--- 产品参数 ---
- KFD2-STC-1 1
--- 产品详情 ---
参数表节选:的技术参数 KFD2-STC1-Ex1
产品阐述 | ||
Output 4 ... 20 mA |
Supply | ||
Connection | Power Rail or terminals 7+, 8- | |
Rated voltage | 20 ... 35 V DC | |
Ripple | within the supply tolerance | |
Power dissipation | 0.8 W | |
Power consumption | max. 1.2 W | |
Input | ||
Connection | terminals 1+, 3- | |
Input signal | 4 ... 20 mA | |
Available voltage | at 20 mA: approx. 16.5 V at 200 Ohm Output load dependent on output load: U = 19.65 - (16.5 x 10-3 x RB); with RB = output load in Ohm | |
Output | ||
Connection | terminals 8-, 9+, 10-, 11+ | |
Output signal | 4 ... 20 mA , max. load 500 Ohm, with HART ≥ 230 Ohm | |
Ripple | max. 75 µA ss | |
Transfer characteristics | ||
Deviation | ≤ 10 µA incl. calibration, linearity, hysteresis, loads and fluctuations of supply voltage | |
Frequency range | field side into the control side: bandwidth with 1 mApp signal 0 ... 40 kHz (-1 dB); 0 ... 100 kHz (-6 dB) safe area to hazardous area: band width with 1 VSS signal 0 ... 40 kHz (-1 dB); 0 ... 100 kHz (-6 dB) | |
Rise time | 40 µs | |
De-energized delay | 40 µs | |
Directive conformity | ||
Electromagnetic compatibility | Standards | |
Directive 89/336/EEC | EN 61326, EN 50081-2, NE 21 | |
Ambient conditions | ||
Ambient temperature | -20 ... 60 °C (-4 ... 140 °F) | |
Mechanical specifications | ||
Degree of protection | IP20 | |
Mass | approx. 150 g | |
Data for application in connection with hazardous areas | ||
EC-Type Examination Certificate | BAS 00 ATEX 7127 , for additional certificates see www.pepperl-fuchs.com | |
Group, category, type of protection | II (1)GD [EEx ia] IIC (Tamb = -20 °C to +60 °C) [circuit(s) in zone 0/1/2] | |
Directive conformity | Standards | |
Directive 94/9/EC | EN 50014, EN 50020 |
为你推荐
UB1000-18GM75-E01-V15 超声波传感器现货直发2022-12-20 13:31
产品型号:UB1000-18GM75-E01-V15 UB1000-18G:1 -
UMC3000-30H-E5-5M-3G-3D 超声波传感器现货直发2022-12-20 13:29
产品型号:UMC3000-30H-E5-5M-3G-3D UMC3000-30:1 -
UB6000-F42-I-V15 超声波传感器现货直发2022-12-20 13:21
产品型号:UB6000-F42-I-V15 UB6000-F42:1 -
UB500-18GM75-E01-V15 超声波传感器现货2022-12-20 13:20
产品型号:UB500-18GM75-E01-V15 UB500-18GM:1 -
UB5000-F42-UK-V95 超声波传感器现货直发2022-12-16 13:46
产品型号:UB5000-F42-UK-V95 UB5000-F42:1 -
UB500-F42S-U-V15 超声波传感器现货直发2022-12-16 13:44
产品型号:UB500-F42S-U-V15 UB500-F42S:1 -
UB4000-30GM-E4-V15 超声波传感器现货直发2022-12-16 13:42
产品型号:UB4000-30GM-E4-V15 UB4000-30G:1 -
UB2000-F42S-U-V15 超声波传感器现货直发2022-12-16 13:31
产品型号:UB2000-F42S-U-V15 UB2000-F42:1 -
UC2000-30GM-IUR2-V15-Y305942 传感器现货直发2022-12-16 13:27
产品型号:UC2000-30GM-IUR2-V15-Y305942 UC2000-30G:1 -
UB200-12GM-E5-V1 超声波传感器现货直发2022-12-16 13:23
产品型号:UB200-12GM-E5-V1 UB200-12GM:1
