企业号介绍
全部
  • 全部
  • 产品
  • 方案
  • 文章
  • 资料
  • 企业
上海冠宁科技发展有限公司
公司主要做传感器、编码器和安全栅,主要品牌有倍加福、MTL、 西克、菲尼克斯。
可获得潜在客户线索数量10+立即解锁
1.5k 内容数 13w+ 浏览量 21 粉丝
KFA5-SR2-EX1.W.LB 安全栅现货直发
型号: KFA5-SR2-EX1.W.LB
--- 产品参数 ---
  • KFA5-SR2-E 1
--- 产品详情 ---
参数表节选:的技术参数  KFA5-SR2-Ex1.W.LB
General specifications
Signal typeDigital Input
Functional safety related parameters
Safety Integrity Level (SIL)SIL 2
Supply
Connectionterminals 14, 15
Rated voltage103.5 ... 126 V AC , 45 ... 65 Hz
Power dissipation1.2 W
Power consumptionmax. 1.3 W
Input
Connection sidefield side
Connectionterminals 1+, 2+, 3-
Rated valuesacc. to EN 60947-5-6 (NAMUR)
Open circuit voltage/short-circuit currentapprox. 8 V DC / approx. 8 mA
Switching point/switching hysteresis1.2 ... 2.1 mA / approx. 0.2 mA
Line fault detectionbreakage I ≤ 0.1 mA , short-circuit I > 6 mA
Pulse/Pause ratiomin. 20 ms / min. 20 ms
Output
Connection sidecontrol side
Connectionoutput I: terminals 7, 8, 9 ; output II: terminals 10, 11, 12
Output Isignal ; relay
Output IIsignal or error message ; relay
Contact loading253 V AC/2 A/cos φ > 0.7; 126.5 V AC/4 A/cos φ > 0.7; 40 V DC/2 A resistive load
Energized/De-energized delayapprox. 20 ms / approx. 20 ms
Mechanical life107 switching cycles
Transfer characteristics
Switching frequency≤ 10 Hz
Galvanic isolation
Input/Outputreinforced insulation according to IEC/EN 61010-1, rated insulation voltage 300 Veff
Input/power supplyreinforced insulation according to IEC/EN 61010-1, rated insulation voltage 300 Veff
Output/power supplyreinforced insulation according to IEC/EN 61010-1, rated insulation voltage 300 Veff
Output/Outputreinforced insulation according to IEC/EN 61010-1, rated insulation voltage 300 Veff
Indicators/settings
Display elementsLEDs
Control elementsDIP switch
Configurationvia DIP switches
Labelingspace for labeling at the front
Directive conformity
Electromagnetic compatibility
 Directive 2014/30/EUEN 61326-1:2013 (industrial locations)
Low voltage
 Directive 2014/35/EUEN 61010-1:2010
Conformity
Electromagnetic compatibilityNE 21:2006
Degree of protectionIEC 60529:2001
InputEN 60947-5-6:2000
Ambient conditions
Ambient temperature-20 ... 60 °C (-4 ... 140 °F)
Mechanical specifications
Degree of protectionIP20
Connectionscrew terminals
Massapprox. 150 g
Dimensions20 x 119 x 115 mm (0.8 x 4.7 x 4.5 inch) (W x H x D) , housing type B2
Mountingon 35 mm DIN mounting rail acc. to EN 60715:2001
Data for application in connection with hazardous areas
EU-type examination certificatePTB 00 ATEX 2081
 Marking
Ex-Hexagon
II (1)G [Ex ia Ga] IIC
Ex-Hexagon
II (1)D [Ex ia Da] IIIC
Ex-Hexagon
I (M1) [Ex ia Ma] I
 InputEx ia
 Voltage10.6 V
 Current19.1 mA
 Power51 mW (linear characteristic)
Supply
 Maximum safe voltage126.5 V AC (Attention! Um is no rated voltage.)
Output
 Maximum safe voltage253 V AC (Attention! The rated voltage can be lower.)
Galvanic isolation
 Input/Outputsafe electrical isolation acc. to IEC/EN 60079-11, voltage peak value 375 V
 Input/power supplysafe electrical isolation acc. to IEC/EN 60079-11, voltage peak value 375 V
 Directive 2014/34/EUEN IEC 60079-0:2018+AC:2020 , EN 60079-11:2012
为你推荐
