--- 产品参数 ---
- KFD2-STC4- 1
--- 产品详情 ---
General specifications | ||
Signal type | Analog input | |
Functional safety related parameters | ||
Safety Integrity Level (SIL) | SIL 2 | |
Supply | ||
Connection | Power Rail or terminals 14+, 15- | |
Rated voltage | 20 ... 35 V DC | |
Ripple | within the supply tolerance | |
Power dissipation | 1.4 W | |
Power consumption | 1.8 W | |
Input | ||
Connection side | field side | |
Connection | terminals 1+, 2-, 3 or 5-, 6+ | |
Input signal | 0/4 ... 20 mA | |
Voltage drop | ≤ 2.4 V at 20 mA (terminals 5, 6) | |
Input resistance | ≤ 64 Ω terminals 2-, 3 ; ≤ 500 Ω terminals 1+, 3 (250 Ω load) | |
Available voltage | ≥ 16 V at 20 mA terminals 1+, 3 | |
Output | ||
Connection side | control side | |
Connection | terminals 7-, 8+, 9 | |
Load | 0 ... 800 Ω at 20 mA | |
Output signal | 0/4 ... 20 mA (overload > 25 mA) | |
Ripple | max. 50 µA rms | |
Transfer characteristics | ||
Deviation | at 20 °C (68 °F), 0/4 ... 20 mA ≤ 10 µA incl. calibration, linearity, hysteresis, loads and fluctuations of supply voltage | |
Influence of ambient temperature | 0.25 µA/K | |
Frequency range | field side into the control side: bandwidth with 0.5 Vpp signal 0 ... 7.5 kHz (-3 dB) control side into the field side: bandwidth with 0.5 Vpp signal 0.3 ... 7.5 kHz (-3 dB) | |
Settling time | 200 µs | |
Rise time/fall time | 20 µs | |
Galvanic isolation | ||
Output/power supply | functional insulation, rated insulation voltage 50 V AC | |
Indicators/settings | ||
Display elements | LED | |
Labeling | space for labeling at the front | |
Directive conformity | ||
Electromagnetic compatibility | ||
Directive 2014/30/EU | EN 61326-1:2013 (industrial locations) | |
Conformity | ||
Electromagnetic compatibility | NE 21:2011 | |
Degree of protection | IEC 60529:2001 | |
Protection against electrical shock | UL 61010-1:2012 | |
Ambient conditions | ||
Ambient temperature | -20 ... 60 °C (-4 ... 140 °F) | |
Mechanical specifications | ||
Degree of protection | IP20 | |
Connection | screw terminals | |
Mass | approx. 200 g | |
Dimensions | 20 x 124 x 115 mm (0.8 x 4.9 x 4.5 inch) , (W x H x D) housing type B2 | |
Mounting | on 35 mm DIN mounting rail acc. to EN 60715:2001 |
为你推荐
UB1000-18GM75-E01-V15 超声波传感器现货直发2022-12-20 13:31
产品型号:UB1000-18GM75-E01-V15 UB1000-18G:1 -
UMC3000-30H-E5-5M-3G-3D 超声波传感器现货直发2022-12-20 13:29
产品型号:UMC3000-30H-E5-5M-3G-3D UMC3000-30:1 -
UB6000-F42-I-V15 超声波传感器现货直发2022-12-20 13:21
产品型号:UB6000-F42-I-V15 UB6000-F42:1 -
UB500-18GM75-E01-V15 超声波传感器现货2022-12-20 13:20
产品型号:UB500-18GM75-E01-V15 UB500-18GM:1 -
UB5000-F42-UK-V95 超声波传感器现货直发2022-12-16 13:46
产品型号:UB5000-F42-UK-V95 UB5000-F42:1 -
UB500-F42S-U-V15 超声波传感器现货直发2022-12-16 13:44
产品型号:UB500-F42S-U-V15 UB500-F42S:1 -
UB4000-30GM-E4-V15 超声波传感器现货直发2022-12-16 13:42
产品型号:UB4000-30GM-E4-V15 UB4000-30G:1 -
UB2000-F42S-U-V15 超声波传感器现货直发2022-12-16 13:31
产品型号:UB2000-F42S-U-V15 UB2000-F42:1 -
UC2000-30GM-IUR2-V15-Y305942 传感器现货直发2022-12-16 13:27
产品型号:UC2000-30GM-IUR2-V15-Y305942 UC2000-30G:1 -
UB200-12GM-E5-V1 超声波传感器现货直发2022-12-16 13:23
产品型号:UB200-12GM-E5-V1 UB200-12GM:1
