安全栅RD0-FB-Ex4
型号:
RD0-FB-Ex4
General specifications | ||
Design / Mounting | Cabinet installation | |
Fieldbus connection | ||
Main cable (Trunk) | ||
Connection | input (Trunk IN): terminals 3+, 4-, 5s output (Trunk OUT): terminals 7-, 8+, 6s | |
Rated voltage | 32 ... 16 V DC | |
Rated current | 31 mA ... 26 mA (without load) 77 mA ... 115 mA (at 20 mA load per input) 120 mA ... 209 mA (at 40 mA load per input) 135 mA ... 241 mA (short-circuit on all outputs) | |
Voltage drop | trunk IN to trunk OUT 100 mV max. | |
Number of couplers | max. 4 per segment | |
Outputs | ||
Number of devices per output | 1 | |
Connection | output 1: terminals 10+, 11-, 12S shield; output 2: terminals 13+, 14-, 15S shield; output 3: terminals 16+, 17-, 18S shield; output 4: terminals 19+, 20-, 21S shield | |
Rated voltage | 10 ... 13 V | |
Rated current | max. 43 mA | |
Short-circuit current | 50 mA | |
Indicators/operating means | ||
LED voltage Fieldbus | green: on, bus voltage existent | |
LED status output | red flashing: short-circuit | |
Galvanic isolation | ||
Main wire/outputs | isolation is not affected by interference according to EN 50020, voltage peak value 375 V | |
Directive conformity | ||
Electromagnetic compatibility | ||
Directive 2014/30/EU | EN 61326-1:2013 | |
Standard conformity | ||
Electromagnetic compatibility | NE 21:2006 | |
Degree of protection | IEC/EN 60529 | |
Fieldbus standard | IEC 61158-2 | |
Climatic conditions | DIN IEC 721 | |
Corrosion resistance | acc. to ISA-S71.04-1985, severity level G3 | |
Ambient conditions | ||
Ambient temperature | -50 ... 70 °C (-58 ... 158 °F) | |
Storage temperature | -40 ... 85 °C (-40 ... 185 °F) | |
Mechanical specifications | ||
Connection type | fixed terminals, plug-in terminals | |
Core cross section | up to 2.5 mm2 | |
Housing | see figure 1 | |
Housing material | Polycarbonate | |
R... DIN rail housing | PA 6.6 | |
Degree of protection | IP20 | |
Mass | 1050 g | |
Mounting | mounting on DIN rail in cabinet |
