M-LB-2.30T3.D 传感器现货直发
型号:
M-LB-2.30T3.D
General specifications | ||
Device type | type 3 acc. to EN 61643-11:2013 class III acc. to IEC 61643-1:2011 | |
Number of protected supply lines | 2 | |
Suitable components | protection module M-LB-2.30.T3.M | |
Electrical specifications | ||
Nominal voltage | 24 V AC, 50 ... 60 Hz | |
Maximum continuous operating voltage | 30 V AC, 50 ... 60 Hz 30 V DC | |
Nominal discharge current (8/20 µs) | 1 kA | |
Max. surge current (8/20 µs) | 2 kA | |
Voltage protection level | max. 180 V (L-N) max. 630 V (L/N-PE) | |
Reaction time | max. 25 ns (L-N) max. 100 ns (L/N-PE) | |
Short-circuit-proof | 6 kA eff at max. mains-side overcurrent protection | |
Overcurrent protection | max. 25 A gL/gG (B 25 A) , mains-side | |
Fault indication output | ||
Connection | terminals 11, 12, 14 | |
Output | volt-free change-over contact | |
Switch power | AC: 250 V / 0.5 A DC: 250 V/0.1 A; 125 V/0.2 A; 75 V/0.5 A; 24 V/0.5 A | |
Indicators/settings | ||
Display elements | status display operating state (green) fault indication (red) | |
Directive conformity | ||
Low voltage | ||
Directive 2014/35/EU | EN 61643-11:2012 | |
Conformity | ||
Degree of protection | IEC 60529:2013 | |
Shock resistance | EN 60068-2:2010 | |
Vibration resistance | EN 60068-2:2010 | |
Operating conditions | ||
Installation conditions | ||
Mounting location | indoor | |
Ambient conditions | ||
Ambient temperature | -40 ... 80 °C (-40 ... 176 °F) | |
Relative humidity | 5 ... 95 % | |
Mechanical specifications | ||
Degree of protection | IP20 | |
Core cross section | - min. 0.5 mm2 solid/flexible - max. 4 mm2 stranded/2.5 mm2 flexible | |
Material | ||
Housing | thermoplastic, color grey , UL 94 V-0 | |
Mass | approx. 120 g | |
Dimensions | 18 x 90 x 72 mm (0.7 x 3.6 x 2.8 inch) (W x H x D) , 1 TE acc. to DIN 43880 | |
Mounting | on 35 mm DIN mounting rail acc. to EN 60715:2001 | |
General information | ||
Supplementary information | Observe the certificates, declarations of conformity, instruction manuals, and manuals where applicable. For information see www.pepperl-fuchs.com. |
