企业号介绍
全部
  • 全部
  • 产品
  • 方案
  • 文章
  • 资料
  • 企业
巨匠机械
我们是做库存的 倍加福 施克 菲尼克斯 MTL 图尔克 总的库存有1千多万
98 内容数 1.2w 浏览量 4 粉丝
Current Driver/Repeater KFD0-CS-Ex2.51P
型号: KFD0-CS-Ex2.51P
--- 产品参数 ---
  • Signal typ Analog input/analog output
  • Safety Int SIL 2
  • Systematic SC 3
  • Rated volt loop powered
  • Connection terminals 12-, 11+; 8-, 10-, 9
  • Voltage 35 V DC
  • Current 40 mA
--- 产品详情 ---
  • 2-channel isolated barrier
  • 24 V DC supply (loop powered)
  • Current input/output 0 mA ... 40 mA
  • I/P or transmitter power supply
  • Accuracy 1 %
  • Reverse polarity protection
  • SIL 2 (SC 3) acc. to IEC/EN 61508
提示:以下是本篇文章正文内容,下面案例可供参考
一、产品描述
参数表节选:的技术参数  KFD0-CS-Ex2.51P
General specifications
Signal typeAnalog input/analog output
Functional safety related parameters
Safety Integrity Level (SIL)SIL 2
Systematic capability (SC)SC 3
Supply
Rated voltageloop powered
Control circuit
Connectionterminals 12-, 11+; 8-, 10-, 9+
Voltage4 ... 35 V DC
Current0 ... 40 mA
Power dissipationat 40 mA and Uin < 22 V: 700 mW per channel
at 40 mA and Uin > 22 V: 1.2 W per channel
Field circuit
Connectionterminals 1+, 2-; 4+, 5-
Voltagefor 4 V < Uin < 24 V: ≥ Uin - (0.37 x current in mA) - 1.0
for Uin > 24 V: ≥ 21 V - (0.36 x current in mA)
Short-circuit currentat Uin > 24 V: ≤ 65 mA
Transfer current≤ 40 mA
Transfer characteristics
Accuracy1 %
Deviation
 After calibration≤ ± 200 µA; incl. calibration, linearity, hysteresis and load fluctuations at the field side up to a load of 1 kΩ and current ≤ 20 mA at 20 °C (68 °F)
 Influence of ambient temperature≤ ± 2 µA/K at Uin ≤ 20 V; ≤ ± 5 µA/K at Uin > 20 V
Rise time≤ 5 ms at bounce from 4 ... 20 mA and Uin < 24 V
Galvanic isolation
Field circuit/control circuitsafe electrical isolation acc. to IEC/EN 60079-11, voltage peak value 375 V
Indicators/settings
Labelingspace for labeling at the front
Directive conformity
Electromagnetic compatibility
 Directive 2014/30/EUEN 61326-1:2013 (industrial locations)
Conformity
Electromagnetic compatibilityNE 21:2012
EN 61326-3-2:2008
Degree of protectionIEC 60529:2001
Protection against electrical shockUL 61010-1:2012
Ambient conditions
Ambient temperature-20 ... 70 °C (-4 ... 158 °F)
Mechanical specifications
Degree of protectionIP20
Connectionscrew terminals
Massapprox. 100 g
Dimensions20 x 107 x 115 mm (0.8 x 4.2 x 4.5 inch) (W x H x D) , housing type B1
Mountingon 35 mm DIN mounting rail acc. to EN 60715:2001
Data for application in connection with hazardous areas
EU-type examination certificateBAS 98 ATEX 7343 X
 Marking
Ex-Hexagon
II (1)G [Ex ia Ga] IIC, II (1)D [Ex ia Da] IIIC, I (M1) [Ex ia Ma] I (-20 °C ≤ Tamb ≤ 60 °C)
 Voltage25.2 V
 Current93 mA
 Power585 mW
Control circuit
 Maximum safe voltage250 V eff (Attention! The rated voltage can be lower.)
