--- 产品参数 ---
- KCD2-SR-EX 1
--- 产品详情 ---
参数表节选:的技术参数 KCD2-SR-Ex2
General specifications | ||
Signal type | Digital Input | |
Functional safety related parameters | ||
Safety Integrity Level (SIL) | SIL 2 | |
Supply | ||
Connection | Power Rail or terminals 9+, 10- | |
Rated voltage | 19 ... 30 V DC | |
Ripple | ≤ 10 % | |
Rated current | ≤ 46 mA | |
Power dissipation | ≤ 900 mW | |
Power consumption | ≤ 900 mW | |
Input | ||
Connection side | field side | |
Connection | terminals 1+, 2-; 3+, 4- | |
Rated values | acc. to EN 60947-5-6 (NAMUR) | |
Open circuit voltage/short-circuit current | approx. 8 V DC / approx. 8 mA | |
Switching point/switching hysteresis | 1.2 ... 2.1 mA / approx. 0.2 mA | |
Line fault detection | breakage I ≤ 0.1 mA , short-circuit I ≥ 6.5 mA | |
Pulse/Pause ratio | min. 20 ms / min. 20 ms | |
Output | ||
Connection side | control side | |
Connection | terminals 5, 6; 7, 8 | |
Output I | signal ; relay | |
Output II | signal ; relay | |
Contact loading | 250 V AC/2 A/cos φ > 0.75; 126.5 V AC/4 A/cos φ > 0.75; 30 V DC/2 A resistive load | |
Minimum switch current | 2 mA / 24 V DC | |
Energized/De-energized delay | ≤ 20 ms / ≤ 20 ms | |
Mechanical life | 107 switching cycles | |
Transfer characteristics | ||
Switching frequency | ≤ 10 Hz | |
Galvanic isolation | ||
Input/Output | reinforced insulation according to IEC/EN 61010-1, rated insulation voltage 300 Veff | |
Input/power supply | reinforced insulation according to IEC/EN 61010-1, rated insulation voltage 300 Veff | |
Output/power supply | reinforced insulation according to IEC/EN 61010-1, rated insulation voltage 300 Veff | |
Output/Output | reinforced insulation according to IEC/EN 61010-1, rated insulation voltage 300 Veff | |
Indicators/settings | ||
Display elements | LEDs | |
Control elements | DIP switch | |
Configuration | via DIP switches | |
Labeling | space for labeling at the front |
为你推荐
UB1000-18GM75-E01-V15 超声波传感器现货直发2022-12-20 13:31
产品型号:UB1000-18GM75-E01-V15 UB1000-18G:1 -
UMC3000-30H-E5-5M-3G-3D 超声波传感器现货直发2022-12-20 13:29
产品型号:UMC3000-30H-E5-5M-3G-3D UMC3000-30:1 -
UB6000-F42-I-V15 超声波传感器现货直发2022-12-20 13:21
产品型号:UB6000-F42-I-V15 UB6000-F42:1 -
UB500-18GM75-E01-V15 超声波传感器现货2022-12-20 13:20
产品型号:UB500-18GM75-E01-V15 UB500-18GM:1 -
UB5000-F42-UK-V95 超声波传感器现货直发2022-12-16 13:46
产品型号:UB5000-F42-UK-V95 UB5000-F42:1 -
UB500-F42S-U-V15 超声波传感器现货直发2022-12-16 13:44
产品型号:UB500-F42S-U-V15 UB500-F42S:1 -
UB4000-30GM-E4-V15 超声波传感器现货直发2022-12-16 13:42
产品型号:UB4000-30GM-E4-V15 UB4000-30G:1 -
UB2000-F42S-U-V15 超声波传感器现货直发2022-12-16 13:31
产品型号:UB2000-F42S-U-V15 UB2000-F42:1 -
UC2000-30GM-IUR2-V15-Y305942 传感器现货直发2022-12-16 13:27
产品型号:UC2000-30GM-IUR2-V15-Y305942 UC2000-30G:1 -
UB200-12GM-E5-V1 超声波传感器现货直发2022-12-16 13:23
产品型号:UB200-12GM-E5-V1 UB200-12GM:1
