HD2-FBPS-1.500 安全栅现货直发
型号:
HD2-FBPS-1.500
General specifications | ||
Design / Mounting | Motherboard based | |
Supply | ||
Rated voltage | 19.2 ... 35 V DC | |
Rated current | 910 ... 490 mA | |
Power dissipation | typ. 1.8 W | |
Fieldbus connection | ||
Rated voltage | 28 ... 30 V | |
Rated current | 500 ... 10 mA | |
Short-circuit current | 550 mA | |
Indicators/operating means | ||
LED ERR | red flashing: short-circuit or undervoltage at output | |
LED PWR | green if Uout > 28 V | |
Galvanic isolation | ||
Fieldbus segment/Supply | functional insulation acc. to IEC 62103, rated insulation voltage 250 V AC | |
Directive conformity | ||
Electromagnetic compatibility | ||
Directive 2014/30/EU | EN 61326-1:2013 | |
Standard conformity | ||
Electromagnetic compatibility | NE 21:2011 | |
Degree of protection | IEC 60529 | |
Fieldbus standard | IEC 61158-2 | |
Shock resistance | EN 60068-2-27 | |
Vibration resistance | EN 60068-2-6 | |
Ambient conditions | ||
Ambient temperature | -40 ... 70 °C (-40 ... 158 °F) | |
Storage temperature | -40 ... 85 °C (-40 ... 185 °F) | |
Relative humidity | < 95 % non-condensing | |
Shock resistance | 15 g 11 ms | |
Vibration resistance | 1 g , 10 ... 150 Hz | |
Pollution degree | max. 2, according to IEC 60664 | |
Corrosion resistance | acc. to ISA-S71.04-1985, severity level G3 | |
Mechanical specifications | ||
Connection type | motherboard specific | |
Core cross section | motherboard specific | |
Housing material | Polycarbonate | |
Housing width | 18 mm | |
Housing height | 106 mm | |
Housing depth | 128 mm | |
Degree of protection | IP20 | |
Mass | approx. 150 g | |
Mounting | motherboard mounting |
