企业号介绍
全部
  • 全部
  • 产品
  • 方案
  • 文章
  • 资料
  • 企业
巨匠机械
我们是做库存的 倍加福 施克 菲尼克斯 MTL 图尔克 总的库存有1千多万
98 内容数 1.5w 浏览量 4 粉丝
Voltage Repeater KFD2-VR2-Ex1.50M
型号: KFD2-VR2-Ex1.50M
--- 产品参数 ---
  • 信号类型 数字输入
  • 安全完整性等级 (SIL) SIL 2
  • 连接端子 14
  • 额定电压 103
  • 功率耗散 1 W
  • 最大功耗 1.5 W
--- 产品详情 ---
  • 1-channel isolated barrier
  • 24 V DC supply (Power Rail)
  • Voltage input 0 mV ... ± 50 mV
  • Voltage output 0 mV ... ± 50 mV
  • Selectable up/downscale sensor breakage detection
提示:以下是本篇文章正文内容,下面案例可供参考
一、产品描述
参数表节选:的技术参数  KFD2-VR2-Ex1.50M
General specifications
Signal typeAnalog input
Supply
ConnectionPower Rail or terminals 14+, 15-
Rated voltage19 ... 30 V DC
Ripplewithin the supply tolerance
Rated current≤ 11 mA
Power dissipation/power consumption0.3 W max.
Input
Connection sidefield side
Connectionterminals 4+, 5-
Input resistancemin. 20 MΩ
Transmission range-50 ... 50 mV
Offset voltage/current≤ 5 µV / ≤ 5 nA
Line fault detection100 nA
Output
Connection sidecontrol side
Connectionterminals 7+, 8-
Voltage-50 ... 50 mV
LoadAccuracy figures for infinite load impedance. Additional 0.03 % of span for a load resistance of 10 kΩ
Fault signalsensor breakage: > +100 mV (upscale), < -100 mV (downscale)
Output resistancemax. 3 Ω
Transfer characteristics
Cut-off frequency350 Hz (-3 dB)
Deviation
 After calibrationat 20 °C (68 °F): ± 3 µV up to ± 10 mV/± 0.03 % of the span up to +50 mV/± 0.05 % of the span up to -50 mV
 Influence of ambient temperature± 1 µV/K (typical ± 0.25 µV/K)
Absolute< 0.25 K at 30 V voltage supply
Rise time≤ 1 ms
Galvanic isolation
Output/power supplyfunctional insulation, rated insulation voltage 50 V AC
Indicators/settings
Display elementsLED
Control elementsDIP switch
Configurationvia DIP switches
Labelingspace for labeling at the front
Directive conformity
Electromagnetic compatibility
 Directive 2014/30/EUEN 61326-1:2013 (industrial locations)
Conformity
Electromagnetic compatibilityNE 21
Degree of protectionIEC 60529
Protection against electrical shockUL 61010-1
Ambient conditions
Ambient temperature-20 ... 60 °C (-4 ... 140 °F)
Mechanical specifications
Degree of protectionIP20
Connectionscrew terminals
Massapprox. 125 g
Dimensions20 x 119 x 115 mm (0.8 x 4.7 x 4.5 inch) (W x H x D) , housing type B2
Mountingon 35 mm DIN mounting rail acc. to EN 60715:2001
Data for application in connection with hazardous areas
EU-type examination certificateBASEEFA 06 ATEX 0040
 Marking
Ex-Hexagon
II (1)GD, I (M1) [Ex ia Ga] IIC, [Ex ia Da] IIIC, [Ex ia Ma] I (-20 °C ≤ Tamb ≤ 60 °C) , [circuit(s) in zone 0/1/2]
 Voltage5.5 V DC
 Current2.4 mA
 Power3.3 mW
Supply
 Maximum safe voltage250 V (Attention! The rated voltage can be lower.)
