--- 产品参数 ---
- 工作温度 ℃
- 封装 DFN
- 多路/解复用器电路 多路复用
- 开关电路
- 导通电阻(最大值) 欧姆
- 电压-电源单(V+) V
- 电压-供电双(V±) V
- -3db带宽 MHz
- 通道数
--- 数据手册 ---
--- 产品详情 ---
BCT4321 N USB2.0 Hi-Speed and Audio Switches with Negative Signal Capability
G EN ERAL DESCRIPTION
The BCT4321N is a double-pole double-throw
(DPDT) analog switch with multiplexes USB2.0
and negative signal audio analog signals. One
Channel has wide bandwidth and low bit-to-bit
skew allow it to pass high-speed differential
signals with good signal integrity. Another channel
has ultra-L ow on resistance (2 5Q). Each switch is
bidirectional and offers lttle or no attenuation of
the signals at the outputs. Industry-leading
advantages include a propagation delay of less
than 250ps, resulting from its low channel
resistance and low I/O capacitance. Their high
channel-to-channel crosstalk rejection results in
minimal noise interference.
The
BCT4321N is available in Green
QFN1. .4X1.8-10 packages. It operates over an
ambient temperature range of -40°C to +85°C.
FEATURES
●Vcc Operating Range: 2.7V to 5.0V
●-3dB Bandwidth: 720MHz(USB Mode)
●Off Isolation: 66dB @1MHz
●Crosstalk Rejection: 86dB @1MHz
●Low ON Resistance.
2.5-ohm at VCC = 3.6 V (Audio Mode)
8.5-ohm at VCC = 3.6 V (USB Mode)
●Analog Signal Range:
Vcc-6. 5V to Vcc-2 (Audio Mode)
0V to VCC (USB Mode)
●Audio Channel Shunt Resistors for Pop & Click
Noise Reduction
●Power-off Protection on Common D+/R, D-/L
Ports
APPLICATIONS
Cell Phones
Hi-Fi Audio Switching
USB 2.0 High Speed Data Switching
USB 3.x Type C Switching
为你推荐
TC358775XBG东芝Toshiba多功能视频转换器桥接芯片2023-12-28 10:54
产品型号:TC358775XBG 型号:TC358775XBG -
WK2168是首款具备256级FIFO的低功耗并支持UART/SPITM/IIC/8位并行总线接口的4通道UART器件2023-11-24 00:35
产品型号:WK2168 -
WK2204是首款具备256级FIFO的低功耗并支持UART/SPITM/IIC位并行总线接口的4通道UART器件2023-11-24 00:31
产品型号:WK2204 -
WK2212是首款具备256级FIFO的低功耗并支持 UART/SPITM/IIC/8位并行总线接口的2通道UART器件2023-11-24 00:28
产品型号:WK2212 -
WK2124是SPITM接口的4通道UART器件,WK2124实现SPI桥接/扩展4个增强功能串口(UART)的功能2023-11-24 00:17
产品型号:WK2124 -
模拟开关/多路复用器 BCT4321NETB-TR 2023-10-25 09:34
产品型号: BCT4321NETB-TR -
由恒泰瑞代理提供华芯CJC5340 ADC 数字音频系统模拟数字转换器2023-10-24 14:06
产品型号:CJC5340 -
CJC4344(10针,24Bit,192kHz立体声D/A音频数模转换器)2023-10-23 10:11
产品型号:cjc4344 -
音频编解码器CJC8988可完全替代WM8988,ES83882023-05-25 14:59
产品型号:CJC8988 起订量:1000 供货总量:5000 所在地:深圳 -
Uart串口扩展芯片 1to4 wk2124 wk2132 wk2168 wk2204 wk21142023-05-24 12:50
产品型号:WK2124 主接口:UART/SPI/IIC/8位并口 通道:4 硬件流控:有/无 rx/TxFiFo:4*256/2*256 封装形式:SSOP20/LSSOP16L/LQFP48L/QFN24L
瑞纳捷RJM8L003入门使用指南2024-12-07 01:09
BCT3144双路闪光灯驱动芯片2024-03-08 08:30
BCT4481多功能、高集成度Type-C接口SOC芯片2024-03-08 08:30
BCT3146双路闪光灯驱动芯片2024-03-07 08:30
什么是CAN? Pin MCP2515 芯片2024-02-22 08:31
多镜头多传感器图像视频处理器应用2024-01-26 08:31
恒泰瑞提供基于RJM8L151S的宠物定位器解决方案2024-01-03 08:31
瑞纳捷高性能防复制加密认证芯片解决电池防伪方案2024-01-03 08:31
《硅谷》前史,“八叛徒”与仙童半导体的故事2023-12-13 08:32
关于多种接口扩展为串口的实用案列2023-11-25 08:31
