--- 产品参数 ---
- KCD2-UT2-1 1
--- 产品详情 ---
参数表节选:的技术参数 KCD2-UT2-1
General specifications | ||
Signal type | Analog input | |
Functional safety related parameters | ||
Safety Integrity Level (SIL) | SIL 2 | |
Supply | ||
Connection | terminals 9+, 10- or power feed module/Power Rail | |
Rated voltage | 19 ... 30 V DC | |
Ripple | within the supply tolerance | |
Power dissipation | ≤ 0.98 W | |
Power consumption | max. 0.98 W | |
Interface | ||
Programming interface | programming socket | |
Input | ||
Connection side | field side | |
Connection | terminals 1, 2, 3, 4 | |
RTD | type Pt10, Pt50, Pt100, Pt500, Pt1000 (EN 60751: 1995) type Pt10GOST, Pt50GOST, Pt100GOST, Pt500GOST, Pt1000GOST (6651-94) type Cu10, Cu50, Cu100 (P50353-92) type Ni100 (DIN 43760) | |
Measuring current | approx. 200 µA with RTD | |
Types of measuring | 2-, 3-, 4-wire connection | |
Lead resistance | max. 50 Ω per line | |
Measurement loop monitoring | sensor breakage, sensor short-circuit | |
Thermocouples | type B, E, J, K, N, R, S, T (IEC 584-1: 1995) type L (DIN 43710: 1985) type TXK, TXKH, TXA (P8.585-2001) | |
Cold junction compensation | external and internal | |
Measurement loop monitoring | sensor breakage | |
Potentiometer | 0 ... 20 kΩ (2-wire connection), 0.8 ... 20 kΩ (3-wire connection) | |
Voltage | selectable within the range -100 ... 100 mV | |
Input resistance | ≥ 1 MΩ (-100 ... 100 mV) |
为你推荐
UB1000-18GM75-E01-V15 超声波传感器现货直发2022-12-20 13:31
产品型号:UB1000-18GM75-E01-V15 UB1000-18G:1 -
UMC3000-30H-E5-5M-3G-3D 超声波传感器现货直发2022-12-20 13:29
产品型号:UMC3000-30H-E5-5M-3G-3D UMC3000-30:1 -
UB6000-F42-I-V15 超声波传感器现货直发2022-12-20 13:21
产品型号:UB6000-F42-I-V15 UB6000-F42:1 -
UB500-18GM75-E01-V15 超声波传感器现货2022-12-20 13:20
产品型号:UB500-18GM75-E01-V15 UB500-18GM:1 -
UB5000-F42-UK-V95 超声波传感器现货直发2022-12-16 13:46
产品型号:UB5000-F42-UK-V95 UB5000-F42:1 -
UB500-F42S-U-V15 超声波传感器现货直发2022-12-16 13:44
产品型号:UB500-F42S-U-V15 UB500-F42S:1 -
UB4000-30GM-E4-V15 超声波传感器现货直发2022-12-16 13:42
产品型号:UB4000-30GM-E4-V15 UB4000-30G:1 -
UB2000-F42S-U-V15 超声波传感器现货直发2022-12-16 13:31
产品型号:UB2000-F42S-U-V15 UB2000-F42:1 -
UC2000-30GM-IUR2-V15-Y305942 传感器现货直发2022-12-16 13:27
产品型号:UC2000-30GM-IUR2-V15-Y305942 UC2000-30G:1 -
UB200-12GM-E5-V1 超声波传感器现货直发2022-12-16 13:23
产品型号:UB200-12GM-E5-V1 UB200-12GM:1
