KFD2-BR-1.PA.1500 现货直发
型号:
KFD2-BR-1.PA.1500
General specifications | ||
Design / Mounting | Cabinet installation | |
Supply | ||
Connection | Power Rail or terminals 11 (L+), 12 (L-) | |
Rated voltage | 20 ... 30 V DC | |
Ripple | ≤ 10 % | |
Rated current | 640 mA ... 365 mA | |
Power dissipation | max 2.5 W | |
Fieldbus connection | ||
PROFIBUS PA | ||
Connection | 3+, 6+, 2-, 5-, 1 shield, 4 shield | |
Rated voltage | 24 ... 26 V | |
Rated current | max. 400 mA | |
Terminating impedance | 100 Ω , integrated | |
PROFIBUS DP | PROFIBUS with RS-485 transmission technology | |
Connection | terminals 7 RxD/TxD-P, 8 RxD/TxD-N, 9 shield, 10 FE | |
Baud rate | 1.5 MBit/s max. | |
Indicators/operating means | ||
Switch | PROFIBUS DP terminator | |
LED PWR | green: Power on | |
LED DP/ERR | red 2 Hz flashing: DP error red on: Hardware error red off: DP communication detected | |
LED PA | red 2 Hz flashing: No PA communication or overload Off: PA communication OK | |
Galvanic isolation | ||
PROFIBUS DP/PROFIBUS PA | functional insulation acc. to IEC 62103, rated insulation voltage 50 V AC /70 V DC | |
PROFIBUS DP/Supply | basic insulation according to IEC/EN 61010, rated insulation voltage 253 V AC /357 V DC | |
PROFIBUS PA/Supply | basic insulation according to IEC/EN 61010, rated insulation voltage 253 V AC /357 V DC | |
Directive conformity | ||
Electromagnetic compatibility | ||
Directive 2014/30/EU | EN 61326-1:2013 | |
Standard conformity | ||
Electromagnetic compatibility | NAMUR NE 21 | |
Degree of protection | IEC/EN 60529 | |
Fieldbus standard | EN 50170/2 | |
Climatic conditions | DIN IEC 721 | |
Shock resistance | EN 60068-2-27 | |
Vibration resistance | EN 60068-2-6 | |
Ambient conditions | ||
Ambient temperature | -40 ... 60 °C (-40 ... 140 °F) | |
Storage temperature | -40 ... 85 °C (-40 ... 185 °F) | |
Relative humidity | < 95 % non-condensing | |
Shock resistance | 15 g 11 ms | |
Vibration resistance | 1 g 10 ... 150 Hz | |
Pollution degree | max. 2, according to IEC 60664 | |
Corrosion resistance | acc. to ISA-S71.04-1985, severity level G3 |