CertificateBASEEFA 09 ATEX 0219X
 Marking
Ex-Hexagon
II 3G Ex ec IIC T4 Gc
Galvanic isolation
 Input/Outputsafe electrical isolation acc. to IEC/EN 60079-11, voltage peak value 375 V
 Input/power supplysafe electrical isolation acc. to IEC/EN 60079-11, voltage peak value 375 V
 Directive 2014/34/EUEN 60079-0:2012+A11:2013 , EN 60079-7:2015+A1:2018 , EN 60079-11:2012
International approvals
UL approval
 Control drawing116-0334 (cULus)
IECEx approval
 IECEx certificateIECEx BAS 06.0011
IECEx BAS 09.0103X
 IECEx marking[Ex ia Ga] IIC , [Ex ia Da] IIIC , [Ex ia Ma] I
Ex ec IIC T4 Gc
General information
Supplementary informationObserve the certificates, declarations of conformity, instruction manuals, and manuals where applicable. For information see www.pepperl-fuchs.com.
二、应用领域
示例:
• 工业控制领域:工业、控制设备美。
三、应用电路图
示例:
总结
提示:这里对文章进行总结:
例如:以上就是今天要讲的内容,本文仅仅简单介绍了XX产品的使用,我们提供了大量方案产品,欢迎联系,感谢您的关注。
为你推荐
  • Terminal Block for Cold Junction Compensation K-CJC-1BU2022-11-08 13:37
    产品型号:K-CJC-1BU 变送器位置:c 信号范围:4到20mA 大范围:1.0到21.5mA 常规变送器:0到3602 智能变送器:2500土10%
  • Terminal Block for Cold Junction Compensation K-CJC-BU2022-11-08 13:28
    产品型号:K-CJC-BU Number of :3 Core cross:max. 2.5 mm2 Color:blue Mass:approx. 5 g Dimensions:15.1 x 15 x 18 mm
  • SD07R2022-11-08 13:20
    产品型号:SD07R 变送器位置 : c 信号范围:4到20mA 大范围:1.0到21.5mA 常规变送器:0到3602 智能变送器:2500土10%
  • Solenoid Driver KFD0-SD2-Ex1.10452022-11-08 13:16
    产品型号:KFD0-SD2-Ex1.1045 信号类型 :数字输入 安全完整性等级:(SIL) SIL 2 连接端子:14 额定电压 : 103 功率耗散:1 W
  • SMART Transmitter Power Supply KFD2-STV5-Ex1-12022-11-08 13:09
    产品型号:KFD2-STV5-Ex1-1 信号类型:数字输入 安全完整性等级:(SIL) SIL 2 连接端子:14 额定电压:103 功率耗散 :1 W
  • Voltage Repeater KFD2-VR2-Ex1.50M2022-11-08 11:43
    产品型号:KFD2-VR2-Ex1.50M 信号类型:数字输入 安全完整性等级:(SIL) SIL 2 连接端子:14 额定电压:103 功率耗散:1 W
  • 电感式传感器 NBN8-18GM50-E22022-11-07 13:43
    产品型号:NBN8-18GM50-E2 开关功能:开关功能 输出类型:输出类型 额定工作距离:8 mm 安装:非齐平 输出极性:DC
  • 技术支持Emerson 475手操器2022-11-07 11:22
    产品型号:475手操器 Offline:脱机 Onling:在线 MEASURING :测量用的方式 Pressure:压力 Level:标准、水平的
  • 加拿大-AFP-正品全新原装-ELDV2-10-16MT-0030 AFP十通隔膜阀2022-11-07 11:09
    产品型号:ELDV2-10-16MT-0030 产地:加拿大 是否进口:是 订货号:3900 加工定制:否 货号:3900-03038
  • Current Driver/Repeater KFD0-CS-Ex2.51P2022-11-04 09:42
    产品型号:KFD0-CS-Ex2.51P Signal typ:Analog input/analog output Safety Int:SIL 2 Systematic:SC 3 Rated volt:loop powered Connection:terminals 12-, 11+; 8-, 10-, 9
