,CombLas VIS -
1微米皮秒光纤激光器AP-1030P2024-10-22 13:41
产品型号:AP-1030P -
Helios飞秒瞬态吸收光谱仪2024-09-25 09:50
产品型号:Helios -
单包层掺镱光纤Yb-Doped Single-Clad Fiber2024-09-19 16:53
产品型号:YB-401 型号:YB-401 -
MWIR中红外线栅偏振片2024-09-14 13:29
产品型号:MWIR 型号:MWIR -
1550nm光纤飞秒激光器SOPRANO-15 mini2024-09-14 13:26
产品型号:SOPRANO-15 mini 型号:SOPRANO-15 mini -
Terasense可调谐太赫兹源 频率扩展器2024-09-06 16:31
产品型号:Terasense 型号:Terasense -
K2-ASOPS高功率单腔双光梳激光器2024-09-05 15:01
产品型号:K2-ASOPS 型号:K2-ASOPS -
K2-1000高功率GHz双光梳飞秒激光器2024-09-05 14:53
产品型号:K2-1000 型号:K2-1000
SSFS飞秒激光孤子自频移波长调谐技术2024-07-02 09:17
1.5μ超紧凑型单次自相关仪正式上市2024-06-17 16:08
近距离了解中红外可调谐光纤飞秒激光器 Femtum Ultratune 3400性能2024-06-17 14:26
可输出不同偏振太赫兹波的光电导天线2024-05-14 11:21