Field circuit
CertificateFIDI 22 ATEX 0001X
 Marking
Ex-Hexagon
II 3G Ex ec IIC T4 Gc [device in zone 2]
Galvanic isolation
 Directive 2014/34/EUEN IEC 60079-0:2018 , EN 60079-11:2012 , EN IEC 60079-7:2015+A1:2018
International approvals
FM approval
 Control drawing116-0437
UL approval
 Control drawing116-0438 (cULus)
IECEx approval
 IECEx certificateIECEx BAS 05.0004X
IECEx CML 19.0040X
 IECEx marking[Ex ia Ga] IIC , [Ex ia Da] IIIC , [Ex ia Ma] I
Ex ec IIC T4 Gc
General information
Supplementary informationObserve the certificates, declarations of conformity, instruction manuals, and manuals where applicable. For information see www.pepperl-fuchs.com.
二、应用领域
示例:
• 工业控制领域:工业、控制设备美。
• 智能交通设备:收费站、停车场、车内语音提示;
• 广告宣传行业:广告语播报;
三、应用电路图
示例:
总结
提示:这里对文章进行总结:
例如:以上就是今天要讲的内容,本文仅仅简单介绍了XX产品的使用,我们提供了大量方案产品,欢迎联系,感谢您的关注。
为你推荐
  • Terminal Block for Cold Junction Compensation K-CJC-1BU2022-11-08 13:37
    产品型号:K-CJC-1BU 变送器位置:c 信号范围:4到20mA 大范围:1.0到21.5mA 常规变送器:0到3602 智能变送器:2500土10%
  • Terminal Block for Cold Junction Compensation K-CJC-BU2022-11-08 13:28
    产品型号:K-CJC-BU Number of :3 Core cross:max. 2.5 mm2 Color:blue Mass:approx. 5 g Dimensions:15.1 x 15 x 18 mm
  • SD07R2022-11-08 13:20
    产品型号:SD07R 变送器位置 : c 信号范围:4到20mA 大范围:1.0到21.5mA 常规变送器:0到3602 智能变送器:2500土10%
  • Solenoid Driver KFD0-SD2-Ex1.10452022-11-08 13:16
    产品型号:KFD0-SD2-Ex1.1045 信号类型 :数字输入 安全完整性等级:(SIL) SIL 2 连接端子:14 额定电压 : 103 功率耗散:1 W
  • SMART Transmitter Power Supply KFD2-STV5-Ex1-12022-11-08 13:09
    产品型号:KFD2-STV5-Ex1-1 信号类型:数字输入 安全完整性等级:(SIL) SIL 2 连接端子:14 额定电压:103 功率耗散 :1 W
  • Voltage Repeater KFD2-VR2-Ex1.50M2022-11-08 11:43
    产品型号:KFD2-VR2-Ex1.50M 信号类型:数字输入 安全完整性等级:(SIL) SIL 2 连接端子:14 额定电压:103 功率耗散:1 W
  • 电感式传感器 NBN8-18GM50-E22022-11-07 13:43
    产品型号:NBN8-18GM50-E2 开关功能:开关功能 输出类型:输出类型 额定工作距离:8 mm 安装:非齐平 输出极性:DC
  • 技术支持Emerson 475手操器2022-11-07 11:22
    产品型号:475手操器 Offline:脱机 Onling:在线 MEASURING :测量用的方式 Pressure:压力 Level:标准、水平的
  • 加拿大-AFP-正品全新原装-ELDV2-10-16MT-0030 AFP十通隔膜阀2022-11-07 11:09
    产品型号:ELDV2-10-16MT-0030 产地:加拿大 是否进口:是 订货号:3900 加工定制:否 货号:3900-03038
  • Current Driver/Repeater KFD0-CS-Ex2.51P2022-11-04 09:42
    产品型号:KFD0-CS-Ex2.51P Signal typ:Analog input/analog output Safety Int:SIL 2 Systematic:SC 3 Rated volt:loop powered Connection:terminals 12-, 11+; 8-, 10-, 9
